  • i_love_carsI
    i_love_carsI
    i_love_cars
    I guarantee you are pulling hotter IATs with this setup after a couple pulls. While the turbo itself certainly impacts temps, you are going to be starting with hotter air to begin with. All your air is now being pulled into the car from the hot side of a turbo motor and your filters are just sitting there with no ducting pushing cold air from the outside into them. There's a reason BMW engineers put the intake for both n54 and n55 on the cold side of the engine. Heatsoak is a well-known and documented issue on these engines. Doing anything that involves putting your air filters on the hot side is going to exacerbate that problem. Sending in colder air to begin with will reduce the total amount of heat transfer that the turbo gives off to the air as it passes through to the intercooler.
    This won't be a problem if you aren't running hot laps - I am just making an observation based on physics. Your car will still obviously be making great gains from this. I think you should explore what you said about maybe making an air duct.
    For now, though, probably just go flog on it when the weather is better 😉
    Just don't be one of those "paint your intercooler black" dudes 😆
    2007 Z4MR
    2003 E39 M5
    2002 E46 M3
    2021 X5 40i
      I just read that as ""paint your intercooler" black dudes." Had to reread that lol.
        No doubt my IATs will be higher. Not denying that. I plan on creating some sort of air duct and possibly wrapping the pipes, but we will see.
        I might have to dig up some old logs and compare differences. I was running stock intercooler before (headsoak city up in that bish). The 7" should almost cancel out the higher IATs. We will see.
        • i_love_carsI
          i_love_carsI
          i_love_cars
          also agree on not running meth. I am holding off on that as well. Especially having port injection options now - fueling can be dealt with in such a way that meth isn't as necessary unless you are absolutely trying to max out power. More hassle than it's worth otherwise IMO.
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
            When will your car race-ready? I'd love to do a pull against you, see how they compare. Maybe at one of the WIBimmers meets this year?
            • i_love_carsI
              i_love_carsI
              i_love_cars
              hoping to have boost leak resolved by Monday, then assuming all goes well the tune should be getting dialed in over the next month or so. I'm always down for some pulls but that means you actually need to make it to a meet  😆
              2007 Z4MR
              2003 E39 M5
              2002 E46 M3
              2021 X5 40i
                Meth, not even once.
                If I ever get a new intercooler I will definitely be applying high emissivity coatings to it. Something to consider if you need to bring temps down without meth/changing the entire intake setup. Some folks have never heard of it before so I thought i'd mention it
                Just dont be one of those "paint your intercooler" black dudes
                  High emissivity coatings? I'd be one of the folks who have never heard of it before. Please explain...
                    Buttoned everything up (besides the front bumper) and fired her up this weekend. Started on the first crank and purred like a very noisy kitten.
                    She feels real good 😄
                    After that picture, I installed my new plates 😆
                    • i_love_carsI
                      i_love_carsI
                      i_love_cars
                      bahahahahha that's fucking awesome. love that plate
                      2007 Z4MR
                      2003 E39 M5
                      2002 E46 M3
                      2021 X5 40i
                        A lot of hate on the black intercoolers here. I just came to flaunt my black intercooler. It's the stealthiest.
                        I would also like to post this for your viewing pleasure. It is not the most scientific of experiments, but I can say I was surprised by the results.
                        I did not use standard spray paint as they did, I used radiator paint which is much thinner.
                        I quite enjoy the new plate!
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          i hate to be that guy that derails a thread (ok actually i don't), but there's better physics and math being applied by EE about this whole black intercooler thing. Basically do it if you want the aesthetics of black, but don't assume you're getting better performance because in real terms, you aren't.
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                            But what if you plasti dip it!?  Plasti dip fixes everything!  That's gotta be more efficient with the rubberized coating help to contain coolness and help cool ther intercooler.
                            But seriously, more discussion should be had about end tank internal design and flow than the color of an ic.
                              I agree, I should have stated that the "cooling benefit" they find is not that relevant.
                              I like my black intercooler, you cannot see it behind my grills.
                              #stealthmodeengaged #exceptformyreallyloudexhaust
                                I bought my intercooler black from the factory. That is all.
                                  Jake walnut blasted my intercooler
                                  • M
                                    M
                                    mpower420
                                    Ever race hwy100
                                    Im going tonite as long as it dont rain [emoji383][emoji383][emoji383]
                                    • andyhundleyA
                                      andyhundleyA
                                      andyhundley
                                      mpower420 said:
                                      Ever race hwy100
                                      Im going tonite as long as it dont rain emoji383.pngemoji383.pngemoji383.png
                                      Yeah dude are you gonna be down on HWY?
                                        I've heard my fair share of HWY 100 stories, but have never been down there. Maybe later this summer... it's not on the top of my to-do list.
                                        Wouldn't mind throwing a few bucks down on roll races though.
                                        • M
                                          M
                                          mpower420
                                          Kseries brz all that shit
