  4. Musings from the shop
fukinitupagianftwlikeabossifitaintbrokefi
136 Posts 22 Posters 2.6k Views 1 Watching
    This thing is rad as phuck.
    Mike's swap by Jake Spence Photography, on Flickr
      Nice!
      I've been in a bit of a lull lately. Took me a few tries to get the center support bearing mounts for the e30 driveshaft done right. I finally got my pistons and dropped them off at the machine shop. Hopefully I'll have the block back by next weekend. It's been a long time since I made any visible progress, so I decided to put the front suspension back together and put the car back on the ground.
      I wheeled it outside and rinsed a couple months worth of accumulated dust off of it and now I'm totally stoked about getting it back on the road again. Spent a few hours today scrubbing down the engine bay. Will probably put some paint on it this week.
      This is what I like to see. A small forest of unused jackstands!
          Wasn't expecting that! I like it, leftover paint from Ben?
            Ben's blood.
              Keepin it real.
              Spray bomb for life.
                Gloss Mother F****** Red and Gloss Mother F****** Flint Gray Metallic makes for one Hip Mother F*****
                  Surprise mother f*****
                    Okay, so here's my engine rebuild timeline so far...
                    March 3 - Ordered JE pistons through Top End Performance. Estimated 3-week lead time.
                    April 15 - Received pistons.
                    April 16 - Dropped pistons and block off at Automotive Supply to have the block bored. Was informed that they had gotten busy so it might take a week or two for them to get it done.
                    May 5 - Voicemail from Automotive Supply asking me to call them back.
                    May 6 - There was a problem with the tooling (or something...) and my block is wrecked. Agreed to sell them the other block that I had. Dropped 2nd block off the same day.
                    June 3 - Received voicemail that my block is done.
                    June 4 - Picked up block. Hone job looked like shit. Put a ring in each bore to measure the ring-gap and 3 of the bores were tapered. The tops of three bores were ~.002" undersized, but the middle was the correct size. The forth bore was .002" undersized with no taper.
                    June 5 - Brought block back to Automotive Supply. Jason, the "machinist" was off so I'd have to wait until Monday to talk to him.
                    June 8 - Stopped at Automotive supply to find out what he was planning to do with my block. He hadn't looked at it yet, but said he'd look at it and call me later that day.
                    June 10 - Having heard nothing I went back to find out what was going on. They said it was done and gave me my block back. The bores are a fuzz larger and no longer tapered, but one bore is ~.0025" larger than the other three.
                    TLDR: It took Automotive Supply 2 months to bore a block, they destroyed one of my blocks in the process, and they did a shitty job. Not recommended.
                    First time I got it back. Aside from the "crosshatch" there was a lot of horizontal marks. That combined with the taper makes me think that they probably didn't bore it at all, but just hogged it out with a hone. Vertical lines are from the bore gauge.
                    It looks a little better now, but still not good.
                      Are you really gonna use it with one bore being .0025 off? That's a whole lot.
                        I doubt it=/ Sorry to hear bud. Maybe they really hate m42's like everyone else besides you and I
                          That sucks.
                          • i_love_carsI
                            i_love_carsI
                            i_love_cars
                            I don't know the specifics of this particular bmw block in terms of the outer limits of boring out, but I personally would not be comfortable with a difference like that. Engine building is a precision exercise, plain and simple. You need a shop that's gonna measure and check to a tee. Anything less is risking premature engine failure. If you use what you have, you're going to have to re-calculate your expected compression from the bigger bore on one cylinder and build around that (depending on your performance plans), and higher risk of cylinder wall failure depending on the tolerances of the block (again, I'm not aware of the specifics on your motor). But these are generally things I would be worried about. If one cylinder isn't to proper spec for the JE pistons you're using, the larger bore is going to be a higher risk for blowby and premature wear on your ring and bearing in that cylinder.
                            i dunno. I just don't like there to be anything inconclusive about my block before I put it back together.
                            2007 Z4MR
                            2003 E39 M5
                            2002 E46 M3
                            2021 X5 40i
                              2.5 thousandths is not acceptable. The tolerance span for piston to wall clearance is less than one. I think the Target clearance spec for the pistons I used was .0018. They better be paying for both blocks...
                              Sent from my potato phone
                                I agree that it's far from ideal, but I want to actually drive the car this summer. Specifically I have a vacation planned for mid July, so I'm in a hurry to get it done. I'm also renting shop space, so every month that the car sits there is more money out the window. Worn out cylinders can easily have .005" of wear, sometimes substantially more, so basically I'm starting my rebuild with one bore that's half worn out. It suck, but given the circumstances, I'm just going to deal with it. As long as the pistons don't get wrecked I can get a new block and do it right next year.
                                  As advice from someone who's been there, do it right the first time. Once you get the car together you won't wanna take it apart and throwing it together is gonna risk things breaking like my car ultimately putting you back where you started or further behind.
                                    ^ditto
                                      I mean seriously how hard is it to find a competent machine shop with relatively quick turn around time? I know of a few local, but I'm sure there are some close to you.
                                        Okay, so I left some details out of the story. I've been planning on "someday" taking the car out west on an extended vacation. See the sights, drive some cool mountain roads, and use the free time and the open spaces to gain some perspective on things.
                                        I recently put in my notice and am quitting my current job, however I haven't found a new job yet. I haven't been too worried about it because I have enough money saved up to keep my bills paid for a couple of months, so...... I made plans to visit a friend of mine in Denver for a week or two in mid-July. Basically, with no income, the sooner I get on the road, the longer I can stay on the road before I have to come back and find a job. Getting an engine, dismantling it, and waiting around hoping that a shop will turn my block around quickly aren't very high on my list of things I want to do right now. The opportunity for me to do this is here right now, and I'm not going to let a couple thousands of extra bore get in the way. :)
                                          Honestly at that point I would buy a clean stock m42 and pop it in there quick. couldn't imagine it being expensive. certainly less than ruining a set of forged pistons.
