<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Do you let your car warm up?]]></title><description><![CDATA[<p dir="auto">Do you let your car warm up?</p>
<p dir="auto">I have heard of a couple extreme cases where a guy made his wife walk to work in the winter a few blocks away because not letting it warm up was bad for the engine.</p>
<p dir="auto">I have also heard of a guy that wouldnt even think about flogging the car until he felt that even the diff oil was up to temperature.  </p>
<p dir="auto">What do you say?</p>
]]></description><link>https://wibimmers.com/topic/3469/do-you-let-your-car-warm-up</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:45:23 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3469.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Jan 2015 01:11:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Do you let your car warm up? on Sat, 07 Feb 2015 21:18:11 GMT]]></title><description><![CDATA[<p dir="auto">I seem to have the best luck if I just start it and drive. Seems like if I let it mine idle for any length of time on a cold start up, I end up with junk in my ICV and the car starts running like crap. If I just start and go I don't seem to have too many problems. I live in town, so I don't end up going much over 30mph for the first 5 minutes or so anyway.</p>
]]></description><link>https://wibimmers.com/post/53876</link><guid isPermaLink="true">https://wibimmers.com/post/53876</guid><dc:creator><![CDATA[6670charger]]></dc:creator><pubDate>Sat, 07 Feb 2015 21:18:11 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Fri, 30 Jan 2015 18:15:13 GMT]]></title><description><![CDATA[<p dir="auto">i generally follow the mantra somewhere else also mentioned: easy 'warm up' rpms until the car is up to temp, and in the winter i start the car and let it idle while I clear windows of snow and ice.</p>
]]></description><link>https://wibimmers.com/post/53563</link><guid isPermaLink="true">https://wibimmers.com/post/53563</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Fri, 30 Jan 2015 18:15:13 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Fri, 30 Jan 2015 01:26:40 GMT]]></title><description><![CDATA[<p dir="auto">fwiw, my owners manual says NOT to let the car warm up by idling it...</p>
]]></description><link>https://wibimmers.com/post/53525</link><guid isPermaLink="true">https://wibimmers.com/post/53525</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Fri, 30 Jan 2015 01:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Fri, 30 Jan 2015 01:25:20 GMT]]></title><description><![CDATA[<p dir="auto">Remeber too that the oil pump speed is propotional to engine speed. Oil doesn't compress, so the flow volume should be roughly proportional to rpm. My gut feeling is that an engine spinning 4000rpm doesn't require 4x the oil flow of one that's spinning 1000rpm. The pump is likely sized to provide barely adaquate flow at idle so that there's not exsessive losses and heat generated at higher rpms.</p>
]]></description><link>https://wibimmers.com/post/53524</link><guid isPermaLink="true">https://wibimmers.com/post/53524</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Fri, 30 Jan 2015 01:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Thu, 29 Jan 2015 18:25:11 GMT]]></title><description><![CDATA[<p dir="auto">You could always run a bleed cycle and listen to it once on a while, and i hate the cost, but ive had a mechanical pump fail on a 1.8t vw suddenly without a warning, and it cost the entire valve train when it spat the t belt. Can we complain too much..? Lol</p>
]]></description><link>https://wibimmers.com/post/53475</link><guid isPermaLink="true">https://wibimmers.com/post/53475</guid><dc:creator><![CDATA[Bobdudeman1988]]></dc:creator><pubDate>Thu, 29 Jan 2015 18:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Thu, 29 Jan 2015 17:33:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/53451">Bobdudeman1988 said:</a></strong></p>
<p dir="auto">nice thing with the n52/54/55..er..basically any new bmw  is the electric water pump/thermostat . it starts blowing heat very quickly because it keeps the pump off or on very low till the coolant warms up.. and even when its cold the factory tune limits boost to somewhere around 5 psi till oil is 120f</p>
<p dir="auto">i let mine run for like a minute when its super cold. otherwise i start driving</p>
