Diaries of a Daily Driver
It's an external spline type, I bet I could get them with a 12pt socket but didn't have much time to mess with them the other day.
Friend works at a dealer and should be able to find one that works, but now I need to find new lugs quick!I shall update if I come up with nothing, thanks for the assistance!
Whats the thread pitch? Pretty sure I have a full set from my E46 in my tool box.
I'm pretty confident that everything smaller than a 7 uses a 12x1.50 so the e46 and e39 should have the same wheel bolts. Maybe different lengths but same bolt.
@MPW3RLee came in clutch with the socket for the lugs, which are indeed identical to what I had on my red e30.
Out with the old
On with the new!
I've always wanted a set of style 32's, but never had a car for them. These were completely unnecessary but it seemed like the right thing to do!
I also grabbed a set of stockers from @DrLeadFoot that I will end up using for snow tires
It was idling rough yesterday, but still doesn't show a CEL. I feel like someone may have pulled the bulb....
I plan to scan it to see what codes are lurking and see if I can't quickly narrow down the issue.I will say that driving it yesterday was amusing, it pulls stronger than I remember and sounds good to boot!
Now to make it less of a rolling death trap!
Until next time!
Watch for the CEL to come on for a couple seconds when starting the car. It should self test every time you start turn the key to run. Wheels look good!
Haha, perfect! Thank you for the tip. I never really thought about using the self test stuff in that manner before.
It all makes sense. -
Looks so much better cleaned up on those style 32's.
AHHHHahahahahahahahahaaahhhahha
@jc43089 was right!
It's gonna be fun to see what codes it's throwing
Oh she a code throwin' hoe!
Most notable is the ""Function, inlet-camshaft control, bank 2"
I shall remove the vanos solenoid and give it a cleaning and clean up the contacts, but judging by some quick research this morning it is the result of a small timing discrepancy.
Plenty of o2 codes and secondary air system codes.It did say the front right wheel speed sensor is bad, which is cool because that means I don't have to try all 4 corners before replacing them!
Oddly enough it doesn't have any misfire codes...
Having a bit more of a lead to work on is quite convenient, and I shall begin to amass parts while I wrap up the diesel and then dive head first into this thing!
Until next time!
I replaced the hood cables (all) this weekend and cleaned the latches so that they actually hold the hood.
Threw the other wheels on now that I bought the lug tool ($5 on Amazon).
I replaced a handful of bulbs in the tail lights so those work properly now, added some new buttons back onto the HVAC controls (they were missing), just some general stuff!Next thing is to put fresh oil in it and replace the brakes, then drive it for a bit and re-scan codes to see what stayed!
I now own more wheels for this 540 than any other car I have had.
Picked up a set of 5 of these bad boys last night, they're a bit dirty but they are overall in good shape. The clear is starting to flake on one so I'm thinking about disassembly and polishing the lips and cleaning up the hardware.
Current wheel list:
16" Style 48's
17" Style 5's
17" Voxx Maglia's
18" Style 32's -
Haha, it's a bit of work for sure.
I think I'm going to build them for my future E30 build, and then if I need the cash I will just sell them.
I dunno, I had no real reason to buy them. -
getting the clear off is the worst, its tough as nails. aircraft stripper/power washer required.
keeping the polished lips clean is the 2nd worst. something with that alloy attracts pitting/dirt in a hurry.
personally, i wouldn't do it with that method again. I would, however, get the lips blasted/powdered to match the faces. they are a fantastic looking wheel.
FYI theres a reputable guy on R3v doing 4x100 fill & drill on style 5 faces now. good deal, too.
I've got some really nasty shit that pulls paint off 5 layers at a time lol, don't know its origins, but I'm sure you cant buy it anymore.
Cleaning lips is something I'm used to, the wheels on my red e30 loved to pull dirt and brake dust.
Coating the barrels is something that I would do, but at that point I would likely do something silly like black chrome with gold hardware or something else scene.
Couldn't find the fill n' drill thread on R3v
