  4. E28 SETA Build
E28 SETA Build
240 Posts 16 Posters 0 Views 1 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    6hp is all so a briggs and Stratton is all the difference so why is it called a super eta???
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      Well the engine will be out already while swapping the trans.  The only difference is the 6hp?  Are all of the sensors and other stuff the same?
      The only difference in sensors are what Motronic 1.1 vs 1.0 requires. I don't remember exactly what is added if anything but the crank position sensor is moved to the front of the block vs inside the transmission. This website outlines a good history of the differences for ETA's if you are curious.
      http://www.strictlyeta.net/technical/differences2.html
      • RamRod E28R
        RamRod E28R
        RamRod E28
        I love how full of shit this guy is "german edition" lol look at the bumpers dead give away moron
        • RamRod E28R
          RamRod E28R
          RamRod E28
          http://madison.craigslist.org/cto/4364505624.html
          and this I gotta say great camera work way to put some effort on the photo
          • RamRod E28R
            RamRod E28R
            RamRod E28
            http://madison.craigslist.org/cto/4351483311.html
              Good info, so it's a different computer and harness then.  So what parts combo is an "i stroker"
                A regular old eta bottom end and 885 head if i am correct. Or if you want high compression you use the seta bottom end.
                • RamRod E28R
                  RamRod E28R
                  RamRod E28
                  So swap heads from the super eta and keep the regular eta bottom end?
                    The seta already has an 885 head.  Is the cam different?
                      Paging snap.
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        SNAP!!! also cyoung I looked at the trans and the 2 holes for the old m20 crank sensor are filled in and will have to be drilled out if im gonna stay with the old m20
                          Yes SETA's have the 885 head but it has the eta cam and single valve springs. Read this page if you wanna know all about 2.7i or "e to i" builds
                          http://www.strictlyeta.net/technical/328i_1.html
                          The other problem I ran into last night while talking to Mike was that his transmission bell housing has to have the provisions for the speed and reference sensors for motronic 1 which use the flywheel. The bell housing needs those two holes on the drivers side as circled below. I don't think it will have those holes though because the SETA has motronic 1.1 which moved those sensors to the crank pully.
                          post-2724-0-08637100-1395263542thumb.jp
                          So the options for your manual swap are:
                          • Swap G260 onto the ETA along with the motronic 1.1 harness and required sensors (which would included fixing your harness)
                          • Swap Complete SETA drive line into the car (again requiring fixing the harness)
                          • Find a compatible G260 from 1987 or earlier 528e/325e
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            Mr Menard and I will see what's what once we pull the 84 drivetrain. I'm sure we can figure something out!!!
                              They had to make it different for one year...  This probably also means that the flywheel from the seta doesn't have the toothed ring either.  Ideally it would be nice to leave the eta in and build a 2.8i from the seta to swap in in the future.
                              Also before you take the parts car down from the stands, get the shifter linkage out, the carrier and shift lever/rubber boot and the wire that goes through it can just come out as one piece.  The clutch master needs to come out too.  Just mentioning what I forgot while we were working on it.
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                we also need the pedal box as well kind sir so idk what im gonna do about the brakes to get it out lol
                                  I am here.
                                    You should try to get as much of that stuff out as you can before next Tuesday, then we can get started on the good car then.  I'd be up for starting pretty early.  With a long day we may be close to getting it done.  Probably going to end up swapping everything from the '88 into the '84.  Any other option will need a bunch of different parts/time.  There wasn't much bad on the harness.  And the '88 engine seems like it was taken care of decently.
                                      So after a bit of thinking today this might be really simple.
                                      Swap seta and manual into car using seta harness etc.
                                      In the future find an i cam and springs to swap in to make it an "i stroker"  Am I missing something or is it that simple?  What pistons are ideal?  And the head could also be shaved and worked over as a "next winter" project to raise compression ratio and flow a bit.
                                        Also you will need the bracket welded to the inside of the transmission tunnel that supports the end opposite of the transmission of the shifter plate. This is what I need to fabricate for my car since previous owner removed it and I forgot to take it off my last E28 before scrapping  :mad:
                                        • RamRod E28R
                                          RamRod E28R
                                          RamRod E28
                                          Anyone else chime in about this i cam swap?
