  4. 1999 M3 daily driver running log
264 Posts 28 Posters 2 Views 1 Watching
    New snow tires made for a lot of fun yesterday!
      Pretty sure I saw you driving south on hwy 100 through Franklin last week or the week before. Car looked good.
        Pressed in e30 ball joints into my 96+ M3 control arms tonight, worked perfectly. The parts are definitely identical which is cool. Some sources say the outer joints are not sensitive to their orientation like the inner joints, this is definitely false, thankfully I noticed before I pressed the new joints in.
        The inners are the ones with the cut off threads, you can clearly see the oval shape on those, and you can also see the oval shape on the outers as well. It's not as pronounced on the outers but is definitely there.
        The inner joint nuts were a huge pain to remove, the passenger side taper popped and the nut got stuck halfway off. Had to use an automotive induction heater (really cool tool and a great alternative to a torch when you're working near critical components like engine mounts in my instance), strong arm, cutoff wheel, and air chisel to get the damn thing off. Had I not went to the shop I used to work at, I would've been screwed. The car drives a lot better, there was quite a bit of play in the old parts...
        Also, got a 2" piece of brass rod stuck in my brand new snow tires. Pulled it out and sprayed some soapy water, thankfully it didn't puncture the tire.
          This is going to sound silly but i'd still get a plug/patch put in that tire.  Once something penetrates the rubber deep enough then all the nice ingredients to make rust work their way into the steel belts which will cause belt separation.  I know it sounds out there but I've seen it numerous times.
          Also, which induction heater do you have?  I have looked at these and i'm always tempted to buy one!  I've seen demos and they are a neat tool!
            The reason I didn't patch it at the time is that it went into the tire almost tangent to the tread so I figured it probably didn't get down that far, although it didn't come out the other side so it's hard to tell how deep it went. If they were old tires I would probably just forget about it but you make a good point...I'll see if I can get a plug in there.
            I was borrowing the induction heater at the shop and I can't for the life of me remember the brand. It was probably one of the coolest tools I ever used. Heated the inner joint nut to red hot and didn't even disturb the dust on the rubber motor mount less than an inch away!
              Sweet tool. Pricing these though seems to be in the $500 range. Is there a lower cost version?
                Looked it up, it was an Induction Innovations MD-600 Mini-ductor, looks like they are in the $500 range. Definitely not a tool I would buy for myself unless I won the lottery or something
                  Took this pic after cleaning it up the other day, can't wait to really get it polished up this summer.
                  Drove the car 600 miles this weekend (Grand Rapids, MI, and back) and it did the trip without a hitch!
                    My cassette tape adapter stopped working so I decided to modify my C43 head unit to add an auxiliary input. I wanted to retain the oem look so I didn't want to use a more modern head unit.
                    I followed a few of the DIY's online and tapped into the audio out on the tape deck. The first attempt I used a headphone cord with very thin wires
                    This worked initially, but the leads soldered to the 3.5mm female plug were extremely fragile and one cracked and I lost the left channel while installing the radio back in the car. I tried again with much more durable 20 gauge wire and it worked beautifully
                    I ran the wires out a gap in the back of the radio chassis, protected the wires from abrasion, and fixed them in place to stress relieve the soldered joints
                    There was very little room behind where I wanted to mount the input jack (as I found out after the first attempt) so I attached the wires at 90 degrees
                    I mounted the input in the back of the storage tray under the OBC as I wanted it out of sight with the cord removed, yet still easily accessible
                    I gutted the old cassette adapter to be used to trick the head unit into playing the new audio input and it works beautifully! I had heard many complaints about the sound being very muddy and quiet with this mod, and that was the case with my first attempt. I figured out that this can be caused by the Dolby noise reduction filter on the tape deck and can be corrected by hitting preset 6 while in tape mode to switch it off. The sound quality is excellent and I am very pleased with the results!
                      nice work on the stereo hack!
                      just an fyi for the inner ball joints, and I know this because almost every one I've done had the same thing happen as you, you can put pressure on the bottom of the joint to keep it from spinning. I usually get a jack stand in place and lower the cars weight onto it.
                        I shouldve done that from the start haha, that's what I get for rushing... There was rust and dirt that got caught in the threads and basically seized the nut to the threads. I didn't have the joint supported on the first side and the force I was using to try and turn the nut popped the joint free. Once that happened, I put a strong arm underneath it (basically holding up the entire car) and it was still spinning so I had to split the nut with a cut off wheel and chisel it off. On the other side I used the strong arm from the start and was able to get it off with just that and a lot of heat
                          Links to the head unit mods? I've been wanting to do this with a e34 head unit.
                            http://www.bimmerforums.com/forum/showthread.php?1886405-DIY-E36-Aux-in-with-C43-headunit
                            Here is the one I used, really simple mod actually. Only hard part was the fairly fine soldering
                              the hard part is differences between units. unless someone has done your specific unit, or you are an electrical engineer, its pretty much a crap shoot.  I imagine Chris's e34 doesn't have a CD43.  For my e30, I had to buy a tape deck (there are like 50 versions) that someone had already figured out that model. I couldn't get my slightly different unit to work with the same DIY.
                                I was lucky enough that the unit I have (C43) had that really good DIY, I believe the C43 can be adapted to quite a few cars as it is a standard size and they usually go for fairly cheap compared to a CD43.
                                  Picked up a set of wheels that I am super stoked about:
                                  18x8 et35 BBS RE 847
                                  They were used as winter wheels so the paint is bubbling a bit in a few places but the rest of my car is the same story so it doesn't bother me, down the road a light refinish and they will be good as new.
                                    Nice score!
                                      Nice! What did you end up paying for those? Craigslist find?
                                        Got them off the Milwaukee craigslist from a guy in Pewaukee. Ended up buying them for less than the cost of a single new one so I'm really happy with that!
                                          Driver's side caliper seized up on me and got so bad I had to park the car last Thursday until the brake parts I had ordered the day prior showed up. When they arrived in the middle of the week, I was hoping to rebuild the calipers and get back on the road. I got everything apart and attempted to use the pressure of the braking system to push out the caliper but I soon realized they weren't worth rebuilding even though they looked alright on the outside:
                                          I bought a pair of calipers (remanufactered ones from WBR) and was able to get everything installed this weekend.
                                          24555529773a7e8a2e952b.jpg'
                                          I replaced the rotors, pads, calipers, pad wear sensor, upgraded the lines to UUC braided stainless ones, and flushed the system with Ate Type 200 fluid.
                                          I will note that I was a bit disappointed in UUC's lines, as the fitting that meets the hardline was too small and was able to pass through the mount on the body. I had to drill out a washer to fit snugly over the line to get it to secure in place properly.
                                          You can see the washer just underneath the white bracket in the middle.