<p dir="auto">"nice" is relative to context - being there is 0 indication that your water pump is about to fail because it's electronic instead of mechanical. So then you get to be like me and one day pull into work only to have your orange water temp light come on and 2 seconds later go red and piss water all over the ground  <img src="/assets/uploads/files/emoticons_default_laugh.png" alt=":lol:" class=" img-fluid img-markdown" width="20" height="20" />  </p>
<p dir="auto">ahah...ha....ahhhhhhh fuck my life.</p>
]]></description><link>https://wibimmers.com/post/53466</link><guid isPermaLink="true">https://wibimmers.com/post/53466</guid><dc:creator><![CDATA[i_love_cars]]></dc:creator><pubDate>Thu, 29 Jan 2015 17:33:33 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Thu, 29 Jan 2015 15:28:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/53416">REKIII said:</a></strong></p>
<p dir="auto">Fixed</p>
<p dir="auto">This hurt my heart.</p>
<p dir="auto"><img src="http://previews.123rf.com/images/kozzi/kozzi1212/kozzi121202792/16993043-image-of-an-old-man-having-a-chest-pain-against-white-background.jpg" alt="16993043-image-of-an-old-man-having-a-ch" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/53457</link><guid isPermaLink="true">https://wibimmers.com/post/53457</guid><dc:creator><![CDATA[rampelsauce]]></dc:creator><pubDate>Thu, 29 Jan 2015 15:28:30 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Thu, 29 Jan 2015 14:48:54 GMT]]></title><description><![CDATA[<p dir="auto">nice thing with the n52/54/55..er..basically any new bmw  is the electric water pump/thermostat . it starts blowing heat very quickly because it keeps the pump off or on very low till the coolant warms up.. and even when its cold the factory tune limits boost to somewhere around 5 psi till oil is 120f</p>
]]></description><link>https://wibimmers.com/post/53451</link><guid isPermaLink="true">https://wibimmers.com/post/53451</guid><dc:creator><![CDATA[Bobdudeman1988]]></dc:creator><pubDate>Thu, 29 Jan 2015 14:48:54 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Thu, 29 Jan 2015 01:34:29 GMT]]></title><description><![CDATA[<p dir="auto">I'm in the same boat with frozen to highway</p>
]]></description><link>https://wibimmers.com/post/53419</link><guid isPermaLink="true">https://wibimmers.com/post/53419</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 29 Jan 2015 01:34:29 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Thu, 29 Jan 2015 00:40:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/53379">rampelsauce said:</a></strong></p>
<p dir="auto">Blah Blah Blah, I add no relevant info</p>
<p dir="auto">My auto tranny  blah blah blah</p>
]]></description><link>https://wibimmers.com/post/53416</link><guid isPermaLink="true">https://wibimmers.com/post/53416</guid><dc:creator><![CDATA[REKIII]]></dc:creator><pubDate>Thu, 29 Jan 2015 00:40:43 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 23:54:26 GMT]]></title><description><![CDATA[<p dir="auto">I also work 1/8 mile from the freeway on-ramp... So without a warmup idle, I'm going from frozen to 75mph cruising in about 30 seconds.</p>
]]></description><link>https://wibimmers.com/post/53412</link><guid isPermaLink="true">https://wibimmers.com/post/53412</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Wed, 28 Jan 2015 23:54:26 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 22:34:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/53372">i_love_cars said:</a></strong></p>
<p dir="auto">Letting the car idle especially in the cold is horrible - snap already hit on it with carbon buildup. "Warming up" the engine should involve immediately driving it and keeping the rpms in check. This way all components of the car properly heat up. Another way to think about it is ok, so you let your car idle to warm up (which by the way letting an N54/N55 BMW idle to get the oil gauge up to temp will take like 30 minutes), but let's just say you do let it idle to warm up. At that point, you go to drive and everything else important that's mechanical is still cold as fuck like, let's say your CLUTCH. People who warm up their cars like that and then drive like normal are 100% doing long-term damage to their car, reducing the life expectancy of parts. </p>
