    yeah i wasnt suggesting buying them, just finding an example of all brown door cards to see how it looks.
      Seats are complete!!
        Youve done well!
          Looks great!
            Thanks guys!!
            Carpet set with rear seat delete ordered.
            • i_love_carsI
              i_love_carsI
              i_love_cars
              this is a skillset way beyond my wheelhouse. I feel dumb.
              Seats look pretty good IMO.
              2007 Z4MR
              2003 E39 M5
              2002 E46 M3
              2021 X5 40i
                Got my poly e30 diff bushing in the mail from garagistics. Yellow to match the other yellow bushings already on my car.
                  Even your bushing color matches. #earlmode
                    He's an inspiration!!!
                      Just ordered a central locking door lock kit for the beast
                        carpet set is done and on its way!!!! 😁😁😁😁😁😁😁😁😁😁😁😁😁😁😁
                          Getting the central locking system working along with redoing all the cylinders on my e30 is in the top 3 of fixes I've done to it.
                          You're kicking ass! Keep it rolling!!
                            Central locking kit should be here today.
                            Got the rear percel shelf and rear seat belts removed. Also started laying down the carpet underlayment/soundproofing/heatproofing in prep for the new carpet set.
                            exhaust is rubbing on the e30 driveshaft a tad, so in process of putting a new exhaust hanger on to move it slightly. Then just need new muffler hangers for that.
                            Started laying out where the aerocatch hood latches will be installed as well as reinforcing the fiberglass hood. Hood is pretty flimsy and flexes a lot. I want to stiffen it up a bit without adding too much weight.
                            Had the car idling this weekend and found oil leaking at turbo. Seems that the bolts holding the center section to the turbine housing loosened up. Tightened the ones I could reach easily and trying to figure out how to tighten the last bolt that is a bugger to get to.
                              Carpet set came today!!!
                              Taking the advice from the headliner adhesive thread and will most likely grab some 3M 90 adhesive spray when installing these. Gotta wait for a hot, sunny day so that I can leave the carpet out in the sun to soften up while installing. I'm excited!!!
                                maybe i missed it, whats the deal with the carpet set? does the e21 not have a single floor pan piece or do you have to connect these together somehow? your talking about glue, do they get glued to the sheet metal?
                                  I believe these get glued right to the sheet metal. Maybe his came in pieces for sale of delivery?
                                  Mine came as a whole and was rolled up. Had to pop it into shape and leave it on the heat for a bit
                                    Not too many companies make the molded carpet sets. They are pricey to ship and a bitch to install. A BF member named Esty makes these pieces carpet sets for E21s and 2002s out of OEM style carpet. Better quality and easier install. And yes, they get glued directly to sheet metal. Or, like I'm doing is placing a foil backed soundproof/heat proofing padding down first and gluing the carpet to that.
                                      Got the exhaust rubbing fixed as well as the Muffler rehung. I then finished applying the sound/heat proofing padding before the carpet goes in.
                                      After that, I took the door panels off and was surprised to see power door actuators already installed. The wires were cut, so they were inoperable. I removed the old ones and installed the new ones in their place. Wired it up and tested them. Seems to have issues unlocking once locked. I kept the old arm pieces that connect to door lock pins, so I'm assuming something with that is binding. Who knows! Which may explain why previous owner disconnected the actuators in first place.
                                        Interior looks great! Vast improvement from its previous state
                                          Thanks!
                                          Well the keyless door locks work great now. Took out the push rods that the previous owner put in and used the new ones from my kit. Routed them better for my setup and now they lock and unlock great. I'd like to figure something out for the trunk with one of the spare actuators, bit not sure how I'd do it. Just an idea.
