  4. Metallic Blue w/ m50 powaaaa
62 Posts 12 Posters 1.0k Views 1 Watching
  • StewCrewS
    StewCrewS
    StewCrew
    someone said:
    Cruise craigslist all over to see if there is anything nice on there. I've seen a few nice 4x100 rare wheels up lately.
    Yeah Milwaukee CL has been kind of dry lately. I've been on Chicago CL a lot along with jdmchicago.com. There's a lot of low offset wheels that are 15's, but nothing wider than 8". With the 17x9's I'll be able to have my rears all the way down with a little fender pulling. I'd also be able to throw some nice rubber on compared to the stretched tires on my last set of wheels.
      17's usually look way to big on an e30. 16's are perfect in my opinion.
      http://milwaukee.craigslist.org/pts/3260956471.html
      • StewCrewS
        StewCrewS
        StewCrew
        I was concerned about them looking huge too, but the 17" thread in r3v is very convincing lol. I'm not getting 15s again though. 16/17's with a higher offset so I can raise the car a little bit without it looking super weird.
        • StewCrewS
          StewCrewS
          StewCrew
          That sounds really contradicting. I guess this is my mentality: my 14" bottle caps with winter tires makes the car sit significantly higher than my 15's did. So I'm leaning towards 16/17's with nice tires and higher offset, and to then lower the car from there.
            StewCrew said:
            No problem at all! It was nice to meet you guys and Im glad you figured out what was wrong with the car. I just wish I went around front with you guys to hear it! That car is so cool, and Brian's car being completely mint, you guys probably attract a lot of attention driving around lol.
            Definitely need to get one of these. Seems almost full-proof.
            Im considering getting a staggered set of 17x7 17x9 xxr 962s (the fat 5 style). Anyone have any input on this? Other than that theyre xxr's? Hahaha
            We were driving with a white 1M for a couple miles on the way over. I attempted a thumbs up but the dude didn't even acknowledge the peasants in the two old skool BMWs next to him. I have actually only seen 1 person who has given a crap about my car and that was another E30 owner. He pulled up alongside at a stoplight and we simultaneously gave eachother the same thumbs up with the same cheesy smile which caused extreme awkwardness. I couldn't stand him being in my peripheral after that event. I guess I cant handle random interactions with other enthusiasts on the road.
            • StewCrewS
              StewCrewS
              StewCrew
              Wow, didn't even acknowledge you guys? That's lame.. And yeah I know the exact awkwardness you're talking about. When I had the evo, whenever I'd pull up next to another evo8 I'd straight face it and tell them they had a nice car. The usual reply was "Ahh, ha oh thanks ha"
              • StewCrewS
                StewCrewS
                StewCrew
                Turns out my oil pan is not cracked. There was a loose bolt on the front case where oil was dripping out of that made its way to my skid plate. Tightened a few bolts, wiped everything down, blah blah blah, everything seems fine at this point. I definitely smashed the plate though as theres a huge spot of paint missing. Nevertheless it seems to have worked! Also, I sold my wheels and ordered up a set of 17x7 +40 17x9 +35 xxr 962. Looks like Ill have some fender rolling to do soon!
                  Let me know if you need a fender roller, I just ordered one this morning:D
                  • StewCrewS
                    StewCrewS
                    StewCrew
                    Not bad! Have you used one before? If not you're more than welcome to get some practice in my car!
                      Yeah, I did the rears on my M3
                        StewCrew said:
                        [ATTACH=CONFIG]465[/ATTACH] (for all my futurama dweebs like myself)
                        depending on your tire size/spacer size, you wont have to touch your fenders.
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          Cool. I may be hitting you up then!
                          What size tire would you recommend? I'm not concerned with the fronts. But the rears I'm kinda lost about. I've never had a wheel wider than 8", and that had a 195 tire slightly stretched. I was thinking maybe a 215? I don't know much about tires so correct me if I'm wrong.
                          • StewCrewS
                            StewCrewS
                            StewCrew
                            Looking up different tires size on 9" wide wheels, 215/45 doesnt look too bad. Any input?
                            • StewCrewS
                              StewCrewS
                              StewCrew
                              My wheels finally came :D XXR 962 - 17x7 +40 up front and 17x9 +35 in back. The rears actually fit fine but Im running a 5mm spacer just to be safe. The fronts however.. I need to order up some extended lug studs and bigger spacers. The high offset blows but whatever, itll sit really nice regardless. 80mm studs and 20mm spacers is whats needed! Getting tires on them early next week and hopefully driving on them by the weekend!
                              Posted Image
                              Posted Image
                              Posted Image
                                VERY NICE! Those are definitely my favorite style of wheel from XXR. Are you going to make it to the Kettle Moraine drive Oct. 6th or the meet at Rampelsauce's place on the 20th?
                                Any idea what the weight of the 17x9 is? Not expecting it to be feather light, just curious.
                                  When do we see the turbo, and drag radials? :)
                                  • StewCrewS
                                    StewCrewS
                                    StewCrew
                                    Thanks! Yeah theyre a basic style of wheel but look so good! If nothing catastrophic happens at the drift event tomorrow then I should be able to make it hahaha. And I'll get the weight of one of the 17x9s for you bud.
                                    Hahahah we'll have to see about that xD
                                      StewCrew said:
                                      drift event
                                      WHERE?!?
                                      I would run my car in a drift event.
                                      We better see some pics/videos of this
                                      • StewCrewS
                                        StewCrewS
                                        StewCrew
                                        WHERE?!?
                                        Columbus 151 Speedway in Columbus, wi! Today from 10-5! $20 covers drifting all day as long as you have the tires! Only rule is you need to have a helmet that covers your whole head, like a motorcycle helmet. And don't worry my go-pro is ready to rock :)
                                        • K
                                          K
                                          krautuner
                                          badass E30!
                                          e2526838-2d06-47c6-87b1-e8cf6c8c570ezps
