    baseline run? or final result?  either way 300whp in an E30 is no joke!
    • AsparagusMikeA
      AsparagusMikeA
      AsparagusMike
      Final result. 330hp 316 tq 0n 8.5 psi at around 6000 rpm
        I like the Quiznos  "NOS" sign in the video.
        Let us know your driving impressions!
          300hp looks and sounds fun. Get some miles on it!
            I got a ride / drove this car this weekend.
            Holy balls batman, it is sweet.
            The car feels so good. It is smooth, the power delivery is smooth and linear, and the chassis feels great due to all the work Mike has put into it.
            And man does it rip, any gear, any rpm, you lean in the throttle and are immediately doing well over the posted speed limit.
            Great work Mike!
              winning!
                well done my friend! picnic or bust?
                • AsparagusMikeA
                  AsparagusMikeA
                  AsparagusMike
                  Yup I should be able to make it.
                    What turbo and manifold are you running again?
                    Edit: did you get a tq curve print out as well?
                    • AsparagusMikeA
                      AsparagusMikeA
                      AsparagusMike
                      Holset HX35 on a Rapid spool manifold
                      I suppose I should have posted this graph earlier, oops.
                        Sweet thanks veggiemike
                        would be interested in seeing that msq file 😉
                        manual boost controller? Electronic? Or just straight spranging it with boost reference directly to gate?
                        • AsparagusMikeA
                          AsparagusMikeA
                          AsparagusMike
                          Check your pm's
                          Electronic boost controller
                            If you're sending those MSQ's around feel free to hit a brother up!
                            Also, I think I know where your oil is going. Watched the dyno pull vid and saw the let off cloud
                            • AsparagusMikeA
                              AsparagusMikeA
                              AsparagusMike
                              Ya No doubt my car is consuming a bit of oil. I have been monitoring it frequently though and it doesn't seem to be much worse then it was when the motor was NA.
                              About a quart every 1000 miles... 1/4 of a quart give or take every 2 tanks of gas or 300 miles.😁
                                Do you have an oil restrictor in the oil feed line?
                                • AsparagusMikeA
                                  AsparagusMikeA
                                  AsparagusMike
                                  Not that I know of
                                    That could certainly be part of it
                                    • AsparagusMikeA
                                      AsparagusMikeA
                                      AsparagusMike
                                      Ok I lied, I actually do lol
                                        Are you running a catch can setup? Or stock style pcv system?
                                          Was nice bumping into you at WIR! Car looks and sounds great.
