  4. chit chat thread
chit chat thread
    Well the e36 wouldn't start.  I have the battery charger on it and a heat lamp under the engine.  I really should just get an oil pan heater...
    Same with the M3. Good thing my boss made the last two days discretionary.
    • N
      N
      Nick_F
      Any 335 experts on here? Looking for some troubleshooting help for power loss
        I don't know about experts but a few of us are familiar with owning an n54/n55 so you could say we're familiar with fixing them since "kinda broken" or misfiring tend to be their favorite states of being.
        Do what are the symptoms.  Any codes?
        Edit: there actually is one expert on here but he hasn't frequented the site recently.
        • N
          N
          Nick_F
          No codes just running sluggish. I'm leaning towards spark plugs since I'm at the maintenance interval with 64000 miles.
            That's a good place to start in that car.  Have you had the carbon cleaned yet?
              Carbon buildup isn't as common on N55 as it is on N54, but still something to check. Spark plugs/coils might help, but it seems weird to me that you aren't getting any codes.
              Since you have MHD, can you share a log of a pull?
              • N
                N
                Nick_F
                I havent done a carbon cleaning since the dealer told me with the n55 it's less of an issue and should be done around 100k. Plugs should be here in the next few days but I didnt order coils. If the plugs dont fix it that might have to be next. I cant do a log since I didnt purchase that part of MHD but starting to think I should.
                  If you plan to continue modding/maintaining the car, logs are a good thing to get familiar with. Wouldn't hurt to purchase that module if that's the case.
                  • N
                    N
                    Nick_F
                    Ok I'll have to start researching how to efficiently take logs. I did just buy coils so I'll have peace of mind that everything is new.
                    • N
                      N
                      Nick_F
                      So I was leaving working and started my car just for it to fall on its face and stall. Started it again and all was good besides the sluggish performance. 40 minutes later I was leaving the vendor I went to meet with and got a service engine soon light.
                        Make sure the exhaust burble is turned off.
                        It has nothing to do with your issue, but just make sure its turned off.
                          Since you recently messed with the charge pipe and TMAP sensor, I'd start there. Check all charge pipe connections, check to make sure it is connected to the throttle body properly with the C-clip.
                          • N
                            N
                            Nick_F
                            Yea I'll be looking at that tonight. I wonder if I damaged the Tmap when it wasnt fitting. I didn't have these issues up until yesterday though which is a little strange.
                            • N
                              N
                              Nick_F
                              Yea burble has been off since the first day I tried it.
                              • N
                                N
                                Nick_F
                                2019-02-06 17_40_03 98G0B v1.53 Stage 1 93oct_98ron.csv
                                • 2019-02-06 17_40_03 98G0B v1.53 Stage 1 93oct_98ron.csv
                                • N
                                  N
                                  Nick_F
                                  2019-02-06 17_35_45 98G0B v1.53 Stage 1 93oct_98ron.csv
                                    Create an account on Datazap.me, upload it there and then post the link.
                                      It's cool that it's a CSV file, because it makes it look like I'm actually doing work right now.
                                      Not that familiar with these engines, but I can see you're not hitting your boost targets. Fuel rail pressure drops about 10% during the pull... not sure if that's normal. Timing is also really low if that's total timing and not a "correction factor" or trim value of some sort...
                                      • N
                                        N
                                        Nick_F
                                        https://datazap.me/u/fnick123/e90-n55
                                        I hope this works
                                        • N
                                          N
                                          Nick_F
                                          Here is a better log that I did a full 3rd gear pull starting at ~3k to ~6.5k
                                          https://datazap.me/u/fnick123/full-3rd-gear-pull?log=0&data=3-14
