  4. '88 E30
'88 E30
savebigmoney
    That's because a PS rack without the PS is no bueno. BUT a manual rack that is made to not have PSĀ is ftw! The e21 has a manual rack and I love it.
      Quick steering
      Easy steering
      Gobs of cornering grip
      Pick 2
      Manual racks are fine but fighting some grippy front tires in a sudden countersteer maneuver is something id rather have power steering for.
      Anyone who disagrees drifts on 800 treadwear snoozeradials
        Cams in the AM
          Was your head that clean to begin with or did the shop clean it?
            Machine shop hot tanked it
              He actually licked it clean, while saying something about "practice for upcoming wibimmer meets".
              I think there is cause for concern.
                Well with uncle bens help: 1e653c33b9478bc8ec5502aef19544fa.jpg
                Cams are in and engine is timed, everything is torqued. Will be rechecking the ARPs after the first heat cycle
                Still need to flush block as well
                Rebuilt the vanos while he installed the cams (didn't take pics) was pretty easy. There was a decent amount of play before, not as much after. Hooray for no more marbles.
                Installed new Stewart pump as well
                Now it's just reinstalling exhaust & all other crap.
                Realized I sold my intake elbow, so I can't really drive it around the rest of the year NA, so I'm forcing myself to finish the SC.
                Looks like I'll have to figure out something for modifying the dipstick tube for a drain (or just tap the pan) as it interferes with the sc piping.
                Probably need to buy a new tensioner as well. Also figure out belt routing.
                Closer!
                  Hey, get this done so i can get a ride when i'm up next.
                    I'll try, been tough getting some free time as my folks are visiting this month from Nevada & spending time w/them is > e30
                      woah woah woah
                      you slipped that in there very non-nonchalant.
                      thats awesome!
                        Waiting on a temp sender (7/18 arrival) for the water temp gauge.
                        Also waiting on the ICV connector (to manifold) from reboot engineering (machined alum). After breaking 3 of the shit plastic ones and for the amount of times I'll most likely have to remove the intake manifold in this thing, I figured why not.
                        ^thats all in the "parts yet to arrive" category
                        Stuff I'll need to figure out:
                        -oil drain from SC, tapping the pan annoys me
                        -intake elbow deal from SC to TB (current one has 2.7 million holes drilled into it) need to either replace it or slap something together
                        Need to get the 2nd O2 bung welded onto my exhaust for the wideband.
                        Need to install and wire all the gauges/senders/etc
                        Seatbelt situation
                        Extend fuel lines
                        Replace all the vac lines & install vacuum distribution block
                        There's more but I can't remember
                          Should be able to use the narrow band output on the AFR gaugeĀ
                          Saves you some hassle and another sensor
                            Don't you need to know values of the sensor or something odd like that.
                            @ snap and I discussed that but I can't remember the outcome
                              Bosch only publishes sensor values for the newer LSU sensors. I dug deep and could not find anything for the early Bosch narrowband
                                Daggerty
                                @snap and I discussed that but I can't remember the outcome
                                I think he means use the simulated narrow band to ecu you just have to set high and low point for your wideband output, not all can do this. I believe it's 1.1 volts max,Ā otherwise you will get a cel. I can find it if that is the route you are going.
                                  Critical mission failure: cd42dd280bbd0e17f1388a48d9668a81.jpg
                                  On Monday going to the local radiator shop to have them toss a 90° on
                                  Also if you take the stock e36 upper hose and flip it 180° and trim off the side that originally connected to the rad, it should clear everything perfectly (obviously it will sit closer to the pulleys, couldn't get anymore bend with only one hand)
                                  Depends how much room he needs with the TIG
                                  I'm hoping that if it is semi close to the pulleys, that the solid engine and trans mounts will keep the whole shit show from piling into one another
                                  Hoping to get some more piddly stuff finished up this week/weekend such as wiring/random hoses/dipstick drain perhaps.
                                  Also most likely won't be able to run the intake tube they provide (hits ABS pump, angle doesn't work either) so I'm probably going to hop on silicone intakes and order up some crap and figure something out, already removed the drivers side hi beam [emoji849]
                                  I suck at updates
                                    Damn it Kaiser.
                                      Snapped a brake line.
                                      Removed abs
                                      Time for more room hooray
                                        Break lines
                                        Im not chomping at the bit to do an ABS delete like many E30 guys are but I honestly dont think I have ever needed to use the ABS in my car. It has never intervened. Carry on my wayward son
                                          ABS is gone. Unfortunately snapped the stock line under where the stock proportioning valve sits - snapped when I was removing it - honestly is probably not a bad thing and it will force me to replace it. It was the last line that I hadn't replaced in the braking system so all in all I'm not too upset about it.
                                          Most likely will just buy a length of hardline that has the fittings installed and bend it to fit. I hate flaring lines.
                                          I also will be buying the ABS delete from chase bays. While it's expensive it comes with everything so it'll be convenient.
                                          Good news without ABS I can run the stock VF intake pipe with a mushroom filter (yellow one) and run it thru the low beam headlight hole. So from a distance it shouldn't look too different.
                                          Also without ABS I can run the stock e30 expansion tank, which I might try and remove the black paint from so I can see the damn coolant level
                                          Radiator goes in Monday for modification
                                          With your input, this post could be even better šŸ’—
