    What it really needs is to be finished.
    fixed it for you!!
      It could definitely use that:( I might have found a lip though:P tomorrow I will be working on the car if anyone wants to stop by.
        I got some work done on Thursday and Sunday, but I only took one picture=/
        Lets start off with the trailing arm bushings. I figured out why they will not seat. I simply installed them incorrectly. You are supposed to insert each poly piece, and then run the sleeve through the middle. I ran the outer pieces in, with the sleeve in. When I put the inner pieces in, it trapped air. This kept them from fully seating, and is now keeping me from taking them out. All I can think of now is to drill a small hole in each one to let the air escape, and then install a zerk fitting so I can grease them in the future. I will let you know how this works after Wednesday.
        Now for work that actually got completed. I got sick of seeing the firewall/trans tunnel insulation just dangling there, so I finished tugging the rest of it out.
        Other than that, I finished removing all of the seam sealer that I could find and also finished smoothing out the mounting points for the old ABS brackets. The next step for the bay is to weld the seams to keep any filler used from cracking. I wish I could fill every imperfection in the bay with metal, to stay away from having to use filler. That would take a whole lot of time and I would still need filler in the end to smooth it all out. Hopefully I will just need a light skim coat to fill small indents and to smooth all of the welded seams out.
          So to start on a bad note, I may have to destroy my new bushings to get them out. I drilled a hole in the end of one arm to release the air, and that didn't help at all. I'm really not sure how else to remove the bushings without damaging them=/
          Good Note: I should have some boxes showing up today=D Not sure exactly which ones, but they're all great.
          I got something done yesterday that I have been meaning to do.
          Started by removing this:
          To access here (among other reasons):
          So that I could bundle these here securely:
          So that I would be left with this:
          Bye bye wires. Also snapped some pics of the bay ready for the seams to be welded:
          Then I was peeling plastidip off of my front bumper. I will never plastidip a car again. The removal is so tedious=/
          Updates tomorrow with whichever boxes arrive=P
            Did you want to use my press?  It's a small floor standing 10 or 12 ton.  You can even take it to your shop for awhile if you want (get it out of my way during my move later in the month).
            Might help with the bushing project.
            • StewCrewS
              StewCrewS
              StewCrew
              Earl I was reading about plastidip and I guess heating it up a little bit works well.  Ill bring a heat gun with me next time I swing by.
                I might need to take you up on that offer Robert=) I don't know how it'd get there though. lol I was thinking about that Jake. I wanted to try goo gone on the overspray in my jams and tail light recesses too.
                  Don't use a heat gun for it, that'll do more harm then good, use a high amp hair dryer. Aside from that, i've thought about plasti-dipping my E28..
                    I highly recommend getting the dipyourcar.com kit then. No matter what, it is a huge pain to sit and remove it because it takes so long. lol
                      Is your car in West Bend?  I could through it in the truck, otherwise it isn't overly large, it could fit in a hatchback.
                        It's actually off of Good Hope. If it can fit in the back seat of a mk3, we should be good;)
                          It might.  At worst it could be unbolted.
                            Awesome;)
                              My boxes didn't end up showing up on Thursday. UPS needed me to sign for them, and I wasn't home. So of course I took off Friday just to be able to sign for them. They came 7 minutes after I would have been home from work=/ Oh well.
                              Anyways it was like Christmas thanks to Bag Riders=)
                              I asked them to draw on the boxes to see how creative they are. I had a good laugh
                              Contents of two of the boxes
                              The third box was my UAS Airhouse 2's for the rear. I got the tank raw so that I could paint it myself. Here is while it was drying:
                              I also picked up an AC-Schnitzer style CF lip on Saturday in need of repairs. Kerry and I are going to fix it and then it will be getting painted to match my rub strips.
                              Other than getting parts and painting the tank, I didn't get any work done on the car. I was at Kerrys Saturday and then realised that I didn't have anything I needed to get any work done on the car. Wednesday I will be getting the bags mounted to the trailing arms and hopefully fixing the bushing situation. I also need to figure out how I want my trunk setup to be. I want it clean and classy, but not boring.
                              Updates to come after Wednesday
                              • StewCrewS
                                StewCrewS
                                StewCrew
                                How did it go with Kerry fixing that lip?  I didnt get to see the end result
                                  Me neither=) Lol We didn't start on it. We were going to do it Wednesday, but I remembered that I have leagues. Hopefully sometime this weekend or next week we can get to it.
                                    hahah those boxes are hilarious!!!!
                                      I always love asking companies to draw on the boxes. Sometimes they draw really awesome pictures, and sometimes they provide a good laugh:)
                                        I was very happy with how yesterday went.
                                        I finally got to order my 3" and 3.5" lips. I am so excited for them to come.
                                        After work I got to the shop and had just the right tool to get the pesky RTAB sleeves out.
                                        After a little wrestling I let out a sigh of relief as I stared at these.
                                        Now to reinstall them correctly this next time=D
                                        I grabbed these front work
                                        And what do you know, matching threads
                                        And then I did this slick move
                                        Tada
                                        I got them to screw on nice and flat=) Just need to put some loctite on the threads when I reinstall them. Now to make the top mounting coles on the frame rail.
                                        I also grabbed the subframe and took it in the light to see the color. Reminds me of a bass boat when there is heavy light=P
                                        From a distance it is just a metallic pewter color.
                                        The next updates will be after Saturday=)
                                          good to see this moving along Earl!!
