686 Posts 32 Posters 0 Views 1 Watching
    Gonna try to flip the rear subframe bushings tonight and reinstall. We'll see what that does with the rear camber once installed - hopefully it won't be more then I can offset with the weld-in camber plates.
      Well - had another good night in the garage last night. Pulled subframe back out, flip-flopped subframe bushings and removed subframe spacers and reinstalled. We had some issues getting the metal sleeves that run through the subframe bushings into the underbody "pockets", but half an hour of wiggling and "adjusting" with a BFH they finally slipped in.
      The weld-in camber plates clear the underbody now.... But not by much. I do have acouple questions:
      -Do I reinstall the original large washers that were sandwiched between the subframe bushings and body? I did - just wasn't sure if I was supposed to.
      -When I drop the big rear suframe bolts through the holes/bushings about 1/2" is sticking down through the bushings. I was expecting more - so tried tapping the bolt down with a socket extension but it didn't seem to want to go down. Does 1/2" of thread sound about right? When you tighten down the nut from below, does the splines of the bolt seat down and gain me more thread?
      -I've seen 70ft/lbs for the subframe nuts - and "get tight as possible". Thoughts on torque spec?
        on mine, I torqued them to 70 lb-ft ish or whatever the spec is and it didn't seem quite right to me so I snugged them down by feel.
        I couldn't find anything on the trailing arm torque specs so I checked for free motion without the shock attached and snugged it down until it started to bind just a bit, then backed it off to where it still freely rotates, I used nylock nuts and loctite.
        Also, yes, the washers get re-installed, otherwise the shear area on the bushing will be reduced and will wreck the bushings sooner
          Well - had another pretty good night!
          Subframe is up and bolted in, rear coils are in, ebrake and driveshaft are bolted in, rear seats are in, new front sway bar end links and steering boots are in, new front tie rod ends are in.... Didn't install the new swaybar bushings though when I ran across this:
          Apparently the passenger front sway bar bushing mount was broke/stripped at some point and a PO or shop did this. I'm going to leave bushings "as is" until I can replace the front substructure.
            Hoping wheels are done at paint tomorrow so I can get tires mounted and set this thing on the ground.... Hopefully Saturday is a productive day!!!
              This is the e30 weekend!  Parts for mine are coming Friday so hopefully Monday it will be ready to go.
                I'll just leave this here....
                  Interior is 99% done (for now at least):
                    I love everything about this except for the wood wheel and shift knob. Of course, you're building it for yourself, not me. Either way, this thing is awesome!
                      I've always had a "thing" for wood wheels - but I do have to admit I'm undecided on if this one is gonna stay. The same wheel with brushed silver center - but wrapped in black leather - could be on the "to do" list.
                      I've got a long list of stuff to do though before I get to that point!
                        Looking great!  Keep up the good work.
                          Dude.....  Hell yeah!!
                          That thing is looking good!!
                            Not a bad day.
                              Oh that is killer
                                Oh my. Perfect!
                                  YES!!!
                                  NSFW.
                                    Looks fantastic. Hopefully you make the e30 meet!
                                      Oh it better make it! Just need to bleed brakes, get exhaust on, install new tie rods, and get it aligned to have it driving!
                                        You already know how I feel about it=)
                                          "Meh"
                                          :P
