  4. Finally Joined the Longroof Club
328itn52e91
156 Posts 22 Posters 3.2k Views 1 Watching
    did you match plate numbers?
    Yup! I went for the collector special plates that have the same number as my collector plate, it was like $15 more at registration so I figured why not, sort of fun.
      78.5k
      With a couple inches of snow in the forecast for Friday I made the switch to the snow tires off the e36. I won't be raking in the Instagram points with these but thankfully it doesn't look as awful as I thought it would. I lost the screws for the center caps so I'll have to find some new ones. TPMS light is on (no sensors in the wheels) so I may look into coding that out, an emulation module, or just ignore it. Ignoring is the cheapest and easiest so that's probably what will happen.
      #fitment
        Thats what I call fitment 😁
          figment
            78.7k
            Friday was probably the first time the car has ever sat in below-freezing temperatures for an extended period of time. I started it up after work and it went like this: *ding* standard sub-37F 'its cold' reminder, *ding* TPMS malfunction (snow tires).........*ding* low coolant warning....*ding* brake lamp failure.  Nice.
            Low coolant is likely just from thermal contraction, I haven't found any signs of leaks but topped it up and will keep an eye on the level. Turns out the brake light bulbs are some goofy type (P21W/1057/7506) that napa, o'reilly's, and even batteries plus bulbs didn't have, had to order new ones online.
            Driving around in the snow on Friday was entertaining and I didn't have any issues with grip when needed, I'm glad I went with the sportier RWD versus getting an xdrive. An xdrive on snow tires would be a beast though that's for sure.
            I also popped in a new serpentine belt and idler pulley on Saturday. The tensioner was replaced in the last year, but the belt and idler were original and definitely due for replacement. Next on the list is the valve cover gasket and water pump/thermostat.
              79.2k
              Lame update: I changed the oil with BMW 5w30 over the long weekend. Got a car wash too, it was clean for about an hour and now it's filthy again. That is all.
                a lame update is still a good update in touring land.
                  80.5k
                  Minor updates and improvements for daily life!
                  There was no place to keep a pair of sunglasses, so I added a euro-market glasses holder that replaces the oh sh!t handle on the driver's side
                  Added some front and rear OEM rubber floor mats to keep the salt out of the carpets
                  And I also realized it was missing some fairly critical badging so I got that sorted too
                    That sunglass holder is sweet!
                      I agree, that is pretty nifty.
                        Agreed! I was pretty excited when I came across it, it's a surprisingly convenient spot for it. Only issue I've found so far is I might smack it with a helmet on, but it would take 5 seconds to swap out if needed so it's no big deal.
                          can you measure the dims of the mounting screw locations of the glasses holder?
                            I see what your doing here...
                              I'll grab some after work!
                                150mm center to center
                                  Randomly stopped by a junkyard in Oshkosh as I was passing by on Saturday to see what I could find. They had just gotten a 2006 330i that was hit in the front so I snagged the 3 stage intake manifold with both (untested, so who knows if they work) DISA valves for pretty cheap. It wasn't too fun to pull while it's 5F outside, but the 40hp bump will be worth it!
                                  A little PSA for anyone doing this swap: There are two types of 3 stage intake manifolds. The manifolds on n52 cars built prior to early 2006 have a single port for the oil separator and won't be a direct swap on any of the later cars. You want the dual port manifold. I learned this after pulling/buying this one and thankfully it is correct haha
                                  Bonus winter pic:
                                    Any more wagon pics/updates?
                                    I love this thing!
                                      I love this thing!
                                      Nothing exciting, just driving it a lot! Definitely have some maintenance to do as soon as it starts getting warmer. I haven't taken any good pics lately but my dad snapped this nice one last weekend:
                                        Thats a pretty epic pic!
                                          Yes! That’s wallpaper worthy
