  4. Chris’ e34 extravaganza
57 Posts 16 Posters 1.2k Views 2 Watching
    Yeah I agree. I would be hesitant to call it dead. Here's my 2 cents:
    1. Was there oil in the cylinders prior to you testing it? ( I know you know what your doing, but Ive made this mistake before) you said it was "dry." The end cylinders will have the most lubrication due to the path the oil travels through the motor thus higher numbers?
    2. Valves. If that thing is gunked up at all, very likely from sitting, the valves might not be seating completely altering the test. How long would your tester hold psi per cylinder?
    3. Rings wear, but being a N/A motor, I doubt they are bad, a headgasket is more likely and an easy job.
    4. Borescope; did you check to see how it looks in there?
    5. Nevermind, your right, its probably dead.
    6. Trade me the S38 for my M30 and I can swap it into my E24. This is really the only fair option considering you owe me a finders fee. 😎
    • RobZRR
      RobZRR
      RobZR
      Ain't nobody got time for that wagon business.
      I beg to differ!!😀
        @HipMF asking for the BAN hammer 🔨
          Haha! Maybe...
          I like wagons, but if I was building one I'd go for an engine with stupid torque. 260-270 ft-lbs in a car that weighs almost 4000 pounds isn't that great.
          A gutted e24 would be a good thousand pounds lighter and more likely to use the power at the top of the rev range.
            Haha! Maybe...
            Horsepower wins parts, torque sells races
              You need to put oil in the cylinders and recheck.  I have seen dry cylinder walls cause extremely low compression.  I had a flooded M50 show 30PSI on compression test and with a little oil it jumped back to 180.  It also wouldn't start because compression was so low.  I just cranked it over with the plugs out and injectors unhooked to dry the fuel away and added a squirt of oil to each cylinder and it started right up.  That was on my e36 a couple months ago when it was extremely cold out and had a failed start attempt.
                This.
                I had a two stroke inline 6 that had numbers roughly all over the board; 60,50,110,80,130. I was super worried. Added oil, rechecked compression and it was 160's all the way across. I was shocked.
                • RobZRR
                  RobZRR
                  RobZR
                  rampelsauce said:
                  Bingo.  Rebuild that S38 and make something that will make @DrLeadFoot feel bad about his S62 touring.
                  Here you go. find a perfect box for that S38 diamond like this one and make a nice faux M5.
                  https://fortmyers.craigslist.org/lee/cto/d/bonita-springs-94-bmw-525i-mint/6852122107.html
                  https://sanantonio.craigslist.org/cto/d/schertz-1995-bmw-525i/6848522043.html
                  • ChrisOC
                    ChrisOC
                    ChrisO
                    Sorry I haven't updated in awhile, very busy with school and weather is just finally getting nice where I wanna be in my garage
                    I appreciate all the suggestions from everyone, I'm going to put some oil in the cylinders and re-run the compression test. I also visited home this past week and grabbed my borescope so I can check out the cylinder walls and pistons.
                    I can easily hook up pressurized air to the hose that came with my compression tester kit so I'll do that also if the compression numbers are still low
                    For now I've been pulling the car apart, I had a moment today in the garage as I was gutting it (easily lost 400lbs today) thinking how cool it would be to rebuild it, completely simplify the car, cage it, put some light bucket seats in it and use it, until the carpet came up and the skirts came off
                    I had a lot of fun getting this skirt off. A PO jacked on the fender seam and bent the fender/skirt up into the body of the car with the bolt holding the skirt on smashed inwards. When all this shit fell out after the skirt came off I knew it was no good
                    Yeah its bad up front. Extending beyond this hole towards the frame rails under the undercoating is completely soft. The metal has rusted away just leaving a sheet of just undercoating haha
                    Can see the hole to the front right of the jack point, although it looks mostly intact it's made up of multiple layers of metal and they are all swollen with rust in-between the layers.
                    Rear wheel well, same story as the floor pan, completely rusted through under the undercoating up about a solid 6in beyond what you can see
                    random firewall rust holes on the passenger side
                    Hard to tell but this is a hole into the rockers
                    Same story but worse on the passenger side
                    Mysterious rusty puncture hole in the battery area
                    Yeah so I've played this game before and I'm not going to again. I'm sure the inside of the rockers is horrifying
                    Funny thing is though, parts of this car are really rust free, the rear jack points, pan and rockers dont even have surface rust. No rust on the quarters, no rust on the rear trunk lip, fenders aren't rusted through. This was a texas car until 2002, The rust is probably from sitting uncared for in a wet environment with trapped water for 11 years and not salt. Shame
                    Making progress
                    Idk what I'm doing with everything, I want the shell gone and all the regular e34 parts gone. I'm just kinda gonna hang on to everything M5 specific for now
                    It sucks doing this to this car, it really does. I feel bad every time my garage opens and you see such a special car with nothing but a M5 badge left on the rear.
                      sad the shell isnt a keeper!
                        I’m guessing that the door bottoms are torched after seeing all that rust?
                        • ChrisOC
                          ChrisOC
                          ChrisO
                          The front doors might actually be rust free I’ll check them out, one of the rear doors has a massive dent
                            Sad day. Yeah that thing is pretty gone. I feel your pain. Its crazy how much damage can happen from moisture.
                            At least you won't lose money with the parts from it.
                            Curious to see the new compression numbers.
                              I wonder if you can retrofit the ITBs to fit on an S52.
                                Yeah let me know, the fronts on mine started showing a tiny bit of rust hidden under the door trim this last winter. Also might be interested in the driver rear window regulator and motor.
                                @Rekpoint the bore spacing is different so they wouldn’t line up perfectly without some sort of adapter, and they’re likely too big for that motor anyways. You’re probably better off buying an ITB kit specifically for the s52.
                                  It was worth the chance,
