  4. Running Thread of the Daily: 325XI
107 Posts 14 Posters 2.0k Views 1 Watching
    Missed an upload.  New o-rings on the injectors.  These were a PITA!  My fingertips were raw afterwards.
    The car has been running great!  There seems to be no oil consumption at all after 200 miles.  Super pumped!
    I'm still getting post cat O2 sensor codes on both banks.  I will be doing a water pump and a T-stat soon. Hopefully the t-stat is sticking open and not letting the car get to operating temp.  If not, headers and software to come.  Not what I want to be doing to this car but that engine light is annoying.
      Dude, I hear ya with those injector o-rings!  I did them over the weekend and putting the new ones on was way harder than I anticipated!
      • The Full BananaT
        The Full BananaT
        The Full Banana
        A small pick is a must for replacing those o-rings. Definitely a good tool to keep around.
          I used that to get them off but getting them on was a pain.  I'm not sure if leadballs experience was the same.
            Is it common for those injector O-rings to fail?
              no, its a 'while you are in there'. the o-rings certainly feel rock hard after 15 years, so putting them back into place seems like a terrible idea considering the cheap cost of new o-rings and how destructive a fuel leak could be.
                It's good practice to replace any o-ring that are more than a year or two old if you disturb them, its super cheap insurance against leaks
                  Makes sense, I was just curious.
                    On e46's it is a common fail.  The symptoms would be smelling gas while not seeing a leak, extended crank time after it's been sitting or brief rough idle at start up.  The O-rings fail because they are old and brittle and they definitely need to be replaced after removing the injectors but it's also a common fail item.
                      Replaced the steering linkage. It's a totally new car now!
                      The old/original linkage was so hard to move and the u-joints were clunky and loose. To get the bold one to move I had to bang it on the concrete multiple times.5f3883becc219d79dd68f525c1aa5bf8.jpgeec130bda15f1031ff2ffc3f586ed196.jpg
                        How was the install on that? Need to do it on Robin's car pretty soon as hers has a u-joint going bad as well.
                          Not bad. Take off the drivers wheel. 2 8mm 12point bolts and some careful prying and hammering. Do the bottom first. Some WD40 a day before the removal wouldn't be a bad idea.
                            Oil and filter change with Castrol Edge 0W-40.
                            184,412 miles.
                            I finally joined bobistheoilguy.com and am switching away from Mobil 1 5w-30.
                              Rowfull @ bobistheoilguy
                              Im glad it exists because there is some real in depth discussion and useful info going on there but there is something comical about an entire forum dedicated to arguing about the best oil.
                              There are some real Amsoil leg-humpers there
                              Valvoline and Castrol FTW
                              Fite me IRL if you disagree
                                  Sport Seats! Cleaned them up and leather conditioned them over the past 3 days.
                                    Daggerty
                                    Just did this, it's amazing how much they soak up if they have a neglected past.
                                      Which product are you using? They are in a lot better shape for that mileage than the usual e30 sport seat, thats for sure
                                        Got this think off of Jack stands a week ago.
                                        186,XXX miles
                                        Items completed:
                                        -Engine Mounts
                                        -Oil pan gasket
                                        -Oil filter
                                        -All front and rear diff seals, fill plug o-rings
                                        -Front diff bearings
                                        -Liqui Moly
                                        -Front Axles
                                        -Rear chassis diff mount
                                        -CSB, C-Clip, Cap
                                        -Guibo
                                        -Pressurized power steering line
                                        -Headers
                                        -New Studs and nutsd6f17afbc251fad279e59cb646843af0.jpg004cb80bd2a369da5a099fbb265aa6d5.jpg836c04eb5aeb00f83b589610518cc7c2.jpg34d9f1855e531da2c1bc0a146e3df7ef.jpg7f86cbc1d6f7b43f69ee36c9aba45595.jpg100a6b4cb3ff53985d937b6f61deff58.jpg992097bbf37949bdfaba7adf8d7f4f93.jpgf8f7dce231dafe477720296e3beaa3d0.jpg6776f919bf58e47ae67bdde441e434a9.jpg06bb156440ca55949f8df3a2c578d0b5.jpgbb09c6302e14d11daa67c12324e6015e.jpg82affd9d402c9bdc5167655c09487f16.jpg3ff32ba36b1dcd9aa61b4b4c0daa9f05.jpgecc931d2478b600fe08c76ca6d35617f.jpg
                                          Welcome back!
                                          Whats all that sealant looking stuff on the exhaust manifold. Did you use a manifold gasket with that as well?
