  4. My 1997 M3 (That I'm not going to part out anymore)
parted out lmaorip
119 Posts 21 Posters 2.5k Views 1 Watching
  • ChrisOC
    ChrisOC
    ChrisO
    Do they still get BMWs frequently? I might need to go plundering for some brake booster related items.
    Interior is a good find.
    Fresh 4 door e30, forgot to tell you. decent amount of interior stuff left, all body panels too, didn't look under the hood. Black center console and glovebox, carpet, oh-shit handles
    The rear aero bumper doesn't have a removable diffuser. It has one molded in. The aero bumpers are actually just covers for the lower half of the stock bumpers.
    NWZkMmJkMDRiMGE5MmQyZTZhNjIyOTFlNTRlMzEw
    Hm, I'm not sure I guess I didn't get a good look at it. It definitely has the twisty M3 skirts, the build sheet says "S715A M Aerodynamics Package" I found a vert online with an identical build sheet and it just has the M3 rear bumper and diffuser.
    https://www.bimmerforums.com/forum/showthread.php?2128087-Very-Rare-Aegean-Blue-BMW-M-328i-e36-(1997)-lux-edition
      M Aerodynamics Package is completely different than the Aerodynamics Package. That would just mean the car got front and rear Mtech bumpers with twisty skirts. I somehow missed that you originally stated M Aerodynamics=\
        When are they open until during the weekend and weekend? I’m probably gonna have to make my way over on Saturday
          Awesome find!! Those extended leather pieces are really rare from what I understand and seem like the perfect candidate to restore and dye black! I've heard of people getting good results with leatheriques repair/dye kits, though I haven't tried it myself.
          • ChrisOC
            ChrisOC
            ChrisO
            Quick little update, I really need to start busting my ass on this car so I can have it daily-driveable for school
            Washed my floor pan like a weirdo and put my black carpet in, I haven't replaced that firewall gasket still but the dashboard can come out with the carpet in. The car remains garaged 24/7
            Putting a carpet in is always a PITA
            Got some mudflaps from a guy on Bimmerforums for $10
            Took my really bad sagging headliner out, glad I got it out before that foam/glue shit started getting all over everything. Very hard to clean off, happened on my last M.
            I put all the handles and visors back in, probably just gonna drive it like that for the fall
            I also tried to replace my rear emblem that was flaking apart, I got lucky and found a oem one off a e60 (same size) at the scrap yard.
            It was surprisingly hard to take off, it took a ton of force and I scratched the paint behind the emblem up 😐. The little pegs broke off inside the grommets. I ended up ruining both grommets getting those pegs out, so I have to order some of those.
            Check out that orange peel. I'm gonna guess this trunk is a respray, at least it has the vin still
            I also lined up my bumper and fog lights and it looks 1000x better then before
              ChrisO said:
              Have any of you ever dyed leather? Do you have to spray it on or do you just rub it in? This leather is stained beyond repair and some spots need to be filled etc. and I don't want tan anyway. They would look perfect dyed black and in my car
              I am going to be dying the door cards in the E30 along with the headliner and carpet. From the research I've been doing, the Duplicolor Fabric and Vinyl is the stuff to get, can be found at most automotive places and hardware stores. I've seen lightly wet sanding the leather with 1000 grit sandpaper, then cleaning the leather of an residual gunk, and then finally rubbing it down with some isopropyl alcohol. Then spraying the dye on like paint for the most part and letting it dry.
              I think I might dye the back seat black as it won't have very much traffic on it, but the front seats I will likely just be replacing.
              • ChrisOC
                ChrisOC
                ChrisO
                I found some leather dye at the craft store, but it doesn't work at all. It's hard to explain but it almost seems thinner then water and it separates out and refuses to stick to the leather. I'm concerned that the fabric and vinyl spray paint will have a very shiny appearance, do they make a more matte spray? I know that my rear seat is sort of shiny, but something like a shift boot has no shine and I think that's more like what I want for the center console
                  From the videos I’ve seen of people using this fabric dye it looks like the same consistency as spray paint. I will let you know how it goes, might start doing it this week.
