  3. Cars For Sale & Wanted
  4. 2002 E46 M3 For Sale (Slicktop - Trackday Car) 90K Miles - $17,700
  • dastuzD
    dastuzD
    dastuz
    *For those more active members, this is the known as the loudest E46 M3 around
    For sale is my 2002 BMW M3 (E46). This is a slicktop model (no sunroof). I have been unable to find reliable data about the rarity of slicktop models, but anecdotaly they appear to be quite rare. The motor has stock internals (minus the prior owner having the bearing recall done). It has 90,000 original miles on the car. The oil is changed every 1,000 miles with Redline's 10W 60 Oil. Transmission and differential both have Redline's own brand of high temp fluids. The car is definitely loud both in sound and appearance. The low stance, big tires, racing seats, and dark rims get looks and comments wherever it goes. I have roughly $30,000 into the vehicle (not including the purchase price – see below). I have built the car to almost track day specifications. A cage or harness bar would be the final piece of that build.
    Engine -The car runs strong and has no engine issues. The catless header does cause O2 codes – see exhaust section below
    Body - the body is in fair condition - the car is not a show car it has some minor scratches/nicks.  Kidney grill and side vents were swapped from chrome to black
    Interior – the interior of the car is the part of the build I did not finish. I gutted the car for track day usage. The speakers, amplifier, radio, etc. have all been removed. I did not delete any of the wires in the harness, so someone could reconnect or remove those unused wires. My car suffered from the E46 painted trim issues. It bubbled and cracked. I got a coverup kit for it, but I would recommend buying the new trim pieces. I still have much of the interior in storage – Stock seats, OEM rims and tires, intake, etc. if someone wishes to go back to a full interior. The largest item that would need to be purchased would be the carpet.
    Handling -The car drives very well. The suspension and set up makes the car handle very well. Please note that the suspension, bushings, seat, and tires mean that the ride is more track oriented. The car is very stiff!
    History / Full Disclosure
    The vehicle suffered a crash at Blackhawk Farms a few years ago. After this crash I had the driver side front fender touched up, the hood touched up, bought a new front bumper with new bumper shocks, had a new OEM trunk installed, had the passenger rear quarter panel and tail light pocket completely rebuilt, and bought a new rear bumper and bumper bar. When I had the front of the car apart I upgraded the radiator, the water pump, thermostat, and oil cooler. I took the vehicle to International Autos for a complete scan on their body scan system to confirm that the “safety box” of the vehicle was unchanged and square. It was confirmed that it was square and fully intact. All of the body work was performed by a professional. There is no record of the accident on the vehicle history report (carfax) as the incident was not reported to the officials (accident was on a racetrack not on a roadway)
    Modifications
    Engine
    AFE Stage 2 CAI
    VAC Underdrive Pulley Set
    CPV replaced 2013
    Vanos Filter replaced 2013
    Polyurethane Motor Mounts
    A/C Delete
    Secondary Air Pump Delete
    Cooling
    New Water Pump 2015 (updated plastic impeller)
    Lower (55 deg C) Thermostat 2015
    Silicone Radiator Hoses 2015
    SPAL Pull Electric Fan (Clutch Fan Deleted) 2015
    Mishimoto Aluminum Radiator
    Mishimoto Upgraded Oil Cooler
    Exhaust
    Status Gruppe Catless Header - This does cause a O2 error to trigger
    Bimmer World Mid-Pipe (I have both Resonated and Straight Pipes) – I currently have the resonated pipe installed.
    Section 3 is also the Bimmerworld Race Exhaust
    Suspension
    Height Adjustable Progressive Coilovers
    Turner Motorsports Front and Rear Sway Bar & adjustable endlinks
    Powerflex FCAB
    Powerflex RCAB
    Rear Subframe Reinforcement (Turner Kit)
    -The mounting points were in perfect condition when this preventative item was done – I have photos of this process
    Powerflex Poly Subframe Bushings
    ECS Tuning Adjustable Lower Control Arms
    Rear Strut Bar
    Cusco Front Strut Bar
    Front Camber Plates
    Corner Balanced (Big Bear Tire)
    Drivetrain
    Replaced Flex Disk 2014
    Polyurethane Transmission Mounts
    BMW 128d Euro Model Shifter (OEM BMW short throw option for e46 M3)
    ZHP weighted OEM Shift Nob
    Brakes
    Stoptech Stage 2 Upgrade (rotors, pads, SS lines)
    Motul 600 Brake Fluid
    Wheels
    Apex Arc 8’s – Matte Black
    Have OEM rims as well
    Tires
    4X – Dunlop Dirrezza Star Specs 275’s
    Interior
    OMP First R Seats (X2)
    VAC Adapter Seat Brackets (X2)
    Simpson 6pt Harness (X2)
    Scan Gauge 2
    Interior Strip/Gut
