@GunMetalGrey , @HipMF, and I got together this weekend and I had a friend of mine at Noggle Photography shoot some pictures of our cars. Need less to say it was a blast and we hit a couple local spots in Madison. I have just a taste of images to share, but we visited an airport, cement factory, abandon house, and some unpaved roads. @GunMetalGrey Was able to concur a massive water feature , and I found a complete E36 M3 bumper in the middle of the woods.
http://noggsphotography.com/ did exceptional work, I cant wait to see the rest of the images.
Twas fun hooning around with you!
If you do decide to lift it I will lend a hand! -
If you do decide to lift it I will lend a hand!Hell yeah!. I need to fix the heat and finds tires first, but I will let you know!
You found a bumper in the woods? lol
No way..... Are you fucking with us or did you actually find that?
I can confirm that it was just laying in the field that we drove in to take pictures... Super odd
Here I was.... 6 months ago. "I want an M3 Bumper I wish I could find one for free. "
Damn you
Lucky Find.. -
Great find!
Strange things can happen in parts finds. The hard top in my old 93 Miata was being used as a sled by some kids when the PO found it. He was driving by, did a double take, stopped and picked it up. A bit of fiberglass to repair some small cracks on the edges, new paint to match his Miata and good to go. I bought it from him and a few years ago sold it with the car.
The fact that it was an E36 M3 bumper too...
Field*
OEM?
I have a plate holder trim if you feel the need of buying one.
I will gladly take you up on that.
Damn you
Lucky Find..Funny thing is its in better shape than the bumper on my car.
Yeah it was the most super completely random thing. Andy jokingly was like, hey there's an extra bumper for your car (as he points to a white object in the middle of some tall grass and mud. I look over and see a bumper face down in the dirt. I could see the black molding on the side and replied with "Actually, that is a BMW bumper of some sort, I can tell by the trim." So I walked over and picked it up. Well no shit, its actually a perfect fit for my car.
Field*
This blows my mind, of all things to find in a field haha
I foresee more rust in your phuture
futurerustic!
I managed to find an Rx3 too when I went to pee behind a building, but it was completely rotted out.
What kind of car wasteland were you in and where is this?
Its called....
Madison
Madison really is like a fever dream I think we’ve all been living in simultaneously.
That being said, see you there Friday
Finally got the rest of the images from http://noggsphotography.com/
Rear end on this thing is super loose.
Ordering the following:
- Sub frame bushings
- swing arm bushings (#4/#12)
- Axles
- Wheel bearings (#1)
- Upper control arm bushings? (#2/#6)
Does anyone make, sell, or use aftermarket upper control arm bushings? Thoughts on this?
#2 and #6 on this diagram:
2 and 3 can both be replaced by using part 3 in both places. It is a spherical ball joint. I just did that recently, M cars came like that.
6 and 8 have so little rubber that they are likely just fine, no need to replace.
Also there are some places that make a RTAB replacement that appears to use #3 or a similar ball joint as an insert. That seems like an excellent option because the RTAB has multiple axis of deflection, although I have used UUC poly RTAB bushings for a long time and they are great as long as you grease them when installing to prevent squeaking.
