686 Posts 32 Posters 8.8k Views 3 Watching
  • ClassEC
    ClassEC
    ClassE
    Thanks - They are essentially a 1-piece "remake" (knockoff) of OZ Turbos.
    Here's my dilemma: went to install the subframe and the camber adjustments plates are hitting the under side of the body. I kinda went overkill and installed the subframe riser AND the weld in camber adjustments - I believe the risers are causing the weld-in adjustments to hit because they're now 12mm higher. Here's my options:
    -Buy the "standard" height subframe bushings and hope everything fits.
    -Cut off the tops of the existing weld-in camber adjustment plates
    -"Flip" the existing subframe riser bushings and reinstall subframe (flipping the bushings should gain me the clearance - but I'm worried about "lowering" the subframe and offsetting my camber adjustment - and what it might do to my driveline angles).
    Open to suggestions: leaning towards cutting off tops of current weld-in subframe risers, or flipping subframe risers. Not crazy about ordering $160 bushings, waiting for them to arrive, and hoping those don't hit too.....
    • ClassEC
      ClassEC
      ClassE
      Didn't have any help today, so swapped all the interior door panels and cleaned the carpets up.
      Before:
      After (hard to tell - but MUCH better):
      • ClassEC
        ClassEC
        ClassE
        Gonna try to flip the rear subframe bushings tonight and reinstall. We'll see what that does with the rear camber once installed - hopefully it won't be more then I can offset with the weld-in camber plates.
        • ClassEC
          ClassEC
          ClassE
          Well - had another good night in the garage last night. Pulled subframe back out, flip-flopped subframe bushings and removed subframe spacers and reinstalled. We had some issues getting the metal sleeves that run through the subframe bushings into the underbody "pockets", but half an hour of wiggling and "adjusting" with a BFH they finally slipped in.
          The weld-in camber plates clear the underbody now.... But not by much. I do have acouple questions:
          -Do I reinstall the original large washers that were sandwiched between the subframe bushings and body? I did - just wasn't sure if I was supposed to.
          -When I drop the big rear suframe bolts through the holes/bushings about 1/2" is sticking down through the bushings. I was expecting more - so tried tapping the bolt down with a socket extension but it didn't seem to want to go down. Does 1/2" of thread sound about right? When you tighten down the nut from below, does the splines of the bolt seat down and gain me more thread?
          -I've seen 70ft/lbs for the subframe nuts - and "get tight as possible". Thoughts on torque spec?
            on mine, I torqued them to 70 lb-ft ish or whatever the spec is and it didn't seem quite right to me so I snugged them down by feel.
            I couldn't find anything on the trailing arm torque specs so I checked for free motion without the shock attached and snugged it down until it started to bind just a bit, then backed it off to where it still freely rotates, I used nylock nuts and loctite.
            Also, yes, the washers get re-installed, otherwise the shear area on the bushing will be reduced and will wreck the bushings sooner
            • ClassEC
              ClassEC
              ClassE
              Well - had another pretty good night!
              Subframe is up and bolted in, rear coils are in, ebrake and driveshaft are bolted in, rear seats are in, new front sway bar end links and steering boots are in, new front tie rod ends are in.... Didn't install the new swaybar bushings though when I ran across this:
              Apparently the passenger front sway bar bushing mount was broke/stripped at some point and a PO or shop did this. I'm going to leave bushings "as is" until I can replace the front substructure.
              • ClassEC
                ClassEC
                ClassE
                Hoping wheels are done at paint tomorrow so I can get tires mounted and set this thing on the ground.... Hopefully Saturday is a productive day!!!
                  This is the e30 weekend!  Parts for mine are coming Friday so hopefully Monday it will be ready to go.
                  • ClassEC
                    ClassEC
                    ClassE
                    I'll just leave this here....
                    • ClassEC
                      ClassEC
                      ClassE
                      Interior is 99% done (for now at least):
                        I love everything about this except for the wood wheel and shift knob. Of course, you're building it for yourself, not me. Either way, this thing is awesome!
                        • ClassEC
                          ClassEC
                          ClassE
                          I've always had a "thing" for wood wheels - but I do have to admit I'm undecided on if this one is gonna stay. The same wheel with brushed silver center - but wrapped in black leather - could be on the "to do" list.
                          I've got a long list of stuff to do though before I get to that point!
                            Looking great!  Keep up the good work.
                              Dude.....  Hell yeah!!
                              That thing is looking good!!
                              • ClassEC
                                ClassEC
                                ClassE
                                Not a bad day.
                                  Oh that is killer
                                    Oh my. Perfect!
                                      YES!!!
                                      NSFW.
                                        Looks fantastic. Hopefully you make the e30 meet!
                                        • ClassEC
                                          ClassEC
                                          ClassE
                                          Oh it better make it! Just need to bleed brakes, get exhaust on, install new tie rods, and get it aligned to have it driving!
