  4. A 1997 e36 M3 that I shouldn't have bought :/
46 Posts 10 Posters 0 Views 1 Watching
    What do you mean by "not draining properly"  It should not drain out the housing if the check valve is working.  Mine is leaking and causes a rattle for about 10 seconds on startup.  I bought a replacement but haven't had time to install it yet.
      Replaced the oil filter gasket. Started dropping the sub-frame today. Hopefully I can finish the job and put it together tomorrow.
        Full subframe was dropped last week. And this is what I found....
        @GunMetalGrey called it..
        Stupid nut.
        It will be put back together, new tires will be installed and it will be for sale shortly as I have nowhere to store it for the winter.
        what a PITA
        Side note add me on Snapchat if anyone is interested in what Rekpoint does day to day...
        SC : Rekpoint
          Update. Has been sitting in my driveway waiting to be driven. I need to pump old gas out of the gas tank and get some new stuff in there.
          Hopefully we stop getting snow here soon so I can sell it.
          What does everyone think about price?
          I was thinking 4300 OBO
          Based on whats done to it and how many miles it has Id like to hear some opinions. It has some rust., comes with a new hood at asking price etc.
            What was the whole story on the oil pump nut?  How long did it run without oil pressure?
              Not long. He was driving and the ECU cut power to the engine because of no oil pressure.
              Disconnected the ecu and reconnected It and it fired right up.
                The ECU doesn't know or care about low oil pressure, page 6211.0-00 of the ETM shows that the pressure switch does nothing but light up the light.  Did you pull a bearing cap while you had the pan open to see what they looked like?
                http://wedophones.com/Manuals/BMW/1997 BMW 318is-c - 328i-c Electrical Troubleshooting Manual.pdf
                  IN TRA DUST ING  🤔
                    Unfortunately I didn't. I ran a magnet in the pan for any metal shavings and it came out clean.
                      I doubt you would see any metal shavings.  Bearing material isn't magnetic anyway.  You should put some miles on it to see if it seems normal otherwise anyone that knows what happened wouldn't touch it with a 10 foot pole.  It might be just fine and then you can sell it for possibly more rather than someone considering that they might need to put a different engine in due to running without oil pressure.
                      I'm not trying to be rude but I wouldn't buy it for $2000 knowing what's happened to it.  Now if you had driven it 5k miles since then without problems then my concern would be much lower.
                        Might be a good idea to get 3-5k on it and do a Blackstone labs oil analysis, that would likely tell you if there is any excessive wear going on.
                          Totally understandable. I put a few miles on it before it started to snow and I didn't notice anything out of the ordinary. But Ill do some more driving with it to see if anything is out of the ordinary.
                          If worst comes to worst ill part it out. Ideally i wouldn't because I have a few cars coming my way but I gotta do what I gotta do.
                          Ill probably be doing that.
