  • JeffJ
    JeffJ
    Jeff
    solid bushings next time!
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      What it really needs is that AC-S or Max Velocity RS lip
        What it really needs is to be finished.
        fixed it for you!!
          It could definitely use that:( I might have found a lip though:P tomorrow I will be working on the car if anyone wants to stop by.
            I got some work done on Thursday and Sunday, but I only took one picture=/
            Lets start off with the trailing arm bushings. I figured out why they will not seat. I simply installed them incorrectly. You are supposed to insert each poly piece, and then run the sleeve through the middle. I ran the outer pieces in, with the sleeve in. When I put the inner pieces in, it trapped air. This kept them from fully seating, and is now keeping me from taking them out. All I can think of now is to drill a small hole in each one to let the air escape, and then install a zerk fitting so I can grease them in the future. I will let you know how this works after Wednesday.
            Now for work that actually got completed. I got sick of seeing the firewall/trans tunnel insulation just dangling there, so I finished tugging the rest of it out.
            Other than that, I finished removing all of the seam sealer that I could find and also finished smoothing out the mounting points for the old ABS brackets. The next step for the bay is to weld the seams to keep any filler used from cracking. I wish I could fill every imperfection in the bay with metal, to stay away from having to use filler. That would take a whole lot of time and I would still need filler in the end to smooth it all out. Hopefully I will just need a light skim coat to fill small indents and to smooth all of the welded seams out.
              So to start on a bad note, I may have to destroy my new bushings to get them out. I drilled a hole in the end of one arm to release the air, and that didn't help at all. I'm really not sure how else to remove the bushings without damaging them=/
              Good Note: I should have some boxes showing up today=D Not sure exactly which ones, but they're all great.
              I got something done yesterday that I have been meaning to do.
              Started by removing this:
              To access here (among other reasons):
              So that I could bundle these here securely:
              So that I would be left with this:
              Bye bye wires. Also snapped some pics of the bay ready for the seams to be welded:
              Then I was peeling plastidip off of my front bumper. I will never plastidip a car again. The removal is so tedious=/
              Updates tomorrow with whichever boxes arrive=P
                Did you want to use my press?  It's a small floor standing 10 or 12 ton.  You can even take it to your shop for awhile if you want (get it out of my way during my move later in the month).
                Might help with the bushing project.
                • StewCrewS
                  StewCrewS
                  StewCrew
                  Earl I was reading about plastidip and I guess heating it up a little bit works well.  Ill bring a heat gun with me next time I swing by.
                    I might need to take you up on that offer Robert=) I don't know how it'd get there though. lol I was thinking about that Jake. I wanted to try goo gone on the overspray in my jams and tail light recesses too.
                    • Brian.B
                      Brian.B
                      Brian.
                      Don't use a heat gun for it, that'll do more harm then good, use a high amp hair dryer. Aside from that, i've thought about plasti-dipping my E28..
                      instagram @howdoyoudrivethat
                        I highly recommend getting the dipyourcar.com kit then. No matter what, it is a huge pain to sit and remove it because it takes so long. lol
                          Is your car in West Bend?  I could through it in the truck, otherwise it isn't overly large, it could fit in a hatchback.
                            It's actually off of Good Hope. If it can fit in the back seat of a mk3, we should be good;)
                              It might.  At worst it could be unbolted.
                                Awesome;)
                                  My boxes didn't end up showing up on Thursday. UPS needed me to sign for them, and I wasn't home. So of course I took off Friday just to be able to sign for them. They came 7 minutes after I would have been home from work=/ Oh well.
                                  Anyways it was like Christmas thanks to Bag Riders=)
                                  I asked them to draw on the boxes to see how creative they are. I had a good laugh
                                  Contents of two of the boxes
                                  The third box was my UAS Airhouse 2's for the rear. I got the tank raw so that I could paint it myself. Here is while it was drying:
                                  I also picked up an AC-Schnitzer style CF lip on Saturday in need of repairs. Kerry and I are going to fix it and then it will be getting painted to match my rub strips.
                                  Other than getting parts and painting the tank, I didn't get any work done on the car. I was at Kerrys Saturday and then realised that I didn't have anything I needed to get any work done on the car. Wednesday I will be getting the bags mounted to the trailing arms and hopefully fixing the bushing situation. I also need to figure out how I want my trunk setup to be. I want it clean and classy, but not boring.
                                  Updates to come after Wednesday
                                  • StewCrewS
                                    StewCrewS
                                    StewCrew
                                    How did it go with Kerry fixing that lip?  I didnt get to see the end result
                                      Me neither=) Lol We didn't start on it. We were going to do it Wednesday, but I remembered that I have leagues. Hopefully sometime this weekend or next week we can get to it.
                                        hahah those boxes are hilarious!!!!
                                          I always love asking companies to draw on the boxes. Sometimes they draw really awesome pictures, and sometimes they provide a good laugh:)
