  3. General Technical
  4. Do you let your car warm up?
33 Posts 18 Posters 0 Views 1 Watching
  • jockhater2J
    jockhater2J
    jockhater2
    ClassE said:
    I warm up cars when it's 40 or below. I'd be interested to see data on oil viscosity, internal engine wear, and oil seal longevity on a freezing cold engine that's "given a second to warm up" V.S. 4-5 minutes at idle.
    I've always wondered why car manufacturers didn't build in "high idle" switches like in firetrucks as part of a "cold weather package"....
    my truck has a high idle option on the dash computer. Not sure when GM started it. But mine is a 2005 and has it. but my friends 2003 doesn't have it.
    • jockhater2J
      jockhater2J
      jockhater2
      i_love_cars said:
      Letting the car idle especially in the cold is horrible - snap already hit on it with carbon buildup. "Warming up" the engine should involve immediately driving it and keeping the rpms in check. This way all components of the car properly heat up. Another way to think about it is ok, so you let your car idle to warm up (which by the way letting an N54/N55 BMW idle to get the oil gauge up to temp will take like 30 minutes), but let's just say you do let it idle to warm up. At that point, you go to drive and everything else important that's mechanical is still cold as fuck like, let's say your CLUTCH. People who warm up their cars like that and then drive like normal are 100% doing long-term damage to their car, reducing the life expectancy of parts.
      High rpms when the engine is cold is indeed a bad idea. Good way to crack a block. I've seen it happen. The internals of an engine are made of metal and alloys, which contract and expand with cold/heat. Also, in a BMW, oil is used as a cooling mechanism which is why so many of them require 7-8 quarts of the stuff. Same concept as what Porsche does. The oil temperature should be at regular levels before putting undue stress on the engine (high rpms) when it cannot cool effectively.
      Bottom line is, I immediately start driving when I start my car and do not go above 3k rpm until the oil temp is good.
      If only more people understood this.
      • ClassEC
        ClassEC
        ClassE
        I also work 1/8 mile from the freeway on-ramp... So without a warmup idle, I'm going from frozen to 75mph cruising in about 30 seconds.
          rampelsauce said:
          Blah Blah Blah, I add no relevant info
          My auto tranny  blah blah blah
          Fixed
            I'm in the same boat with frozen to highway
            • Bobdudeman1988B
              Bobdudeman1988B
              Bobdudeman1988
              nice thing with the n52/54/55..er..basically any new bmw  is the electric water pump/thermostat . it starts blowing heat very quickly because it keeps the pump off or on very low till the coolant warms up.. and even when its cold the factory tune limits boost to somewhere around 5 psi till oil is 120f
              i let mine run for like a minute when its super cold. otherwise i start driving
                REKIII said:
                Fixed
                This hurt my heart.
                16993043-image-of-an-old-man-having-a-ch
                • i_love_carsI
                  i_love_carsI
                  i_love_cars
                  "nice" is relative to context - being there is 0 indication that your water pump is about to fail because it's electronic instead of mechanical. So then you get to be like me and one day pull into work only to have your orange water temp light come on and 2 seconds later go red and piss water all over the ground  :lol:
                  ahah...ha....ahhhhhhh fuck my life.
                  2007 Z4MR
                  2003 E39 M5
                  2002 E46 M3
                  2021 X5 40i
                  • Bobdudeman1988B
                    Bobdudeman1988B
                    Bobdudeman1988
                    You could always run a bleed cycle and listen to it once on a while, and i hate the cost, but ive had a mechanical pump fail on a 1.8t vw suddenly without a warning, and it cost the entire valve train when it spat the t belt. Can we complain too much..? Lol
                      Remeber too that the oil pump speed is propotional to engine speed. Oil doesn't compress, so the flow volume should be roughly proportional to rpm. My gut feeling is that an engine spinning 4000rpm doesn't require 4x the oil flow of one that's spinning 1000rpm. The pump is likely sized to provide barely adaquate flow at idle so that there's not exsessive losses and heat generated at higher rpms.
                        fwiw, my owners manual says NOT to let the car warm up by idling it...
                          i generally follow the mantra somewhere else also mentioned: easy 'warm up' rpms until the car is up to temp, and in the winter i start the car and let it idle while I clear windows of snow and ice.
                          • 6670charger6
                            6670charger6
                            6670charger
                            I seem to have the best luck if I just start it and drive. Seems like if I let it mine idle for any length of time on a cold start up, I end up with junk in my ICV and the car starts running like crap. If I just start and go I don't seem to have too many problems. I live in town, so I don't end up going much over 30mph for the first 5 minutes or so anyway.
                            Appleton, WI
