  4. The E46 M3 Journal
The E46 M3 Journal
536 Posts 34 Posters 0 Views 1 Watching
    And that’s why they call you doctor, nice job!
      Diff and trans fluid change!
        New trunk!
          I love it!!!
          is that CF or steel?
            snap said:
            I love it!!!
            Fiberglass mold of a (hopefully) CSL trunk. Needed some love to fit well but close enough for me.  I'm loving it.
            Additional update: KW Suspension has my rear shocks and they are inspecting them.  Should get 2 new ones under warranty as one is leaking.  The rear springs lost their spring and they replaced those under warranty as well.
              CSL trunk looks great!
                The trunk color is a shade lighter than the car but not that much of an issue for me.  Excited to drive it soon!
                  that looks fantastic
                    Rebuilt shocks installed!
                      Sliding back into daily use!  LOVE THIS CAR!
                      Milo likes it too.
                        Burning gas!
                          CSL trunk is so good! 😱
                          are you running wheel spacers?
                            Thanks!  I'm liking it!
                            10mm rear with 255, 12mm front with 245
                              Yep. Take notes
                                Been out of storage for about a tank of gas.  The battery had power but not enough to crank.  A quick jump and on the road again!
                                Need some new rear tires and to go back to stock RTABs.  The polys are too noisy for me.
                                We are using the wagon for wagon things and swapped the kiddos seats into the m3.  A rear facing baby seat in a coupe is forced yoga.  Lol
                                  Are the RTABs squeaky or is it just the harshness. You will be out of the car seat phase soon enough. Moving on to boosters is like a breath of fresh air
                                    If they squeak they aren't greased well or with the right grease.  Once I greased mine properly they  made no noise.  I had UUC ones but I am sure they are all similar.
                                      Squeaks and thuds/rattling until they warm up and quiet down.  The recurring maintenance to grease them is what I'm not excited about.  Back to stock but will clock them correctly for the lowered suspension.
                                        You probably said it earlier but what brand?  I haven't had to re-grease mine in a couple years.  Are you sure the rattling isn't something else?  They should be tight enough that the poly stays tight in the trailing arm and the only movement is the sleeve turning in the poly.  I have seen some other designs that have an insert with a spherical bearing which is smart because it isn't completely a 1 dimensional movement at that joint.
                                          A couple new pieces for the M3!
