  4. Shop Life 2.0
Shop Life 2.0
nochristmasjazz
    Didn't mention it earlier because I didn't really believe it, but I put the car on a second truck scale and it seems to agree with the first. First scale said 2320 with me in the car and half a tank of fuel. 2nd scale said 2380 with me, almost a full tank, a bag of tools and a couple other miscellaneous items. So roughly 2150 without me and half a tank. Still need to add some metal to the trunk, but that's a couple hundred pounds lighter than I was expecting...
    Fantastic!  Wow that is light.
      This is also a couple hundred less than I would have guessed!
      What was the first aluminum block 4 cylinder from BMW? N20? Hah
      as sac religious as it always is, a honda F20 would be a magical swap in that chassis
        S14 would be the ideal swap. F20 is the affordable equivalent and has definitely been on my radar from the start.
          F20 is a pain, get a K20 with an adapter plate, have endless loads of joy.
            Care to elaborate? Glancing at numbers they seem to be lower redline, and predictably less horsepowers, but otherwise pretty similar. I haven't really researched it much, so have no idea of the benefits of either engine, or what it would take to make either of them fit in the chassis...
            Since I already have a decent stockpile of parts, the current plan is to just throw a small turbo at the M42 with 8-10 psi and see what happens. I'd love to have a high-reving temperamental 4-cylinder though. I think the sounds and driving experience would really fit the car as it is now, but in the long-term I can see myself turning the dial on this project back down from 11 and trying to put some driveability and refinement back into the car. In terms of around-town driveability and autocross performance (pretty much all 2nd gear at a variety of rpm) the torque of a small turbo makes more sense than a high-reving NA. Not that you couldn't boost a Honda, but keeping the M42 just feels like the right think to do.
              It really all depends on what you are building the car for, and how you feel about the power plant. I like Japanese engines because of the reliability so I tend to favor them. I also love odd swaps and out of the norm modifications. I suggest the K20 over the F20 because of aftermarket support, lower price point, readily available parts, and the early F20's had oiling problems. You will see that even a lot of Honda guys favor the K over the F. As far as reving goes, keep in mind that you can swap blocks and heads around to make power differences as well (similar to M20 strokers). Just spend some time online looking at comparisons and you can help build a good decision Im not sure which is lighter, but I bet its not the M42. 😄
              http://www.superstreetonline.com/features/htup-1010-2003-honda-s2000/
                Car looked and sounded great out at the autox, Mike. Also, nice driving! You're a faster driver than me, thats for sure. Thwarted by another m42 car!
                Hope you dont mind if i post these here:
                  Great shots Dan!
                    3rd image that shows both cars is my favorite. In an attempt to be relatable: My old E30 did its first autocross yesterday.
                    ahem.
                      'tis the season
                      qxCJWWD1FEyV63zdVburUvMdaNkVv3l-g-ATwmb
                      Took it for one last spin Saturday morning to pick up some mini tacos and an engine cart, then backed it in and yanked the motor.
                      This year's plan:
                      Raise engine/make sure driveline is straight. (Oil pan hangs really low right now)
                      Swap the bottom end for one that I have in storage that's in better condition.
                      Remove some rust that's left in the trunk and weld in an actual trunk floor.
                      Turbo
                      Additional things I may do if i get bored with those things, or I'm avoiding working on them for some other reason:
                      Make the ends of the rear flares blend with the body nicer
                      Grind/filler/paint rear flares
                      Make rear portion of side trim fit somehow
                      install carpet or something in the rear seat area, or just paint... not sure
                      Front flares. Probably not gonna happen this year, but who knows
                      Should be fun...
                        Dooo ittttt
                          Dooo ittttt
                          4GLTE swap, coming right up.
                            JOIN ME
                            https://chicago.craigslist.org/sox/pts/d/1jz-twin-turbo-and-r154/6730382005.html
                              JOIN ME
                              “Everyone wants this motor do not want my time unless you have cash in hand.”
                                JOIN ME
                                Toyota engines have a reputation for being heavy, and since it's 2 cylinders longer all the extra weight is in front of the front axle, so.... No.
                                Currently looking into standalone ECUs. Lots of research to do, but currently leaning towards Haltech.
                                  JOIN ME
                                  Why is there a V8 badge on the front of the 1JZ?
                                    I know of an MS3x setup that you could obtain for a very reasonable cost, with untouched wiring looms for it.
                                      I know of one of these as well with built internals for a really good price. Friend of mine is just too lazy to list it.
                                      You cant see the rest of it because the radiator hose is blocking it. it reads like this:  "I can beat your V8"
                                        I haven't ruled out MS, but people around this forum don't seem to have had much luck with it...
                                        Haltech seems to have some decent support, and the software looks easy enough to use, which is probably the most important factor for me right now.
                                          Can't tell if joke or...
                                          I never had issues with MS, it was always stuff wrong with mechanical things or my setup (ground wire locations lol)
                                          I haven't heard bad things about haltech, or good things, or really much at all. I do know that it exists though!
