  3. Cars For Sale & Wanted
    AsparagusMike said:
    Mileage is a bit on the high side but overall not a bad price for a S50. Would totally pick it up for a spare if I had the extra $
    https://chicago.craigslist.org/nwc/for/d/prospect-heights-s50-engine-manual/6803879281.html
     I've gotten the idea in my head of a s50 in the e34 someday and I can't get it out. This isn't helping.
      I can see the no modifications is going well 😂
         I've gotten the idea in my head of a euro s50 in the e34 someday and I can't get it out. This isn't helping.
        Fixed.
          ^^^^ this ideally. Gotta wait till after college, but what a fun sleeper it’d be. Not sure if it’s be quite as drop-in easy though. From what I’ve read, the U.S. s50 is a bolt-in affair, just plop it in, change out the DME and let ‘er rip.
          • vng704V
            vng704V
            vng704
            Might be a good buy. I haven't seen it myself. '95 8 series https://www.facebook.com/marketplace/item/254301832130482/
              Dang that's the cheapest I've seen an 8 series in a while
                Can't sleep. Anyone want a crashed gt40?
                https://www.iaai.com/Vehicle?itemID=30816316&utm_source=facebookus&utm_medium=social&utm_content=20190203%2Bpost%2Bphoto&utm_campaign=general
                • wally509W
                  wally509W
                  wally509
                  Interesting, I thought you could buy turn key replicas for how much they want for this wrecked one?  Unless the RCR ones are that much better than era or Superformance, but I don't see how that could be as I remember my buddy who knows a lot about GT40s once said the Superformance replicas were closer to the original cars than even the Safir continuation ones were.
                  The RCR "deluxe plus" GT40 kit is not even $50k.
                    https://chicago.craigslist.org/wcl/cto/d/homer-gleni-e30-autocross-track-car/6811137265.html
                    It looks a little rough but it has a pretty nice list of parts (e30 m3 suspension swap, etc)
                    • ChrisOC
                      ChrisOC
                      ChrisO
                      This thing looks awesome
                        This dude must have had an obscene amount of projects and got bitched at by his wife or is trying to sell everything to buy something else.
                        Wouldn't be browsing Milwaukee or Chicago CList without seeing that house/driveway at least once.
                        My point remains.
                          first off, who the hell cuts the bulkhead at the rear seats?! its structural!
                          oh yeah, that's right, homer glen guy would. he thinks he knows everything about e30s
                          that car is way too crusty for 7k. the sunroof delete is taped on.
                            Thank you!  Looks like junk to me.
                              There are issues here but again not a surprise.
                              In addition to structural issues, the bulkhead removal raises a safety issue with the battery placement in spare tire well. The battery needs to be fully enclosed in a battery box for the safety of the driver. Any decent organization would fail the car in tech.  Hoping the jumper cables were just to start and not a permanent fixture (still, running the cables through the car rather than removing the truck lid raises other questions, maybe "quicker'?)
                              The tape over the top of the sunroof panel might be OK if the panel is welded or riveted to the roof skin. Looks like the latter. My panel has welded on brackets that are bolted to my cage, and has seam sealer and gorilla tape over the seams to keep out the water when it rains.
                              I'm assuming the rear trunk clips are because of the gutted bulkhead but if you want weight reduction it would be much better to remove the front hood assembly and use clips there.
                              Similarly replace the front comfort seat and slider which weighs a lot and offers no support at all for autox or track.
                              The coil relocated to the top of the passenger fender well could be OK as long as the bracket is bolted through so the coil doesn't come loose. Coil coming loose and banging against the exhaust headers can fry the car's electrics.
                              Heater core is pulled which is fine, but given Wisconsin you'd want some setup to deal with defogging the windshield.
                              Taped over hole to the left in the passenger floorboard could be to get access to trans fill hole to run a fill hose? Useful if the case.
                              If you could pick this up for $3-4k, there is potential. The suspension bits are a plus. Go through it thoroughly to make sure everything is OK mechanical and electrical. Get it up on a lift to check structure and rust. There's been some repainted stuff out of Homer Glenn covering some poor body conditions. You'd also want much more detail on who did the stroker rebuild and how well it was done. Battery box or weld in a new bulkhead depending on who you plan to run with, cage it or add a roll bar at minimum, pick up a used race seat, harnesses, etc., and you could have a fun toy.
                              By that time / price point though there are other things you could have bought.
                                Not sure how I missed the cut bulkhead.... it wasn't even done cleanly, just hacked out.
                                I think my eyes glossed over because I want the coilovers and K1's.
                                • RobZRR
                                  RobZRR
                                  RobZR
                                  I know it's not an E30, this is what I call the Ultimate Driving Machine.
                                  https://bringatrailer.com/listing/2001-bmw-740i-27/
                                  • ChrisOC
                                    ChrisOC
                                    ChrisO
                                    That thing is so cool, but $36k and rust spots 😓
                                      Rust spots be damned!  Take my money!
                                        holy hell
                                          Yeah I’d still buy it, that’s a sweet build