<p dir="auto">High rpms when the engine is cold is indeed a bad idea. Good way to crack a block. I've seen it happen. The internals of an engine are made of metal and alloys, which contract and expand with cold/heat. Also, in a BMW, oil is used as a cooling mechanism which is why so many of them require 7-8 quarts of the stuff. Same concept as what Porsche does. The oil temperature should be at regular levels before putting undue stress on the engine (high rpms) when it cannot cool effectively. </p>
<p dir="auto">Bottom line is, I immediately start driving when I start my car and do not go above 3k rpm until the oil temp is good. </p>
<p dir="auto">If only more people understood this.</p>
]]></description><link>https://wibimmers.com/post/53409</link><guid isPermaLink="true">https://wibimmers.com/post/53409</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Wed, 28 Jan 2015 22:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 22:31:22 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/53389">ClassE said:</a></strong></p>
<p dir="auto">I warm up cars when it's 40 or below. I'd be interested to see data on oil viscosity, internal engine wear, and oil seal longevity on a freezing cold engine that's "given a second to warm up" V.S. 4-5 minutes at idle.</p>
<p dir="auto">I've always wondered why car manufacturers didn't build in "high idle" switches like in firetrucks as part of a "cold weather package"....</p>
<p dir="auto">my truck has a high idle option on the dash computer. Not sure when GM started it. But mine is a 2005 and has it. but my friends 2003 doesn't have it.</p>
]]></description><link>https://wibimmers.com/post/53408</link><guid isPermaLink="true">https://wibimmers.com/post/53408</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Wed, 28 Jan 2015 22:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 22:29:12 GMT]]></title><description><![CDATA[<p dir="auto">All the options were HILARIOUS.</p>
<p dir="auto">My motorcycle has a cold start. Once the cold start is done then I drive it gently for the first 5 minutes before giving her the beans.</p>
<p dir="auto">The truck. Well diesels don't run well cold. So it idles for 5-10 minutes and I also drive it gently usually takes 15 minutes of driving before I feel comfortable putting the hammer down. Reaching half temp takes being on the freeway for about 15 minutes after it's already gone through the previous mentions.</p>
<p dir="auto">The BMW. I just give a few minutes and drive it easy until the engine warms up.</p>
<p dir="auto">Best way to warm up a engine is under light load driving. I really only do the excessive idling in winter. I'm looking to get a remote start for the truck.</p>
]]></description><link>https://wibimmers.com/post/53407</link><guid isPermaLink="true">https://wibimmers.com/post/53407</guid><dc:creator><![CDATA[jockhater2]]></dc:creator><pubDate>Wed, 28 Jan 2015 22:29:12 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 19:46:46 GMT]]></title><description><![CDATA[<p dir="auto">I voted: not usually unless icicles are forming on my balls.....</p>
<p dir="auto">But, I was really torn, because when I do let my car warm up, I listen to T-swift to get amped up for the drive.</p>
<p dir="auto">Snap, you officially made this one of the hardest voting decisions in my life.</p>
]]></description><link>https://wibimmers.com/post/53395</link><guid isPermaLink="true">https://wibimmers.com/post/53395</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Wed, 28 Jan 2015 19:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 19:05:29 GMT]]></title><description><![CDATA[<p dir="auto">I warm up cars when it's 40 or below. I'd be interested to see data on oil viscosity, internal engine wear, and oil seal longevity on a freezing cold engine that's "given a second to warm up" V.S. 4-5 minutes at idle.</p>
]]></description><link>https://wibimmers.com/post/53389</link><guid isPermaLink="true">https://wibimmers.com/post/53389</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Wed, 28 Jan 2015 19:05:29 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 17:52:57 GMT]]></title><description><![CDATA[<p dir="auto">Ok. Well i warm mine up so its warm inside. And right now the 335 is in storage. I do start it about every two weeks and let the oil come up to temp and cycle through the motor. I can't see letting it lie doormant untill spring being good either.</p>
]]></description><link>https://wibimmers.com/post/53383</link><guid isPermaLink="true">https://wibimmers.com/post/53383</guid><dc:creator><![CDATA[michael1972]]></dc:creator><pubDate>Wed, 28 Jan 2015 17:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 16:51:36 GMT]]></title><description><![CDATA[<p dir="auto">3k is also my imaginary cold rev limit, I could set it to physically do that with ms2 though.</p>
