  4. 87 535is - getting started
223 Posts 21 Posters 0 Views 1 Watching
    Do you have ABS/does it work?
      I might look into that :) That looks awesome.
      • merlM
        merlM
        merl
        Yes, I have abs and it works. The brakes worked well enough on the track that I never got into abs.
          I want to remove my ABS. I'm not a fan of ABS. But that is awesome!
            I like ABS but after replacing the pump, control unit, sensors (with used sensors), and cleaning the rings on the hubs, it is still in-op. I have some more used sensors to try out before pulling the rest of my hair out, but I am starting to lean towards removing my ABS. I really dont want to flat-spot a set of nice tires, but as hard as I was on the brakes at the track, I didn't get into any lockup even on my all-seasons. So im on the fence about keeping/removing the ABS. If I can get it to work this spring, then I will re-locate the pump to behind the passenger side strut tower for some better weight distribution.
              Learn to put just the right amount of pressure on your brakes while braking hard. A good way to do this, drive with out cruise control for a long time. I never use crusie control, you'll get muscle memory of where say, "60mph is" and your foot will auto adjust for going up and down hills. Sounds stupid, but it works. My ABS is all sorts of fucked up, and likes to kick on and off on it's own. too bad I can't just disconnect the power to the damn thing. Or remove it and put in T fittings.
                You can do both of those.
                  No, I was reading on Mye28.com that it can cause brake bias issues..
                    It does on all cars. Get a proportioning valve.
                      yeah, I'll look into it, because I seriously hate my ABS. It's all jacked up. I also need to rebuild my power steering pump soon. I hate not having power steering, or power brakes.
                        I'm removing abs because A) I hate it and B) Shaved bay:P lol
                        • merlM
                          merlM
                          merl
                          @ Snap
                          I just realized I didn't tell you tires - Hankook Ventus V12 ...(I think that is right)
                          • merlM
                            merlM
                            merl
                            Euro headlights installed and wired (city light on in photo) ... front bumper test fit.
                            Posted Image
                              Damn you for having euro's. :( I need to source some.
                                Working on it=)
                                • merlM
                                  merlM
                                  merl
                                  Euro non-AC center console.
                                  Posted Image
                                  • merlM
                                    merlM
                                    merl
                                    Installed
                                    Posted Image
                                      Can I ask how much, and where you got that from? I really want one. I removed my AC. and I'd like a little cubby hole like that.
                                      • merlM
                                        merlM
                                        merl
                                        I actually received it with my euro bumper purchase so I don't know how much it would cost or how rare it is in the US (all US cars had AC) I did have to order a new Heater control plate as the radio and heat controls reverse (that was 65 bucks) ... I am looking forward to having the cubby as well.
                                          Looks damngood. I want one. Gunna source one.
