  4. A 1997 e36 M3 that I shouldn't have bought :/
46 Posts 10 Posters 0 Views 1 Watching
    Yes I have a multi-meter. It is getting fuel. Just no spark. Before I bought it I tried putting new spark plugs in and that didnt work either.
    I have a feeling an ecu ground/fried or a cam/crank position sensor. Leaning more to an ecu problem.
    Gonna try some stuff tonight.
    Probably drive it for a few weeks but ultimately I bought it to flip because the price was decent.
    I have an ECU from @ChrisO's 97 M3 if you deduce the problem might be from that.
      Yep! Chris mentioned that to me. I'll hit you up on FB if that is my problem. I'll start digging into it tonight!
        Pulled the ECU in the rain today. Hoping that it would be my problem. There was a decent amount of dirt and grime in the ecu compartment but when I cracked the ECU open it looked fine.
        My next thought was the DME relay. Tested just fine. More looking tomorrow. Hopefully it isn't down-pouring.
          Another updated. Checked the system relay all is well. I shall keep researching and digging!
            Put a nut on the brown coil ground. Still nothing. Re-Installed the ECU. and started taking apart the intake system so I can pull the crank sensor tomorrow and test it!
              So today I was just about to pull the crank possession sensor when @ChrisO hmu. He asked If I needed to borrow his check engine light scanner. I didn't check it so I said sure bring it over!.
              We started fiddling with it and we actually noticed when you turned the key we couldn't hear the fuel pump priming. We compared it to his car and we confirmed our suspicion. After further evaluation we noticed there wasn't a 15 amp fuse in the fuel pump fuse spot. We popped one in and WHALAH it runs. It is currently having trouble idling but I assume it has something to do with the intake boot being so cracked and warn out.
              Woo my bank account doesn't look bad to me anymore.....
                Nice! Glad it was a simple fix. That torn intake boot will definitely make it run like absolute garbage
                  Getting a mishimoto asc delete one from a guy who owes me money tomorrow. So I like free parts 😂😂
                    Well my suspicion was confirmed today. It randomly/idled bad due to the old intake boot. Installed this mishimoto one and it started right up with no hesitation and went right back down to idle!  (700ish rpms)..
                    Next things to figure it out is the oil pressure light. I suspect that it's on due to the fact that there's so much gas in the oil the oil is very thin. I drained it and there is indeed alot of gas in the oil. Grabbing a filter and some 15w-40 mobil 1 to see if that's it!.
                    I also ordered a used oem clutch fan and a single lug nut.
                    Anyway does anyone have any experience with Aero Catches? I am not about to spend a couple hundred dollars to fix the hood cable when I can buy aero catches for 80 and it not be a pain in the ass LOL
                      If it was me, I'd try to tackle replacing the cable before i went and put hood releases on it. Worst case, you're out 30 bucks and you just get the aerocatches.
                      Found a DIY: https://www.bimmerforums.com/forum/showthread.php?668742-xjeeper-s-Hood-latch-and-cable-replacement-DIY-(the-easy-way)
                        I wish it was that cheap. But the cable was cut in multiple places. So I would need the whole kit. Would be around 150$. This car isn't perfect and I will probably selling it as a track car or something.
                          I have aerocatches on my e21 since it has a fiberglass hood.
                            Just get a cable from a parts car or a junk yard. prob cost you $20.
                              I have bought the cables, they aren't expensive.  33 for the long one and 19 for the one between the latches.
                              https://www.fcpeuro.com/BMW-parts/325i/?utf8=✓&year=1994&m=20&e=177&keywords=hood+cable
                              And the latches are 17 each if you need those but probably not.
                                Put new oil and oil filter in it today. Did not get rid of the oil pressure light. Going to replace the sensor tomorrow...
                                It's acting weird. It just kinda stalls out. Then a the sudden no power then stall. Gotta diagnose it..
                                The straight pipe is very ignorant and loud...
                                • ChrisOC
                                  ChrisOC
                                  ChrisO
                                  I'm praying for you
                                    ChrisO said:
                                    I'm praying for you
                                    Ehh worst comes to worst I sell it for what I paid 🤷‍♂️
                                      ChrisO said:
                                      I'm praying for you
                                      RIP.
                                        RIP.
                                        Did you discover something in between this post and the last one? Lol
                                          No lol. I just forgot I responded within 5 minutes and gave a generic response. I cant delete anything LOL
