pistonse30
    Pre-throttle body .7mm meth bung.
    At my welding guy's (Dan the Exhaust Man) shop.  He is putting a full cage in this at the moment.
    Intake manifold ready to go!
    As she sits now.  Need to get the cold side piping tightened up, run the meth lines to the trunk and finish the engine part of it.  Lastly install new wideband O2 sensor harness when it is delivered.  I'm sure I'm missing some other things.
      #weldporn
        Do you have a solenoid on your water feed to the intake manifold? It was probably in the thread earlier but what water/meth injection kit are you using? My Volvo might need some...
          I pieced together a kit from Howerton Engineering. They have a fast acting valve solenoid thing that I'll have megasquirt run. They sell full kits as well.
          With that said I have a 60psi pump for sale on the cheap.
            Lookin' good m8
              Still burning coolant.  Guessing that the deviation in the block didn't come out with the block prep...  I'll get in there this weekend to see what the spark plugs look like.
              Getting to drive it was still fun.  It rips pretty good while laying a smoke screen.
              WTB:S52 motor
              Thinking that I'll get new rings on my Imagineering pistons.  Swap those and the K1 rods over to the new crank.  Drill and tap the head studs out to a bigger size (I think Boris with the 8 second e30 is running RB26 ARP studs). Punch out the bore to 87mm then machine down the block surface.  Slap the head on with a cut ring gasket and try to blow it up!
                Im not too keen on the larger stud idea but
                A. I need to see a bare s52 block in person
                B. My opinion shouldnt mean anything.
                  Or should I buy a new head, machine my block down to level and go from there?
                  • CMartC
                    CMartC
                    CMart
                    I've got a buddy who swears by this stuff.
                    http://www.amazon.com/Permatex-20539-Indian-Shellac-Compound/dp/B0008KLOG6/ref=sr_1_1?ie=UTF8&qid=1442602942&sr=8-1&keywords=indian+head+gasket
                    800+whp LS motors, 700+ whp 4G63s, etc. He really globs it on there - may be worth a try,
                    Excursion 7.3
                    E30 LS1
                      How much have you driven it? I replaced a cracked head on an m52 and it smoked white for 30 miles at least, I think there was tons of moisture in the exhaust from before the repair.
                        It is eating coolant and the oil is milky tan...
                          Well in that case... I just remember the disappointment at the clouds of smoke on startup of the first engine I built and somebody told me later "oh yea they always do that".
                          • T
                            T
                            tsweers89
                            That about sums it up
                            post-2578-0-54305900-1444098598thumb.jp
                            • ClassEC
                              ClassEC
                              ClassE
                              Damn.... Not what I was hoping to read while catching up on this thread.
                                Getting motivated
                                  So glad the museum is open now!
                                    The m52 that I picked up for $380 is shot.  Cracked head and the cylinders need to be bored out due to rust from a head gasket leak.  I could use the block and bore it out to 87mm for my pistons.
                                    Anyone have a m52 or s52 from an automatic car?  Preferably owned by a grandma who had a 50 mile daily freeway commute in a 55mph speed zone.
                                      Did the seller lie?
                                        I on some fronts, yes.  It was a junk yard motor he didn't have any knowledge of.
                                          Sounds like a good table candidate...
