  4. My E30
My E30
33 Posts 8 Posters 510 Views 1 Watching
    sooooo, got super bored today and did this all for no reason whatsoever
    popped the trunk tar out
    and the spare
    relocated the antenna, need to get a plug for it yet
    I was surprised how heavy that trunk tar BS was.
    55lbs of junk
    -1 bottle cap 40lbs
    allout and vacuumed up
    no more antenna
    zip-tied up out of the way
    • JeffJ
      JeffJ
      Jeff
      why the antenna? its so cool and it gives you music
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        tumblrlks6fzJvuF1qhfyv3o1400.gif grumpy-cat-citizen-kane-applause-clappin tumblrlks6fzJvuF1qhfyv3o1400.gif
          thanks for the sarcastic clapping
            the antenna still works.
            • JeffJ
              JeffJ
              Jeff
              how you removed it
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                unscrewed it with my fingers. then moved it to where it is now. zip tied it.
                just took off the whole windshield washer setup too (didnt work anyways)
                • JeffJ
                  JeffJ
                  Jeff
                  ooo hows signal in the trunk? i have a pump for the windshield was if you want it
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    the signal's okay, but i dont listen to the radio much.
                    and the lines had pinholes in them, so it sprayed fluid into my hood lining. lol.
                    I want to replace the whole head unit with a black plate with a hole for 3.5 mm audio.
                    so i can plug my own music in.
                    then I can get rid of all that unnecessary stuff.
                    • JeffJ
                      JeffJ
                      Jeff
                      hmm engine wash on the go! i would have kept it
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Jeff! I didnt want to fix it.
                        It had pinhole leaks in it.
                        if i need to pull over because the windshield is that horrendously dirty, I've got other issues. lol
                        • JeffJ
                          JeffJ
                          Jeff
                          its not really fixing it if you take advantage of the pin holes to was the engine as you drive.
                          i took mine out because of a hose that was leaking all over also.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                          • JeffJ
                            JeffJ
                            Jeff
                            any updates yet???
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
