  4. e34 540 Daily Driver Project
30 Posts 9 Posters 514 Views 1 Watching
  • StriggityStrackS
    StriggityStrackS
    StriggityStrack
    Slowly plugging away at this project. I changed the rear main seal and gasket even though it really didn't have any leaks at all. In hindsight I should have left it alone because the upper oil pan gasket just crumbled when I gently pried the rear crankcase cover off. I cut it cleanly at the ends and filled it with OEM loctite 5970 differential/pan sealant. ¯\_(ツ)_/¯  Worst case scenario I have to drop the entire oil pan but it should be done anyways by the condition of the gasket piece that disintegrated.
    • StriggityStrackS
      StriggityStrackS
      StriggityStrack
      @straight6pwr Did you have to do any DME flashing after the swap? I am hearing people say they experienced hanging revs if you keep the auto computer.
        no flashing. I didn't swapped DMEs either, they are the same for auto/manual cars. i've experienced no hanging revs or anything funny.
        my thread says i pulled my TCU (trans control module), but i have to confirm that i didn't put it back in. IIRC the 'trans program' error popped up when I pulled it, but I'll have to look.
          I have 2 upper oil pan gaskets if you need one, I could bring one to the cruise Saturday.
          • StriggityStrackS
            StriggityStrackS
            StriggityStrack
            Update from last weekend.
            I was able to get just about everything installed including some vogtland springs. I didn't get the driveshaft put back in because the shift selector rod was too short since it did not match the gearshift rod joint that was recently replaced incorrectly (part number change in 10/1994) by the last owner. Instead of purchasing a new one I cut, tapped, bent, and extended the old one to work. Turned out "Meh" but now it is fully adjustable. I had originally purchased some fittings for the bend from the master cylinder but I ended up just making a hard line that worked out even easier. I jumped the starter relay, started the car and everything works great. I should have it all wrapped up next weekend but who knows.
              Looks good!
              • ChrisOC
                ChrisOC
                ChrisO
                The style 24's look awesome. Never seen them on a e34 before
                • StriggityStrackS
                  StriggityStrackS
                  StriggityStrack
                  I looked everywhere on the inter-webs for example pictures and could not find anything. I see a lot of people running m contours but never the LTW's. I'm pleasantly surprised with how fitting they are on the vehicle.
                  • StriggityStrackS
                    StriggityStrackS
                    StriggityStrack
                    She is alive and dirty. I have a few gremlins to chase and body work to do but otherwise in decent condition.
                      Any plans to lower the back down a bit?
                      Love those wheels on there.
                      • StriggityStrackS
                        StriggityStrackS
                        StriggityStrack
                        I didn't put the exhaust back on yet because I am working on some bugs but I am hoping since it is 1,000,000 lbs it will help the back settle down a bit more. It does concern me enough to think about lowering the springs but I doubt I will act on it because the rake isn't horrible and this will be a daily driver.
                        • StriggityStrackS
                          StriggityStrackS
                          StriggityStrack
                          I’m really not a huge fan of the e34 steering wheel but instead of replacing it with a better one I was able to spruce it up a bit. I used a universal genuine leather wrap from Amazon and stitched it to match the M pattern. I didn’t know if I would like the wide stitching at first but it feels amazing in hand because it add a bunch of grip to the leather. All in all not a bad look for $20 total.
                            On a scale from 1 - 10, How hard was that?
                            It looks amazing though!
                            • StriggityStrackS
                              StriggityStrackS
                              StriggityStrack
                              The difficulty was a 5 but it took a good hour and a half to complete. The leather was surprisingly easy to manipulate and the stitching stayed tight along the way which I did not expect at all.
                                Link to the amazon product? Looks great!
                                • StriggityStrackS
                                  StriggityStrackS
                                  StriggityStrack
                                  Leather wrap in size "L-". I didn't go with the regular "L" because coincidentally there is a review from an e34 owner who suggested it is loose fit but it probably would have worked just fine if you don't like the gap in mine.
                                  https://www.amazon.com/gp/product/B01L8NUQSS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                                  Colored thread to match the M stitching. I have a whole bunch now though if you need some.
                                  https://www.amazon.com/gp/product/B06Y63TK4D/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                                    That's pretty awesome for how cheap it is. Link saved for future use!
                                    • StriggityStrackS
                                      StriggityStrackS
                                      StriggityStrack
                                      Well she drives but has the dreaded 50 shimmy. As of now I have the whole font suspension back off to work on the upper and lower control arms. It would have been great to do that when I replaced the front shocks.... On another note if anyone has some rare e34 goodies they are looking to liquidate feel free to push them my way.
                                        I want another E34 again. I’m partial to the skinny grilles
                                          I miss my e34 even more seeing this too. I'm also partial to pre facelift versus post facelift.
