887 Posts 52 Posters 0 Views 1 Watching
  • i_love_carsI
    i_love_carsI
    i_love_cars
    that looks so much better than an N54 with stock inlets.
    I still don't like the design of the hot side having the air filters now due to the aftermarket inlets, but I know the increased volume you get makes good power gains regardless and overpowers the hot air being pulled in. I would think a meth injection kit is practically a necessity using those inlets given how much heatsoak issues this engine already has.
    2007 Z4MR
    2003 E39 M5
    2002 E46 M3
    2021 X5 40i
      I'd beg to differ. I might wrap them in heat-resistant material and create an air duct, but the increased air temp won't matter after going thru the glowing hot turbos. The 7" intercooler will do its job.
      I doubt I will ever run meth. Maybe if we were in Texas or California. E85 and maybe port injection is as far as I'll go.
      • i_love_carsI
        i_love_carsI
        i_love_cars
        I guarantee you are pulling hotter IATs with this setup after a couple pulls. While the turbo itself certainly impacts temps, you are going to be starting with hotter air to begin with. All your air is now being pulled into the car from the hot side of a turbo motor and your filters are just sitting there with no ducting pushing cold air from the outside into them. There's a reason BMW engineers put the intake for both n54 and n55 on the cold side of the engine. Heatsoak is a well-known and documented issue on these engines. Doing anything that involves putting your air filters on the hot side is going to exacerbate that problem. Sending in colder air to begin with will reduce the total amount of heat transfer that the turbo gives off to the air as it passes through to the intercooler.
        This won't be a problem if you aren't running hot laps - I am just making an observation based on physics. Your car will still obviously be making great gains from this. I think you should explore what you said about maybe making an air duct.
        For now, though, probably just go flog on it when the weather is better 😉
        Just don't be one of those "paint your intercooler black" dudes 😆
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
          I just read that as ""paint your intercooler" black dudes." Had to reread that lol.
            No doubt my IATs will be higher. Not denying that. I plan on creating some sort of air duct and possibly wrapping the pipes, but we will see.
            I might have to dig up some old logs and compare differences. I was running stock intercooler before (headsoak city up in that bish). The 7" should almost cancel out the higher IATs. We will see.
            • i_love_carsI
              i_love_carsI
              i_love_cars
              also agree on not running meth. I am holding off on that as well. Especially having port injection options now - fueling can be dealt with in such a way that meth isn't as necessary unless you are absolutely trying to max out power. More hassle than it's worth otherwise IMO.
              2007 Z4MR
              2003 E39 M5
              2002 E46 M3
              2021 X5 40i
                When will your car race-ready? I'd love to do a pull against you, see how they compare. Maybe at one of the WIBimmers meets this year?
                • i_love_carsI
                  i_love_carsI
                  i_love_cars
                  hoping to have boost leak resolved by Monday, then assuming all goes well the tune should be getting dialed in over the next month or so. I'm always down for some pulls but that means you actually need to make it to a meet  😆
                  2007 Z4MR
                  2003 E39 M5
                  2002 E46 M3
                  2021 X5 40i
                    Meth, not even once.
                    If I ever get a new intercooler I will definitely be applying high emissivity coatings to it. Something to consider if you need to bring temps down without meth/changing the entire intake setup. Some folks have never heard of it before so I thought i'd mention it
                    Just dont be one of those "paint your intercooler" black dudes
                      High emissivity coatings? I'd be one of the folks who have never heard of it before. Please explain...
                        Buttoned everything up (besides the front bumper) and fired her up this weekend. Started on the first crank and purred like a very noisy kitten.
                        She feels real good 😄
                        After that picture, I installed my new plates 😆
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          bahahahahha that's fucking awesome. love that plate
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                            A lot of hate on the black intercoolers here. I just came to flaunt my black intercooler. It's the stealthiest.
                            I would also like to post this for your viewing pleasure. It is not the most scientific of experiments, but I can say I was surprised by the results.
                            I did not use standard spray paint as they did, I used radiator paint which is much thinner.
                            I quite enjoy the new plate!
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              i hate to be that guy that derails a thread (ok actually i don't), but there's better physics and math being applied by EE about this whole black intercooler thing. Basically do it if you want the aesthetics of black, but don't assume you're getting better performance because in real terms, you aren't.
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                                But what if you plasti dip it!?  Plasti dip fixes everything!  That's gotta be more efficient with the rubberized coating help to contain coolness and help cool ther intercooler.
                                But seriously, more discussion should be had about end tank internal design and flow than the color of an ic.
                                  I agree, I should have stated that the "cooling benefit" they find is not that relevant.
                                  I like my black intercooler, you cannot see it behind my grills.
                                  #stealthmodeengaged #exceptformyreallyloudexhaust
                                    I bought my intercooler black from the factory. That is all.
                                      Jake walnut blasted my intercooler
                                      • M
                                        M
                                        mpower420
                                        Ever race hwy100
                                        Im going tonite as long as it dont rain [emoji383][emoji383][emoji383]
                                        • andyhundleyA
                                          andyhundleyA
                                          andyhundley
                                          mpower420 said:
                                          Ever race hwy100
                                          Im going tonite as long as it dont rain emoji383.pngemoji383.pngemoji383.png
                                          Yeah dude are you gonna be down on HWY?
