  4. 87 535is - getting started
223 Posts 21 Posters 0 Views 1 Watching
    Brian said:
    too bad I can't just disconnect the power to the damn thing. Or remove it and put in T fittings.
    You can do both of those.
    • Brian.B
      Brian.B
      Brian.
      No, I was reading on Mye28.com that it can cause brake bias issues..
      instagram @howdoyoudrivethat
        It does on all cars. Get a proportioning valve.
        • Brian.B
          Brian.B
          Brian.
          yeah, I'll look into it, because I seriously hate my ABS. It's all jacked up. I also need to rebuild my power steering pump soon. I hate not having power steering, or power brakes.
            I'm removing abs because A) I hate it and B) Shaved bay:P lol
            • merlM
              merlM
              merl
              @ Snap
              I just realized I didn't tell you tires - Hankook Ventus V12 ...(I think that is right)
              • merlM
                merlM
                merl
                Euro headlights installed and wired (city light on in photo) ... front bumper test fit.
                Posted Image
                • Brian.B
                  Brian.B
                  Brian.
                  Damn you for having euro's. :( I need to source some.
                    Working on it=)
                    • merlM
                      merlM
                      merl
                      Euro non-AC center console.
                      Posted Image
                      • merlM
                        merlM
                        merl
                        Installed
                        Posted Image
                        • Brian.B
                          Brian.B
                          Brian.
                          Can I ask how much, and where you got that from? I really want one. I removed my AC. and I'd like a little cubby hole like that.
                          • merlM
                            merlM
                            merl
                            I actually received it with my euro bumper purchase so I don't know how much it would cost or how rare it is in the US (all US cars had AC) I did have to order a new Heater control plate as the radio and heat controls reverse (that was 65 bucks) ... I am looking forward to having the cubby as well.
                            • Brian.B
                              Brian.B
                              Brian.
                              Looks damngood. I want one. Gunna source one.
                              • merlM
                                merlM
                                merl
                                I will let you know if I run into another one ... I don't see them often though.
                                  Very nice!
                                  • Brian.B
                                    Brian.B
                                    Brian.
                                    Please do! And the radio thing is whatever. Mine never works to begin with. Don't know if it's my Clarion headunit, or the previous owners botched wiring job.
                                    • merlM
                                      merlM
                                      merl
                                      The new head is de-valved and work will start on that and the intake manifold. Pistons and cam will be about 5 weeks so there is time to make the Motronic 1.3 harness look purty and get the shadowline done.
                                      Also, my brake booster (hydraulic, not vacuum) decided it was done holding fluid  :confused:  so that has to come out and be rebuilt. The 3.73 still needs to go in, air dam mounted, paint for said air dam and bumpers, minor body work, speakers, etc, etc, etc ....
                                      Lots to do but looking good.
                                        Wow Merl, sounds awesome!
                                        What size cam?
                                        What pistons (what CR will you end up with)
                                        What tune do you run with a M1.3 conversion?
                                        Is they hydroboost brake booster desirable, or a problem area?
                                        I am not sure if they would be compatible, but I do have a low mile ATE booster and MC off a 92 E30 vert. in case there was any reason to get rid of the hydroboost setup.
                                        What is your current diff ratio? 3.25? and is the 3.73 Large or Medium case?
                                        I love e28 535i's and is's (esp. yours)  , just trying to learn a bit more
                                        • merlM
                                          merlM
                                          merl
                                          Pistons and Cam are Paul Burke (Imagineering) an i don't have Cam specs but it is built to work with the engine/pistons
                                          Pistons are custom M30B35 10.5:1 forged
                                          motronic 1.3 will be running Miller WAR / MAF with 24lb injectors
                                          I don't think Hydro is a huge problem area but it is also not desired ... no advantage really.
                                          There are people that have converted to Vacuum boosters but it is involved and more work that I want to do
                                          Current diff is 3.25LSD and the new is a medium case 3.73LSD from an e30 ...
                                          Also, the head is an M30B35 with custom port matching ... We should be able to get somewhere around 230hp at the wheels...
