  4. Musings from the shop
fukinitupagianftwlikeabossifitaintbrokefi
136 Posts 22 Posters 2.6k Views 1 Watching
    Are you really gonna use it with one bore being .0025 off? That's a whole lot.
      I doubt it=/ Sorry to hear bud. Maybe they really hate m42's like everyone else besides you and I
        That sucks.
        • i_love_carsI
          i_love_carsI
          i_love_cars
          I don't know the specifics of this particular bmw block in terms of the outer limits of boring out, but I personally would not be comfortable with a difference like that. Engine building is a precision exercise, plain and simple. You need a shop that's gonna measure and check to a tee. Anything less is risking premature engine failure. If you use what you have, you're going to have to re-calculate your expected compression from the bigger bore on one cylinder and build around that (depending on your performance plans), and higher risk of cylinder wall failure depending on the tolerances of the block (again, I'm not aware of the specifics on your motor). But these are generally things I would be worried about. If one cylinder isn't to proper spec for the JE pistons you're using, the larger bore is going to be a higher risk for blowby and premature wear on your ring and bearing in that cylinder.
          i dunno. I just don't like there to be anything inconclusive about my block before I put it back together.
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
            2.5 thousandths is not acceptable. The tolerance span for piston to wall clearance is less than one. I think the Target clearance spec for the pistons I used was .0018. They better be paying for both blocks...
            Sent from my potato phone
              I agree that it's far from ideal, but I want to actually drive the car this summer. Specifically I have a vacation planned for mid July, so I'm in a hurry to get it done. I'm also renting shop space, so every month that the car sits there is more money out the window. Worn out cylinders can easily have .005" of wear, sometimes substantially more, so basically I'm starting my rebuild with one bore that's half worn out. It suck, but given the circumstances, I'm just going to deal with it. As long as the pistons don't get wrecked I can get a new block and do it right next year.
                As advice from someone who's been there, do it right the first time. Once you get the car together you won't wanna take it apart and throwing it together is gonna risk things breaking like my car ultimately putting you back where you started or further behind.
                  ^ditto
                    I mean seriously how hard is it to find a competent machine shop with relatively quick turn around time? I know of a few local, but I'm sure there are some close to you.
                      Okay, so I left some details out of the story. I've been planning on "someday" taking the car out west on an extended vacation. See the sights, drive some cool mountain roads, and use the free time and the open spaces to gain some perspective on things.
                      I recently put in my notice and am quitting my current job, however I haven't found a new job yet. I haven't been too worried about it because I have enough money saved up to keep my bills paid for a couple of months, so...... I made plans to visit a friend of mine in Denver for a week or two in mid-July. Basically, with no income, the sooner I get on the road, the longer I can stay on the road before I have to come back and find a job. Getting an engine, dismantling it, and waiting around hoping that a shop will turn my block around quickly aren't very high on my list of things I want to do right now. The opportunity for me to do this is here right now, and I'm not going to let a couple thousands of extra bore get in the way. :)
                        Honestly at that point I would buy a clean stock m42 and pop it in there quick. couldn't imagine it being expensive. certainly less than ruining a set of forged pistons.
                          I was thinking the same, find a temporary motor that eventually can be used for parts too.
                            honestly though M42's arent very sought after. I couldn't imagine it being more than a few hundred bucks for a clean one.
                              And me!
                                Sucks that you seem to have gotten the short end of the stick in this situation. I've been to Automotive Supply for things before and have never been impressed. After reading this, I'll make sure that no one I know will ever go there. Not acceptable. I don't think you should have needed to pay for any of that work. If anything, it seems like they should owe you.
                                I understand your unique situation and I'd just go with whatever feels best. Sounds like you've already made up your mind and I'd roll with it. Rebuild it later (if needed) when you don't have the opportunities that you do now.
                                  Haven't been on the forum much lately, but I'm finally making some progress, despite appearances:
                                    Motor is in, so all that's left to do is... pretty much everything. Looks good in there though.
                                      I like this:
                                        Looks great!
                                          Nice!!!!!!
                                          Mine made it from the engine stand to the hoist. And then to the floor
