330ci323cidrifte46
  • TkuhnT
    TkuhnT
    Tkuhn
    Boris3 said:
    Looks good! I don't have the expertise to ask the question correctly but is there any need to reflash the LCM/ECU, or will the changed setup just plug and play?
    That has crossed my mind lol. I believe the my will still work for sure. Just not sure how the car will react, like it might think that the headlights are burnt our or something since the data being sent back would be different. It might just say theres a headlight burnt out or something. I need to do the end of that research yet. Either way I know it can be coded in if that is a problem, just need to do the research to get that knowledge. I was going to try and plug it in but the battery is not in the car since my garage isnt heated and I didnt want the battery to freeze up haha
      Hope it works, it'll mean that bits from the burnt bowl ZKW bixenons I pulled from my car might actually be worth something.
      • TkuhnT
        TkuhnT
        Tkuhn
        So a quick search said multiple things. I have AL headlights so not sure how it applys to ZKWs but some said pre 03 (chassis) you dont need to code because the newer chassis have some sort of difference. Others said you have to code the light module for a xenon low beam and some other procedure to make the halogen high beams work. Apparently it can all be done using a NCSexpert. Which I have ZERO experience with lol and I am on the lower end of computer savvy in that sense.
          I swapped in oem xenon headlights in a prefacelift e46, which were a direct plug in. Everything functioned perfectly, just had a headlight error until I turned them on. Didn't bother me enough to recode.
          • TkuhnT
            TkuhnT
            Tkuhn
            Good to know! I'd like to learn to code either way honestly. Have you dabbled it it at all?
              I swapped some OEM Xenon headlights into my girlfriend's 2002 E46 sedan that came with halogens. Just unplugged halogens and plugged in the Xenons. Everything functioned as it should, no errors lights either.
              • TkuhnT
                TkuhnT
                Tkuhn
                Bitchin' hopefully I have the same results. Although it would be cool to learn to code so I could add some features. I also would like to get my key matched to my car since i swapped everything from my 330i and the fob wont unlock the car with the power locks. But not sure that you can fix that with coding
                  I've got a laptop with all the coding software but never even really bothered giving it a shot. You're welcome to play with it if you want.
                  • TkuhnT
                    TkuhnT
                    Tkuhn
                    I'll keep that in mind, theres a really good video tutorial I found on YouTube that a guy talks you through getting the software all the way to coding some things.
                    • TkuhnT
                      TkuhnT
                      Tkuhn
                      Decided to make some room in the rear today. While I'm not hammered low and my fenders aren't super rolled there was a few rubbing issues due to some of the factory bump castings I suppose you could call them inside the rear wheel wells. Hacked out some metal and made some relief cuts.
                      Forgot to take a before of the passenger side.
                      While realistically the best thing to do would be to weld them, I dont have a welder at the house. I was able to get the ends very close the the outside panel and they are much higher than before creating alot more room. I seam sealed the passenger side and need to do the driver side still. So I'll post photos when that is done!
                      • TkuhnT
                        TkuhnT
                        Tkuhn
                        Finished up disassembly, cleaning and swapping in all the xenon stuff on the other headlight yesterday. Also got my new lenses! Super hyped on how good these look all cleaned up with new lenses.
                        • TkuhnT
                          TkuhnT
                          Tkuhn
                          And it has begun 😍
                          • TkuhnT
                            TkuhnT
                            Tkuhn
                            Got a few part in the mail recently. No photos but nothing extremely exciting. The new clutch came in, intake manifold gaskets, a cv boot rebuild kit and a rear plastic thing (idk what the proper name is haha) and then the covers for the low beam side of my headlights.
                            Also got my abs plastic in to finish the rear bulkhead too. Used my CAD (cardboard aided design) template traced it out and started cutting.
                            Got everything trimmed right then drilled some holes. Used M5 nutzerts and some stainless M5 hardware to secure it.
                            • TkuhnT
                              TkuhnT
                              Tkuhn
                              UPDATE
                              Finished up sealing the rear inner quarters that I cut to make some room. Only got a photo of the right side but you get the idea. Sealed the cuts with 3M seam sealer and then sprayed undercoat over everything.
                              Also finished up the evap delete. Looped the vent and installed an inline filter to keep dirt out. Found a great write up on the evap delete for e46 on another page.
                              Vented from the filter up as high as I could since there is alot of debris whipped up from drifting. Not sure if I shared a photo before but I also removed all of the evap lines from the back to the front of the car along with the canister from the rear.
                              Also wrapped the roof, and this color is so hard to show in photos but I'm hyped.
                              Here's one of the new M skirts wrapped as well.
                              • TkuhnT
                                TkuhnT
                                Tkuhn
                                Wrapped the passenger side of the car today and damn does this get me even more excited.
                                And of course I was itching to see what the clear tails looked like.
                                  Cant like this enough. Cant wait to see it all white!.
                                  Image result for henry gif
                                  • TkuhnT
                                    TkuhnT
                                    Tkuhn
                                    Got a new phone, galaxy s10 and this camera is fucking dope. Wide angle option makes taking photos of the car and parts so much more fun hahaha
                                    And got the driver side fender wrapped tonight as well.
                                      I vote you wrap the lips of the wheels white too.
                                      • TkuhnT
                                        TkuhnT
                                        Tkuhn
                                        That would be awfully bold lol
                                          Not sure if that means you're not bold? or.....
                                          Either way, I think it would look hawt.