<p dir="auto">And yes, ive noticed that the n54 takes for freaking ever to get the oil up to temperature. i believe the factory tune limits timing and boost until the oil is up to temp</p>
]]></description><link>https://wibimmers.com/post/53380</link><guid isPermaLink="true">https://wibimmers.com/post/53380</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 28 Jan 2015 16:51:36 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 16:50:09 GMT]]></title><description><![CDATA[<p dir="auto">I warm my car up when its cold.  Otherwise, any other time of year, I let my car drop idle (30 sec-1 minute, or however much time it takes me to grab what I've forgotten) and then I'm away. </p>
<p dir="auto">My auto tranny doesn't like the cold.  He/she hesitates till it's good and warm.  It could probably use a fluid/filter change.</p>
]]></description><link>https://wibimmers.com/post/53379</link><guid isPermaLink="true">https://wibimmers.com/post/53379</guid><dc:creator><![CDATA[rampelsauce]]></dc:creator><pubDate>Wed, 28 Jan 2015 16:50:09 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 14:36:16 GMT]]></title><description><![CDATA[<p dir="auto">^You're not alone</p>
]]></description><link>https://wibimmers.com/post/53375</link><guid isPermaLink="true">https://wibimmers.com/post/53375</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 28 Jan 2015 14:36:16 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 13:55:47 GMT]]></title><description><![CDATA[<p dir="auto">why am i the only one who voted Taylor swift. wtf</p>
]]></description><link>https://wibimmers.com/post/53373</link><guid isPermaLink="true">https://wibimmers.com/post/53373</guid><dc:creator><![CDATA[i_love_cars]]></dc:creator><pubDate>Wed, 28 Jan 2015 13:55:47 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 13:52:09 GMT]]></title><description><![CDATA[<p dir="auto">Letting the car idle especially in the cold is horrible - snap already hit on it with carbon buildup. "Warming up" the engine should involve immediately driving it and keeping the rpms in check. This way all components of the car properly heat up. Another way to think about it is ok, so you let your car idle to warm up (which by the way letting an N54/N55 BMW idle to get the oil gauge up to temp will take like 30 minutes), but let's just say you do let it idle to warm up. At that point, you go to drive and everything else important that's mechanical is still cold as fuck like, let's say your CLUTCH. People who warm up their cars like that and then drive like normal are 100% doing long-term damage to their car, reducing the life expectancy of parts. </p>
<p dir="auto">Bottom line is, I immediately start driving when I start my car and do not go above 3k rpm until the oil temp is good.</p>
]]></description><link>https://wibimmers.com/post/53372</link><guid isPermaLink="true">https://wibimmers.com/post/53372</guid><dc:creator><![CDATA[i_love_cars]]></dc:creator><pubDate>Wed, 28 Jan 2015 13:52:09 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 13:16:41 GMT]]></title><description><![CDATA[<p dir="auto">I dont warm it up for the engine, I warm up the car so the cabin is toasty.</p>
]]></description><link>https://wibimmers.com/post/53368</link><guid isPermaLink="true">https://wibimmers.com/post/53368</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Wed, 28 Jan 2015 13:16:41 GMT</pubDate></item><item><title><![CDATA[Reply to Do you let your car warm up? on Wed, 28 Jan 2015 12:46:45 GMT]]></title><description><![CDATA[<p dir="auto">My truck has to warm up for a few minutes, it also has a carburetor with a manual choke.  It needs a little time for the exhaust manifold to warm the intake manifold to aid atomization from the 1950s carb design.  The nice thing is when started with full choke from cold it idles around 1000 rpm, you can hear it roaring from inside the house when it gets warm enough because the idle rises to around 1500 and the fan clutch is stuck so it sounds like a tornado is in the driveway, this signals go time.</p>
]]></description><link>https://wibimmers.com/post/53365</link><guid isPermaLink="true">https://wibimmers.com/post/53365</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 28 Jan 2015 12:46:45 GMT</pubDate></item></channel></rss>
