  3. BMW Discussion
  4. Mitch's S52 M318 Swap
318 m3 swap eng
44 Posts 6 Posters 767 Views 1 Watching
    I have one for an m50 w/ getrag, is it the same?  I could mail it to you.  Just let me know.
      Should be the same since the trans are the same right. See if GunMetalGray has one, he is in the area.
        gsxify
        M318 said:
        Did you know that on bimmerfest.com they were telling people to put their clutch disk in backwards to get rid of chattering. What do you think about that? Is it COMPLETELY ridiculous?
        This is correct if you are using the E34 M5 clutch and you can use the E34 pressure plate. You need an aftermarket flywheel so you can flip the clutch so it will lay inside the flywheel. I'm not familiar with your flywheel at all.
        2c569698-d9c7-4c7d-95f2-e176a1893935zps
          Spelling!!!
          Do you have the smaller hole pilot bearing or the large one ?
