My E30
that's because it's not a build thread!
IDK WHAT THIS THREAD IS FOR
sooooo, got super bored today and did this all for no reason whatsoever
popped the trunk tar out
and the spare
relocated the antenna, need to get a plug for it yet
I was surprised how heavy that trunk tar BS was.
55lbs of junk
-1 bottle cap 40lbs
allout and vacuumed up
no more antenna
zip-tied up out of the way
thanks for the sarcastic clapping
why the antenna? its so cool and it gives you music
the antenna still works.
unscrewed it with my fingers. then moved it to where it is now. zip tied it.
just took off the whole windshield washer setup too (didnt work anyways)
the signal's okay, but i dont listen to the radio much.
and the lines had pinholes in them, so it sprayed fluid into my hood lining. lol.
I want to replace the whole head unit with a black plate with a hole for 3.5 mm audio.
so i can plug my own music in.
then I can get rid of all that unnecessary stuff.
hmm engine wash on the go! i would have kept it
Jeff! I didnt want to fix it.
It had pinhole leaks in it.
if i need to pull over because the windshield is that horrendously dirty, I've got other issues. lol
its not really fixing it if you take advantage of the pin holes to was the engine as you drive.
i took mine out because of a hose that was leaking all over also.
