  4. E30 M50 tear down kinda thing
550 Posts 16 Posters 0 Views 1 Watching
  • StewCrewS
    StewCrewS
    StewCrew
    The core support project is finished! It will probably take up multiple posts and is definitely going to be pic heavy! Hopefully I'll get all of it up at some time today. I'm talking 20+ pictures haha.
    • Brian.B
      Brian.B
      Brian.
      I'm excited
      instagram @howdoyoudrivethat
        ^im with you.
        • Brian.B
          Brian.B
          Brian.
          Rowleym said:
          ^im with you.
          No you're not. You're 75+ miles north of me. Liar.
            Nice one man. Haha
            • Brian.B
              Brian.B
              Brian.
              Rowleym said:
              Nice one man. Haha
              Thanks ;)
              • StewCrewS
                StewCrewS
                StewCrew
                Okay guys, so I finally got around to uploading all of the pictures for my core support project so here's my little write-up on how to do this. I had already cut the entire middle section out while pulling my motor so that made it a bit easier. Id suggest doing this to clear up a whole bunch of room.
                First things first: grinding the paint away on the upper parts to see the factory tack welds and drilling through them. Drill bit size isnt real important, just make sure its big enough to drill out the entire weld. (Each little dimple is a tack weld)
                My car, being almost 30 years old, needed a bit of persuading to break free due to some rust
                Here are the factory tack weld locations, which are identical for both driver and passenger side.
                Top view (5 tack welds)
                "Inside" view (Another 5)
                So using the mallet and big flat head, I carefully pried between the edges and knocked it free.
                For the lower parts Ill admit I cheated a little and used tools that might not be available to everyone. Since my stock core support was very rusty it was near impossible to see where the welds were, so I ended up using a hydraulic chisel to cut through any welds and break it free. You are also taking off the stock tow hooks. So heres after the lower pieces are taken off and most of the rust grinded down.
                So now all of the stock core support has been removed
                Next was to test fit the new core support, but I found these two little tabs right inside the bumper shock housings wouldnt let it slide into place
                Easy fix!
                And the new support being fitted
                It was a tight fit and needed to be angled at a certain way to get in, but it fits. Keep in mind this is an ebay product, so fitment wont be absolutely perfect. I was able to get it very close with a little bit of pounding from a soft rubber mallet.
                So this is step 1, which I consider "getting the car ready for the new support". Step two will be the next post.
                  You're the man.
                  • StewCrewS
                    StewCrewS
                    StewCrew
                    Next was to make small "L" brackets, since the metal of both the car and the core support are fairly flimsy, I wanted to make sure it would be safe.
                    Posted Image
                    Checking fitment
                    Posted Image
                    Welded together. You will need to make two of these, one for each side.
                    Posted Image
                    Then just a square welded to the tabs for the lower section.
                    Posted Image
                    I kinda forgot to take a couple pictures for the next few steps because I was excited to get done, but theyre pretty straight forward. I used a 3/8" drill bit, and ran to napa to get nuts and bolts the fit snug in the drilled holes. With the holes drilled, I tightened them down as if I were actually putting the core support on, and welded the nut to the fender support (I guess is what you would call it?). Be very very careful doing this! The metal is super thin and its easy to melt right through it!
                    Posted Image
                    The next part was the trickiest. Remove you bumper shock if you havent already (13mm bolts), and tighten down your nut and bolt. Hopefully you will have fairly clean metal, which I was lucky enough to have. But you need to very carefully blind weld the nut inside the bumper shock housing. I took a lot of time to make sure I didnt get any metal on the bolt, because if you do, youre screwed lol. Here you can see both bolts screwed into the nuts with the core support removed.
                    Posted Image
                    You do that for both sides, and thats it! You have just made your new core support removable whenever you want!
                    Posted Image
                    Posted Image
                    Posted Image
                    Any questions/comments/concerns are welcome. This was a fun project and Im happy with the outcome :)
                    • StewCrewS
                      StewCrewS
                      StewCrew
                      Rowleym said:
                      You're the man.
                      High five!
                      • StewCrewS
                        StewCrewS
                        StewCrew
                        Also in other news, I began shaving my bay, and finally got my big boy studs and 20mm spacers on up front!
                        Posted Image
                        No, I did not paint my caliper brackets blue. I aint about dat.
                        Posted Image
                        Posted Image
                        • Brian.B
                          Brian.B
                          Brian.
                          Good write up! How fast/easily removable is the front core support? I'm thinking of doing one for my E28, but I'd do mine differently.
                          • StewCrewS
                            StewCrewS
                            StewCrew
                            With nothing in the car at all how it is now, maybe 2 minutes to get it off. Getting it back in is a little tricky because it has to be lined up perfect. I wish I went with a bigger drill bit for the holes but oh well, it works. I can take it off and put it back in within 5 minutes total. Im already excited for the amount of time its going to save putting the motor back in or when it comes out next lol.
                            • Brian.B
                              Brian.B
                              Brian.
                              Nice!
                                How did you take it out in the first place? Just drill it out? I'm just about to take it out.
                                • StewCrewS
                                  StewCrewS
                                  StewCrew
                                  The old core support? I cut it right in half at first to pull my motor. The only thing holding the top sections in are the tack welds. Like I said in the post I'm not exactly sure where the tack welds are on the part that's around the bumper shock towers because mine was so rusted. But I know there's a couple thick welds on the outside of it. Feel free to text me in you want to send me pictures or have any questions! That way ill get it right away instead of checking here lol: 262-349-6277.
                                    Very nice work my friend!
                                    Thanks for the documentation.
                                    • StewCrewS
                                      StewCrewS
                                      StewCrew
                                      Thanks! It was a fun project and I hope this helps some people out.
                                        StewCrew said:
                                        .....helps some people out.
                                        This guy!
                                        • StewCrewS
                                          StewCrewS
                                          StewCrew
                                          Rowleym said:
                                          This guy!
