  4. Ummm.... So I took a chance. ***Now with Fire Content***
e21
45 Posts 14 Posters 859 Views 1 Watching
  • timmerT
    timmerT
    timmer
    It made it home... 😄
      Nice score.
      Curious what your plans are... Make sure you take care of the fuel system before you start messing with trying to get it started. Probably obvious given how long it's been sitting, but I thought it would be worth emphasizing since the CIS system on these cars is a fairly complex and delicate mechanical/pneumatic system that doesn't take well to rust or old varnishy fuel.
      Gettin' the popcorn ready.
        • timmerT
          timmerT
          timmer
          A little progress update as a result of not having keys...
          Did I mention how fun it is to navigate a non-running car into a garage with the steering locked and the front wheels at a slight angle?  A wheeled floor jack under the rear end ultimately saved the day!
          Got the ignition lock cylinder removed with a little persuading with the drill. Now to see if I can have new keys made to fit, or if I have to get new lock cylinders for the whole car...
          Meanwhile, the trunk is locked.  I’d like to see what surprises are in there!!  Anyone know of a way to get in?
          -Timmer
            BMW can cut you a new key from the VIN. I got one for my E30 a few years ago and it was about $40. I did need the title to prove I owned the car though
            • timmerT
              timmerT
              timmer
              Perfect, I’ll give it a try!  Is this something any dealer can do? The closest one is Bergstrom in Appleton for me....
              Thanks!
                Thanks!
                I would think so! I believe they just ordered it for me and I picked it up a few days later, I didn't have to give them an old key or anything. I'm sure if you called the parts desk they could tell you if they can get one or not
                  Nice deal for the money! that site is pretty cool. Im not going to lie, I spent some time sifting through other units in hopes for some gold.
                  • timmerT
                    timmerT
                    timmer
                    *** UPDATE...version Winter Storm Wesley ***
                    Im hoping to have her running soon!  I’ve tackled the fuel system...what a mess. New key is cut courtesy of Enterprise BMW, and I started cleaning up the interior a bit.
                    What the crap-wooly mammoth-fur stuff did BMW use to cushion the seats with anyway?  Years of sitting turned it into a crunchy, rust colored dust.
                    She was diagnosed with two frozen solid fuel pumps, and every fuel line held as much fuel as a cheese grater.
                    Luckily the tank is dry and in good shape; the new in tank pump is in, the external pump is out.  Just waiting for the fuel lines, fuel accumulator, and fuel filter to arrive to finish things up.
                    Im confident she’ll fire right up once reassembled.
                    Obligatory first fire up in 20+ years to follow.
                    -Tim
                      That fuel pump/accumulator looks like something from the great barrier reef
                        Excited for this!  The fuel pump setup looks just like on an early e24 that I worked on.  It's a pain getting the lines up over the tank to the pump, I think I used a small hose and taped the large one to the end to pull it through.
                        • timmerT
                          timmerT
                          timmer
                          *** UPDATE... Version I need a stiff drink ***
                          Good News!
                          On Wednesday night, I finished installing the new external fuel pump/accumulator/and fuel lines.  I disconnected the bajo bolt at the fuel distributor and flushed out the lines, and decided to give her a go.  Expert tip: I added pigtail wires to the new fuel pump so I wouldn't have to struggle to hook up the short leads provided by BMW under the car.
                          She wanted to fire up right away, but I assumed the the old gas had to get flushed out of the rest of the system.  She eventually ran, but was running extremely rich and I needed to keep my foot on the throttle to keep her running.  I hoped the fresh fuel mixed with fuel system cleaner would continue to flush everything out, and I kept her running up to operating temp and shut her down for the night.
                          I noticed the a banjo bolt was weeping fuel at the fuel filter, so I replaced the copper washer.  Everything else looked good!  I was hoping  a little more cleaning, and a mixture adjustment and everything would be good to go.  I also bled the brakes and got them working without issue.
                          Now, the bad news...
                          Yesterday I had half the day off , so I thought it would be a good time to work on the car a bit more since I work all weekend.
                          Things started off fine, the car fired up right away, but was still running rich and would not idle.  I kept running the car, hoping the new fuel and cleaner would do its job for about 15 minutes.  Things did not improve, so I decided to look into things further. I could not find any obvious vacuum leaks, or anything else, so I decided to try to start the car again.
                          The car did not start, and eventually stopped cranking.  I assumed the cylinders were hydrolocked with fuel.  I turned the ignition to the "on" position and jumped the fuel pump relay to discover the fuel injectors were spraying without the motor running.
                          I pulled the spark plugs, setting the wires to the side, and turned the motor over to clear out the fuel.  As fuel began shooting out of each cylinder I head a large "WOOOOOF", and approximately 6 foot flames were now shooting out of the passenger side of the engine bay.  Maybe I should have disconnected the coil before dousing the exposed plug wires with fuel?
                          I was extremely lucky.  I quickly grabbed a large wool moving blanket and was able to smother out the fire, not before singeing my beard and eye lashes.  Luckily the fire only  burned the insulation on wires for the ignition coil, and oxygen sensor, which were easily repaired.
                          After taking a little breather, and pouring a glass of Blanton's bourbon; I explained to my wife my foolish ways.  Needless to say she was not impressed.
                          I decided to call it a day.  I'll troubleshoot the fuel issues at a later time.  My thought is the piston in the fuel distributor is stuck in the open position a bit, feeding the injectors.
                          Lessons learned.  I need to take my time, have a plan, and always have a fire extinguisher handy.  You would think that a firefighter like me would know this?  It's easy to become complacent.
                          More updates, without fire, to continue...
                          -Tim
                          IMG_3536.MP4
                            Glad you're ok. That could have been really ugly to car, garage, and you.
                              Congrats on getting it to start up! I'm glad you got the put out quickly with no real damage or injury, that's some scary stuff...
                                Caveman - fire good
                                man cave - fire bad
                                Congrats on the successful revival!
                                  gives a new meaning to 'it fired right up'
                                  glad you and the shop are ok!
                                  • timmerT
                                    timmerT
                                    timmer
                                    SUCCESS!!!
                                    The old girl is idling on her own!  Still have some adjustments to do... there was a small stone lodged where the mixture screw is, and once I got it out, the screw is too tight for my makeshift extended 3mm Allen wrench to turn.
                                    I threw some penetrating oil on it to help loosen it up in the meantime while I go purchase a longer wrench.
                                    The O2 sensor was reading about .72 volts when warmed up. I’m confident once the mixture is leaned out she’ll run like a champ!
                                    Best part, no fire!!!
                                    Time for a Busch Latte...
                                    -Tim
                                    59BD0CA0-1FF9-4871-83F2-E3648E170001.mp4
                                    • 59BD0CA0-1FF9-4871-83F2-E3648E170001.mp4
                                      "It's idling, and it's not on fire". Sometimes it's the little things that make all the difference. 😄 Great job bringing this one back to life!
                                        Can't wait to see this driving down the road now!
                                        • timmerT
                                          timmerT
                                          timmer
                                          SHE’S ON THE ROAD AGAIN!!
                                          Well, it’s been since 1998, but the old girl is back on the road under her own power.
                                          Amazingly, she drives better than I thought!  Goes down the road straight, and most things seem to be working as they should.  It’s easy to tell the suspension bushings, and tie rod ends are cooked.
                                          20 miles so far, and looking forward to many more.😁
                                          -Tim
