  4. Finally Joined the Longroof Club
328itn52e91
156 Posts 22 Posters 3.2k Views 1 Watching
    super functional upgrade!
    for the roof rack t-slot: in the world of fishing kayaks, t-slot rails have become quite popular. there are probably several iterations of the 't-bolt' but this is what you can find:
    https://www.austinkayak.com/YakAttack-MightyBolt-2-in-6-pack/ACK22651P.html?utm_source=google&utm_medium=cpc&utm_campaign=Shopping: ACK PLA&adpos=1o16&scid=scplp22651_19781_1&sc_intid=22651_19781_1&gclid=CjwKCAjwqfDlBRBDEiwAigXUaJOzMl8AidnLOQ3GWIQkfWsRHxSZ8j33yopAPHvvcl9jLOIlGAsPrBoCC3sQAvD_BwE
    they fit the t-slot on my e34 roof rails perfectly.
    search 't-bolt' or 't-slot bolt' on amazon, ebay, etc.
      Fits great, well worth the practicality for sure. Any big road trips planned?
      Not at the moment, might be taking it out to the east coast in November but that's the only one on my radar for now!
      Thanks for the info! I had tried to do some looking and didn't come up with much. I ended up cobbling together some random bits from the hardware store a few weeks ago, but I'm not loving how it came out. At best it will hold me over until I have the funds to buy the hitch adapter bit for my rack. A better solution would be fantastic for when I have other things to mount up there
         I ended up cobbling
        Didn't realize you knew how to fix shoes. Does that make you related to Micheal Schumacher?
          Image result for cobbler gif
            86.6K
            Changed the oil with some fancy pants rebranded castrol BMW 5w30 LL01 stuff. If someone came up with a kit that added an actual dipstick to an n52 I would buy it.
              I know the pain... Never mind the price tag... https://www.bimmerworld.com/BimmerWorld-E8X-E9X-Race-Oil-Pan-Assembly.html
              They make an S65 oil pan with dipstick retrofit for $1500 that's almost worth it for me.
                Lolololol, buy your own dipsticks
                  You're expectations are way to high.
                    Ugh, I figured there was something out there, and I can't say I'm surprised that it's a $2k bimmerworld race part...
                      So when's the order getting placed? lol
                        If I find an extra 2 grand laying around that I didn't know I had and have no other use for I'll let you know haha
                          90.8k
                          After having a replacement upper windshield trim piece sitting in my garage for at least a year, I finally got around to installing it. The old trim piece was pretty much toast...
                          Getting the old one out was a bit of a pain as it came out a lot of tiny pieces. The trim hooks onto the windshield from the top and is held down on the roof by some strong adhesive, so getting the groove and mating surfaces clean is pretty important. Ready for the new trim:
                          When installing the new piece I found that once you have each end hooked in place, you can work the rest of it into the groove by rocking the top of a dead blow hammer along the front edge of the trim (pressing towards the back of the car). This method got it sitting nice and flat. Last step is to remove the red adhesive backing to stick it to the roof. It looks way better now
                            Nice work! The sun of the south sure isn't kind to rubber seals.
                              91.2k
                              Well, something was bound to happen eventually.
                              I got home from work this past Wednesday and noticed a rattling sound coming from the engine at idle. Its an inconsistent/irregular knocking sound and seems to disappear as the RPM's rise. It also seems to get worse as the engine heats up. It sounds very similar to the 'marbles in a can' noise my e36 made before the vanos rebuild. The car also sounds like a diesel at idle, but seems to smooth out if you rev it past 2k rpm. I drove it to work on Thursday and the Service Engine Soon light came on. After work I parked the car as I had to leave town for the weekend.
                              On Sunday I got some time to start looking into the problem. Pulled codes with my OBD2 scanner and got one, P054B (Exhaust camshaft overly retarded - cold start). I removed all the cowl covers and other plastic crap covering basically everything so I could poke around. I've read that the vanos solenoids can cause issues so I pulled and cleaned them both, and swapped them between left and right to see if any codes or issues followed. Nothing new popped up but I didn't really drive the car, just let it idle and a few revs to actuate the vanos. No change to the noise at all. I also listened around with a stethoscope and determined that all coil packs and injectors are firing as normal, PS pump and alternator are running quiet, idler pulleys are quiet. The timing chain tensioner seems to be transmitting a lot of the noise so I am fairly certain it is an issue with either the vanos or timing chain. Because the sound doesn't get worse when the engine is revved, it leads me to believe it is an issue with the vanos.
                              It turns out that quite a few cars made from 2010-2012 are the subject of a recall for some bolts on the vanos actuators coming loose or snapping. I called BMW of Milwaukee North and they confirmed that my car doesn't fall under this recall, however it does fall under an 'extended warranty' for this specific issue and that it is still in effect for my car for another 6 months:
                              https://static.nhtsa.gov/odi/tsbs/2014/SB-10045283-5967.pdf
                              https://static.nhtsa.gov/odi/tsbs/2014/SB-10057335-7958.pdf
                              They have to do a diagnostic on the car and if it is indeed the vanos bolt issue, the repair will be completely covered. If not, I'll be learning a lot more about the N52...
                                Damn retarded camshafts
                                  images?q=tbn:ANd9GcRPxfLlmveGWf9xfKtMULj
                                    Extended warranty you say... I hear "redline every gear until the bolt let's loose and get a new engine".
                                      reading through the docs you posted I found this:
                                      someone said:
                                      The parts list below is only for vehicles that receive one replacement VANOS adjustment unit and VANOS adjustment bolts on the intake or exhaust VANOS adjustment unit.
                                      Part Number             Description                                                    Quantity
                                      11 36 8 602 263        VANOS Bolt (ISA screw M7x21)                     4  *
                                      *Additional replacement bolt(s) may be needed if they do not torque to the correct specification, claim additional bolt(s) as necessary and explain the reason in the claim comments.
                                      why on earth would the bolts 'not torque to the correct specification' ? are they spec'ing bolts that are likely to snap when torqued to spec?
                                        Hadn't seen that one. I'm hoping that is mentioned because the driver pocket on the screws is so shallow (The 4 screws below are the ones in question), maybe they could strip before reaching the necessary torque? I wouldn't be all that surprised if that weren't the case though...
                                          dug into it deeper. it appears those bolts are originally aluminum from the factory. they require an initial torque, then an angle torque. they also have a special torx tool called out (i think its just an odd length, due access clearance).  stripping or snapping seems plausible. based on posts online, some of the bolts snap themselves just from the car running. however, it also looks like they've recalled those bolts and replacements are now steel so the whole point may be moot.
                                          repair procedure (which seems to precede the change of bolts to steel)
                                          https://static.nhtsa.gov/odi/rcl/2014/RCRIT-14V176-2716.pdf
                                          but, keep in mind I have very little knowledge of new engine codes and if any of this even applies to your N51/2/3/4/5/6/7/8/9 engine
