Running Thread of the Daily: 325XI
245s, that must be some serious winter traction!
those wheels look great on an e46.
A little wider than I'd prefer but I like those wheels too! Thanks!
New summer set up! Continental Extremecontact Sport XL tires. 18" 225/40 front, 255/35 rear.
Which lift kit is that?
Ben PLS Kuhstum
Lolol
Trans started slipping so got it replaced with a 94k mile trans out of a 325xi. Got the starter rebuilt, new trans filter/gasket. Tensioner & idler pullies replaced. New oil filter housing gasket and hood latches.
Mike also made the rust dissappear by the rear wheel arches. Not bad for a napa rattle can!
Now we just need some snow!
All work done at 212k miles.
You take good care of your stuff. E46 are getting old enough that some of them are approaching 1 failed emissions test from being "kept" outside of Milwaukee County. she’s a keeper!
I fixed it for you.
Maintenance!!!!!
Slow leak in the coolant reservoir, front diff whining on decel, clunk in front suspension all addressed along with some other items!
Grabbed a used diff and Mike added new input and output seals. New o-rings on the trans cooler. New serpentine belt. New locking/hazard button. New swaybar links. "New" suede steering wheel with white label airbag. New Phillips 4300k xenon blubs.
