  3. Services Offered/Wanted
  4. Im walnut blasting valves on n54 and n55 in central wi!
68 Posts 20 Posters 1.5k Views 3 Watching
  • Bobdudeman1988B
    Bobdudeman1988B
    Bobdudeman1988
    Thanks guys :)
    • GB-335xiCoupeG
      GB-335xiCoupeG
      GB-335xiCoupe
      Bobdudeman1988 said:
      New here but long time bmw owner, im offering to blast and clean n54 and n55 valves for 180 !
      Pm me for details
      Im located in N. Fond du lac wi
      And i do this out of my garage at home
      Bob, I'm in Fdl a lot, covering 1/3 of WI as my territory. Definitely interested in having you walnut blast my N55. I sent you a PM on N54tech, but I heard something happened. How long does this blast process take, start-to-finish? Would you have time this Wednesday, Thursday or Friday?
      • Bobdudeman1988B
        Bobdudeman1988B
        Bobdudeman1988
        I replied back on n54 tech and nothing happened, just busy :) i did get banned on e90 post for this ad tho lol
        • Bobdudeman1988B
          Bobdudeman1988B
          Bobdudeman1988
          just added that if you bring the gasket(s) for your oil filer housing i can swap them out for 30 bucks while where in there!
          pm me for parts needed if you dont know. but oil cooler modles have an extra gasket for the t stat housing for the cooler.
           and you need the little oring for the water pipe as well. then the base gasket. i dont keep the parts here but if you need . i can order them for you and you can pay for them with the job :)
          gasket for housing pn below(same gasket for non oil cooled and oil cooled models). number 4 on diagram
          11427537293
          gasket for oil t-stat housing(oil cooled models only). number 5 on diagram
          11427525335
          post-3533-0-86981000-1415111629thumb.pn
          oring for water pipe. number 8 on diagram
          11537545278
          post-3533-0-12359300-1415111671thumb.pn
            So I went and saw Bob today and all I have to say is... AWESOME!
            Bob is a genuinely nice guy who just happens to know his shit about the n54/n55.  His garage was clean and organized and from the minute you step in there he makes you feel right at home.  The set up for the walnut blasting never made me question the authenticity of the service.  He was meticulous about perfecting the repair and almost obsessive about maintaining cleanliness while working.  I am thoroughly pleased with the finished product!  There is a noticeable difference in gears 2-3-4 and the power delivery is much smoother through the power band.
            I was in the garage during the entire service and I will that as an ASE certified technician... I APPROVE!
            Now for the pics:
            Before
            After
            • Bobdudeman1988B
              Bobdudeman1988B
              Bobdudeman1988
              There be dirty valves out there, i shall destroy the carbon tar of death! Thanks pat!
              • GB-335xiCoupeG
                GB-335xiCoupeG
                GB-335xiCoupe
                Looks like a patient on the real trauma tv show. Lol. Damn that garage is CLEAN!
                • Bobdudeman1988B
                  Bobdudeman1988B
                  Bobdudeman1988
                  U should have seen it 4 weeks ago, could barley get 1 car in there lolZ
                    Bob, I still want to get down there and do the clutch at some point. Winter project? I want to go back to BMS E85 flash as well.
                    • Bobdudeman1988B
                      Bobdudeman1988B
                      Bobdudeman1988
                      Cant see it being an issue, as far as tunning if you go back to bms your stock clutch might not slip lol. Just let me know
                      • M
                        M
                        michael1972
                        suspenceful said:
                        Yup, Bob is awesome.
                        I've gone to this guy for my E85 fuel pump install, backend flash, and other miscellaneous crap. Would've had him walnut blast my valves, but I already had it done before meeting him.
                        Cheap prices and knowledgeable, would recommend.
                        +1. Bob does great work.
                        • Bobdudeman1988B
                          Bobdudeman1988B
                          Bobdudeman1988
                          Lol my member title is "nut blaster "XD
                          • GB-335xiCoupeG
                            GB-335xiCoupeG
                            GB-335xiCoupe
                            Walnut Blasting N55 and N54 in Fond du Lac and Northeast Wisconsin, 335xi at 100k+
                            Bobdudeman and I walnut blasted my e92 (2011 335xi) this weekend. He's a real nice guy, down to earth. He doesn't charge much for this service, in my opinion, but he's really not in it for the money. $180. He has all the tools needed and the know-how on both N55 and N54 engines and doesn't mind if you help. Of course he appreciates a little extra and maybe a 12-pack of his favorite beer (Warsteiner dunkel).
                            If you do the walnut blast, I would suggest also doing the oil filter housing gasket (OFHG) replacement and the o-ring for the water hose for the extra $30. Buy the gasket and o-ring ahead of time from Amazon or ecstuning. Bob will also do transmission fluid and pan/filter change if you need it.
                            As for my N55, it had 101,000 miles on it at the time. I've seen pics of N54 intake valves that were much worse at 1/2 the mileage. So the N55 still seems to have the same gunk build-up issue, just to a lesser extent. I have some pics below. Sorry for the quality. It's not the best camera, and I'm far from a great photographer.
                            Before
                            https://flic.kr/p/q6d9ep
                            https://www.flickr.com/photos/127703...ream/lightbox/
                            During
                            https://flic.kr/p/q63ovM
                            https://flic.kr/p/pNSG3W
                            After
                            Trust me, they're clean as a whistle. Noticeably more responsive throttle. Seems to have more power, but I'm thinking it's more of a placebo effect. Later this week, I'm getting the VANOS recall done, so unfortunately I won't be able to give an accurate estimate of fuel efficiency gains. But I'm SO glad this service is done . It's good peace of mind, and I know it won't be needed for another 100k miles! At least 2 years, right, Bob?
                            Bob, if you're reading this: excellent job! Since I'm in that area regularly, I'm going to provide you fair warning that you will be seeing my car again... and maybe some beer too.
                            • Bobdudeman1988B
                              Bobdudeman1988B
                              Bobdudeman1988
                              Some more photos, :)
                              post-3533-0-28716400-1416290405thumb.jp
                              post-3533-0-67310500-1416290422thumb.jp
                              • Bobdudeman1988B
                                Bobdudeman1988B
                                Bobdudeman1988
                                In the process of obtaining parts to blast mini turbo engines as well..(n14?) So that will be a new one :), i also do other repairs cheap! Pm me for more!
                                • Bobdudeman1988B
                                  Bobdudeman1988B
                                  Bobdudeman1988
                                  gonna be blasting a vw fsi 2.0 turbo engine by Wednesday. should be interesting to fabricate a vac tube for that. BUT i got room for more ppls! let me at your valves on nastiness!
                                  • Bobdudeman1988B
                                    Bobdudeman1988B
                                    Bobdudeman1988
                                    Happy114 came down for the blast and waterpump, these where his valves 101k, nasty! But spotless now :)post-3533-0-18490700-1417632604thumb.jppost-3533-0-86063000-1417632623thumb.jp
                                    • Happy114H
                                      Happy114H
                                      Happy114
                                      It idles so much smoother now. It's so clean that you can eat off of it, but it would advise not doing that. The water pump is working flawlessly as well. I did an oil change today and it all looks good under there, and I didn't expect anything different form you. Thanks Bob.
                                      • Bobdudeman1988B
                                        Bobdudeman1988B
                                        Bobdudeman1988
                                        Glad to hear it :)
                                          It is nice to see someone helping out the community and not trying to make hand over fist in profits=)