                    Buy this and thank me later. I've had plenty of experience and know for a fact that it lasts. This stuff is magic.
                    https://877askxtreme.com/product/spraytech-vinyl-plastic-carpet-dye/
                    • ChrisOC
                      ChrisOC
                      ChrisO
                      Currently doing my RTABs,
                      Blown out pretty bad
                      The drill method worked pretty good, but I left a small notch in the trailing arm. Opinions on if it'll ever matter? It's obviously not huge, it's in the thickest spot of the arm and it's circular so it wont crack I'm thinking. The poly bushings went in snug
                      So I have the poly in, everything torqued and the arm is back in the car on the drivers side. unfortunately I found a small hairline crack at the mounting point. I'm not going to risk driving on it, so I need to have it welded and reinforcement plates welded in ASAP, I only have 2 weeks before I go back to school. Can anyone recommend a shop that will do this right? I don't want it rusting or anything like that because a shop didn't prep it right.
                      I hit it with some sand paper, and it is indeed a crack. The other side is the side that clunked bad, so fingers crossed
                      • ChrisOC
                        ChrisOC
                        ChrisO
                        I'm an absolute idiot, and despite trying to be more careful with the other trailing arm I cut into it worse. I didn't feel comfortable with it so I welded it and sanded it down
                        The trailing arm bushing went in very snug like the other side, but I need an honest opinion on if you guys would worry about this or replace the trailing arm. It's in a nice thick spot, but I'm not a pro welder and I doubt I penetrated very deep. These are cast from what I understand and I don't want it to crack and explode when I'm driving or something, I don't know if these things get insane load or if it's not that big of a deal
                        Also more cracks.
                          Also more cracks.
                          Honestly it should be fine. A nice piece of mind for you to have it welded, but sadly I have seen much worse on race cars that just send it.
                          On the other hand, that subframe mount totally needs to be repaired to prevent if from getting worse. Media blasting the area first prior to welding would be a very good idea. Where are you located? I can give you some suggestions based on your location..
                          • ChrisOC
                            ChrisOC
                            ChrisO
                            Thanks for the input, I feel a bit better about the trailing arm. As far as the cracking trailing arm mounts go, I contacted a performance shop in Green Bay hoping they would let me help out with the job so it's done right, as they have never done something like this on a e36 before. Finding a shop who has done a trailing arm reinforcement job already would be ideal, so I'm open to anyone within an hour or so of Green Bay.
                              No problem at all to cut a little into the trailing arm.  The full RTAB reinforcement it is necessary to drop the gas tank but you can cut the front portion of the AKG plates off or just leave it there but not welded.  Either way works.  Hang a soggy towel over the gas tank to prevent melting.  I have done it that way with no problems.
                              • ChrisOC
                                ChrisOC
                                ChrisO
                                Little update, I'm currently at school and finally got the car registered and drive it occasionally. The rtab bolt hole cracks I welded, and I have reinforcement plates that will go in this winter or spring. I gently drive the car to class or just around town a few days a week. Other then that it sits in my garage, but it's a blast and it's a very solid feeling car with the new BC's and poly rtab bushings on it.
                                Here is a day before I left for school, I had just gotten a fresh alignment so I threw my Fikse Mach V's on
                                I had about 1/2" of front wheel gap and -2.5 degrees of camber so I figured I might get some slight rubbing on corners and such. My old M3 had a way more agressive fitment with the rays then this, and I never had problems.
                                about 15 feet down my street I hit a bump while slightly turned and the fender hit the tire and literally bit a chunk out of the sidewall despite being mildly rolled. The Rivals are so soft that my fender is undamaged, but I guess I need a new tire and a pull on the front fenders 😐
                                I know, another stellar update
                                here's some pics from some of my drives in Eau Claire back on DS2's/ a LTW wheel 😂
                                My friend Evan and I took a trip to Mondovi for no reason one weekend, and I got a burger at Mondovi family restaurant.
                                WIBIMMERS food reviews: Don't go to Mondovi family restaurant.
                                When I was in high school we got better food
                                  Eau Claire?
                                  Thats where I exist at
                                    as an homage to stock wheels, you should roll with:
                                    (1) DS1
                                    (1) DS2
                                    (1) LTW
                                    (1) M-contour
                                      I'll second that the Mondovi family restaurant is not worth stopping for.
                                        Shit. a mcdouble looks better than that! LOL
                                        • ChrisOC
                                          ChrisOC
                                          ChrisO
                                          Eau Claire?
                                          Last year I saw someone at Culvers off Brackett Ave with a WIBIMMERS T-shirt on that wasn't @Rekpoint 🤔
                                          I live off water street
