    This weekend I finished cutting, grinding and welding in the passenger seat mounts. I also finished the seam seal on the passenger side floor pan patch as well.
    Continuing, I painted the entire passenger side floor with kbs rustseal.
    Next will be undercoating the new floor patches, cleaning up the rear seat area, treating and painting it with kbs. Then I will come back with my spray gun and put a second coat of kbs on the entire interior.
    I also ripped all the foam off the fiberglass hood and test fitted it. Fits well for being way thinner than the stock hood. Obviously not show car fitment, but I'm happy. I'm leaning towards using 4 aerocatch hood latches to secure it down.
      What temp is your garage?
        No idea. I use a turbo heater. If I have it on high I can work in a tshirt out there.
          Just curious about the kbs drying time when it's cooler (I can get the garage to like 45ish)
            It would dry fine at 45ish no problem tho.
              Sweet! Now I have no excuse
                I've even helped it out at cooler temps with a box fan and its cured fine. Pretty much all in the prep like any paint job
                  Got my rear strut brace back from Rampelsauce tonight too. Looks great! Thanks again!
                      0mKXcg1.gif?noredirect
                        This weekend I got the underside of the floor patches sprayed with underbody coating, so that's officially done. The back seat area was also cleaned up, treated and painted with kbs rustseal paint to complete the first coat of entire interior.
                        Next will be grabbing one more pint of KBS and spraying the final coat on interior with my hvlp gun.
                        Lastly I got the exterior bump trim off the car so the flares will have a flat area to bolt up against.
                          Got the output seals and snap rings changed out on the new diff which was way easier than I thought. Scrap pieces of charge piping made it super simple to press out old and press in new seals.
                          I also thinned up some kbs and sprayed final coat of the entire interior and trunk of my car with my hvlp gun.
                          Word to the wise, don't let your air hose get to close to your torpedo heater. Scared the crap out of me when it popped.
                          Luckily I live so close to harbor freight I was able to grab a new air hose and get back in time before the paint left in the hvlp gun started drying.
                          I also drilled holes in my rear brace/battery holder and prepped it for install. Tomorrow I will get the rivnuts installed in the strut towers and bolt it in place.
                          (my dog photo bombed me with her bone)
                            Smoked ellipsoids in progress
                              I ended up cleaning all the old sealant off, clear coating the glass lenses, painting the inner reflector black and reassembling with new sealant.
                                awesome. was that the first set you've done?  i broke so many lenses when i was converting those.
                                  Yeah this is the first set I've done. They are actually the ones I bought from you a few years ago. [emoji106]
                                    So I got the ellipsoids all sealed up with newly painted trim rings and adjusters installed.
                                    Next thing was deciding what to do with the empty high beam holes. Can't install the lights since the intercooler charge piping goes through it. I decided to take some chicken wire I had laying around and making mesh inserts with the high beam trim rings.
                                    Paint them black and they are good to go.
                                    Then came the scary part for me. What did I get myself into?!?!?!
                                    Following a tutorial on r3v, I disassembled the passenger e30 sport seat first to see how hard it was. Wasn't THAT hard, but still a lot of little things to get wrong. I cleaned up all the vinyl with some prep cleaner and tested the vinyl dye in an inconspicuous spot. I chose a Walnut brown as tribute to my old e21 seats. First test coat is light, but it will darken up with every extra cost applied. I think it's gonna look great!
                                    To be continued.....
                                      Are you just using a spray on die?
                                        I am using a professional leather/vinyl dye called rub-n-restore (giggity).
                                        http://www.rubnrestore.com
                                          After some trial and error on the passenger seat, here is what 4 coats looks like.
                                          After 3 coats it still had streaks from the cellulose sponge they say to use, so I blotted a 4th coat on. This helped a lot! There are still a few spots that need touchup but overall way better than wiping it on. I will remember that for when I do the driver seat. What a difference!
