2018 AutoX Events
roger that.
I will be, I think @straight6pwr and @m42b32 will be as well
Awesome see you all there
I won't be there unfortunately
I'm hoping to have my e30 done for the next Shawno event though, assuming they have another in September(ish)
This has been a bigger disappointment than any of us ever could have anticipated. I feel empty, nay, cheated, out of the opportunity to see your face tomorrow.
They should have one more in the fall months again though.
Don’t let me down twice in one year.
I'm sorry for the crushing disappointment, but don't worry, If I don't have an e30 to drive this summer/fall, I'll be sure to make it to at least one or two events in whatever else I have that runs
Pics!
I had some settings jacked up on my camera and didn't realize it. Also Fox Valley is less lax about just letting you walk around on the track to take pictures. Still managed to get a couple fun shots though.
King of Lean e46.
Mitch, driving that one guy's old car
Mitch over-cooking a corner.
Doing it properly this time.
Austin?
Dan.
Brooke.
And some inspiration For Matt Y, if he even comes around here...
Good times.
Mitch showed me the run times. You put some fast runs in with the E21! I say that is a testament to your ingenuity and suspension design, as well as your driving skills. Great job Mike! You should feel proud of your work
100% agree. That E21 rips
death to m42s!!!!!
Also can confirm that corner was well-done/overcooked
Had to post this here, because it's cool, AND because I think it really illustrates what it's like to drive this car.
After braking hard and hucking the car into a corner it's pretty neutral. The car rotates well, but both ends of the car feel like they have about the same grip (ie both sliding the same amount
). If you're patient and wait for the exit, and then ease into the throttle gently as the grip returns, you can keep the car nice and composed. If you're less saintly, you get into the throttle too early, or too aggressively. The car tells you you've done it wrong by stepping out the rear just a little. I learned long ago that at this point, letting off or countersteering to stop the slide causes the car to regain traction suddenly, and you're left scrambling (with no power steering) to keep the car pointed in the right direction. So, you basically have no choice but to steer the car with the throttle. Less throttle, less rotation. More throttle, more rotation. Stepping out the rear like this in a car with 140 crank horsepower probably isn't the fastest way around the track, but it's a helluva lot of fun.
Thanks for sharing your pics @HipMF
some tips if you need 'em for nikon cameras: If your lens has the VR switch, turn it off. it wont play well with camera panning or moving objects. Set your Autofocus mode to AF-C and 3D tracking. it predicatively changes the focus based on your subjects movement, to help catch focus on cars coming towards you.
finally got around to my photos
@MPW3RLee's E90 booty looks good going thru those corners...
it sounded amazing too!
agreed. The M3 sounded sweet.
Thanks for the tips. The last time I used the camera was at a show that I went to, so I had the ISO jacked up to 800 and autofocus set to AF-S. I just forgot to change it before I started snapping away. Noob mistake. Live and learn...
<a href="http://ribbonheadchicago.bandcamp.com/album/racing-to-the-bottom-ep" rel="external nofollow">Racing to the Bottom EP by RIBBONHEAD</a>
Thanks guys and nice pics! Maybe by next event I’ll be able to figure out who’s who by all your guys cars
️I’m planning on going to the next event at RA on Aug 12th, I’ll have to make it a point to actually put some faces to the names. I will say though the e21 was definitely one of my favorites out there!
