330ci323cidrifte46
  • TkuhnT
    TkuhnT
    Tkuhn
    Mad respect man. Wrapping shit is a tough job! Looks GREAT!
    Thank you! Excited to have it all together and see it as one outside.
      Dat booty
      • TkuhnT
        TkuhnT
        Tkuhn
        Exciting package came in wayyyyy faster than I thought. This bad boy is straight from poland.
        Musk Customs "M-package" front lip. Its fiberglass, but oh my is this a quality and solid piece! Fit the bumper so well I could hold it up in the air by the bumper and the lip didnt even move.
        So hyped to get the bumper and lip wrapped and see this shit on the car on the ground!
        • TkuhnT
          TkuhnT
          Tkuhn
          Got some help from a friend that wraps things for a living tonight. Front bumper is done!
          Next up is the lip, might redo the rear bumper since I got a glimpse at a better way to do a bumper.
            This is looking great!
            • TkuhnT
              TkuhnT
              Tkuhn
              Wrapped the musk lip tonight. Sooo hyped to get this attached to the bumper and put it on the car.
                I like the wall decor !
                • TkuhnT
                  TkuhnT
                  Tkuhn
                  Yea I'm lucky the girlfriend is so supportive 🤗😜
                    Nice lip choice. Excited to see it installed!
                    • TkuhnT
                      TkuhnT
                      Tkuhn
                      Mounted the lip to the bumper after work today 🤘
                      Also got my parts in to rebuild the passenger side axle so I got that done and ready to go in the car. Once I get the axle in all I have to do is throw the exhaust back on (although I'd like a new one in the near future) and shes ready to put on the ground 😁
                      Also I dont think I shared this, not super exciting but I did replace the shift selector joint as well the other day.
                        Looking good. Always liked the Arqray lip.
                        • TkuhnT
                          TkuhnT
                          Tkuhn
                          After staring at the Musk one that I got and pics of the arqray one the musk one is more drastic. The curve inward is deeper and the bottom goes out further. Musk stuff is like that, they make a csl style trunk that is more aggressive as well. It has a taller sweep.
                          • TkuhnT
                            TkuhnT
                            Tkuhn
                            UPDATE
                            Installed the Hold Fast steering wheel my girlfriend got me for christmas.
                            Wrapped and installed the rear roof extension.
                            And I am soooo hypeddd to share this with you guys, first might I add!
                            Quite a few more loose ends to tie up but soooo excited to see this thing on the ground!
                              Wow, that looks fantastic!!
                                Looks great!
                                • TkuhnT
                                  TkuhnT
                                  Tkuhn
                                  UPDATE.
                                  Some bad news today.
                                  Last night we found out there was a problem with my clutch. After trying a few things including removing and installing the slave, rebleeding it and making sure the clutch fork hadn't fallen off or anything we found the problem. (Clutch pedal was hard as a rock immediately).
                                  My new pressure plate was the same as the old one which is a LUK self adjusting one. And after reading these can be flawed from the factory, the plate is fully adjusted which is bad. (The springs are fully extended)
                                  Sooo I was forced to pull the trans, again.
                                  Here you can see the difference. New one is on the right and the old one is on the left. Notice the difference in the self adjusting springs.
                                  Luckily things went pretty smooth and I had everything out in just under 2 hours.
                                  I will be contacting the company I ordered through but I have little faith that they will resolve anything due to their lack of replying to emails after my order. I may end up ordering a sprung disc with non adjusting pressure plate like I should have in the first place.
                                  I didnt let this get me down completely so I continued on to other things.
                                  I wanted to have the rear decklid covered last year but never got around to it, I ended up interior painting the old faded and nasty grey decklid cover.
                                  Then made covers for the speaker area and other hole in the top out of some plastic.
                                  Turned out pretty well.
                                   That's it for now until I figure out what my plan is with the transmission/clutch situation.
                                    MAN this looks sooooo good. Bummer about the pressure plate. Seems like it wont be that big of a set back though, just annoying.
                                    • TkuhnT
                                      TkuhnT
                                      Tkuhn
                                      100% annoying. Lol also seems that you can reset the pressure plates. Sooo I suppose I should try that.
                                      • TkuhnT
                                        TkuhnT
                                        Tkuhn
                                        Aight boyzzz. I devised a way to reset the pressure plate back to the install position thanks to a YouTube search. Some say to use a 3 jaw puller but the way I did it worked like a charm!
                                        First step was to make a hole on my work bench and then support the pressure plate mounting spots. I used some m8 nuts. Next was to devise something the size of the throw out bearing with a hole in it to allow a large bolt to be put through the bench and the pusher (which I used one of the old shipping locks from the pressure plates with the tabs cut off).
                                        Here's a pic of the hackery I set up.
                                        Then I set the pressure plate on the nuts, sent the bolt through the bench and set it up to pull the fingers on the pressure plate down. This is a pic of the fingers pulled down.
                                        Once it's to a certain point you can move the self adjuster with a screwdriver. I moved it all the way back into the install position.
                                        Then while holding the adjuster in the service position I backed off the pinch bolt set up and BAM! Shes back in the install position.
                                        So I did this to both pressure plates and ultimately I opted to put the old pressure plate back into the car with the new carbon kevlar disc.
                                        Here it is all installed back in the car, as you can see the springs are pulled all the way back which is how they should be.
                                        Soooo I could have put the trans back in but I decided to not be a lazy sack of shit and I ordered the detent pin rebuild kit for my trans. (I totally forgot that they should be replaced when we had it out the first time.) Hopefully that shows up by the weekend so this large step backward can be done by Sunday night lol.
                                          Piece of cake.
