The E46 M3 Journal
#6 misfire keeps on popping up about every 500 miles on the check engine light. I need to do plugs next.
I got the coil from BMW so I think the boot came on it.
The exhaust system was tweaked a bit from the headers. A lot of pressure is put on that one mount so they break due to me not getting the muffler tweaked the opposite way. This is on my to do list now because the muffler is cracking to due the pressure.
Moral of the story is spend the $$$ on the Super Sprint headers from the get go.
Spark plugs replaced.
The old ones:
You had one bad coil? Trust me...replace all 6. If one goes bad...the other 5 will go soon after.
This is dumb advice. So say one control arm ball joint goes bad, your suppose to replace the other side as well? Please give me all your old parts when you do this. I'll use them when my car breaks.
I sure would replace the other side. I always do things like that in pairs
Just like if you have one bad rotor, you do both -
I have observed 4 out of 6 coils fail on a Honda J-series within a 6 month period. bigjae may have experienced something similar on his own car and is simply trying to offer helpful advice.
cool your fuggin tits.
OK. Well...I guess my 12 years of driving and maintaining E46s is telling me the wrong answer. But carrying 6 spare coils to the track has saved me a tow home twice. Just sayin'.
And when one control arm with a non replaceable ball joint goes bad...you actually are supposed to replace both sides.
Timmy gets a little opinionated sometimes. Don't mind him.
I will be replacing the #4 coil because it doesn't "snap" over the plug and sits loose. #sketch
The exhaust is getting pretty annoying. I know this won't go over well with some but I am leaning towards my exhaust guy welding a muffler up.
Needs to be done soon. I need two of me to make more time!
I will be replacing the #3 coil because it doesn't "snap" over the plug and sits loose. #sketch
I know i do...haha. Backyard mechanics annoy me sometimes. I see no problem carrying spare coils but not uaing them until one actually fails. Also #3 coil boot is probably your issue not the whole coil. But maybe you want to carry 3 sets of spares just in case.
I had Dan the Exhaust Man weld up the B&B muffler and all is quite on the Eastern Front except when thy beans are given.
Always do stuff in pairs!!! if the car is already on stands and you have the tools out... why not!?! Also if one is going bad, the other is normally not all too far behind...
The #6 misfire has been silent for about a week. But if it comes on again I have a new injector waiting to install.
Also have new coil for #4 because the current one doesn't snap onto the plug. It just sits there.
Didn't do any work on my e46 but gave my buddy's 2006 M3 some love.
Rogue Engineering Rasp Pipes.
No leaks and totally took away the tinny m3 rasp.
A couple of pics from tonight.
I have a new driver side wiper arm to install. I feel the old spring is losing its mojo.
The engine light has been off for a couple of thousand miles now. Running great! #letsseehowlongittakesforittocomeonafteripostthis
She started running a little rough yesterday. I replaced the #4 coil but no change.
There is no engine light on. I'm wondering if the fuel pressure regulator is bad. Possibly do a fuel filter.
Needs an oil change too.
Oil change documentation pic.
Why have I not thought of that before?!
I always forget, and hate stickers. I guess I could also put a post it in my glovebox...
