  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    I love the cold tach display with the reduced rev limit on those.
    You are also now the resident SMG master tech
      I'll take that title.
      E30, LS1, SMG'd T-56???
      • IceddragonI
        IceddragonI
        Iceddragon
        That tachometer is so clever if I'm understanding it right. The yellow bars go away once the engine is warm? Or are they indicators?
          Yessir, the maximum rpm is limited with respect to engine temperature. Im not sure if its coolant or oil temp dependent but its neat that its displayed on the tach
            Haven't updated this one in awhile.
            Recently:
            - Replaced constant pressure oil valve.
            - Installed RTABs with poly bushings
            - Got 2 big leaks in my exhaust properly welded and fixed.
            - Installed new Bavarian Sound Werks speakers.
            - Sound deaded the front door panels.c5a2e8388c0094e47bd415518bcd1f21.jpg28c5e046a87425988e28f7e74ba0cc17.jpg
              How do you like the Bav Sound speakers? Always been interested in them, just don’t make anything for pre-2k models.
                Ehh, they are okay. The biggest mountain to climb with the sound is the rattling in the door panels. Added their material to the insides of the front doors and it helped a lot but still isn't amazing.
                I can't wait to get back into the e30 with the speakers ampped with 500 watts and a 1000 watt sub.
                  Oil and filter change.
                      168,826 miles.  Oil & filter change.  OEM filter, Liqui Moly 10w-60.
                      She is running strong!  Daily driving it all over Wisconsin and also drove it to Colorado a month back!
                        Did a water pump around 172,XXX but forgot to post.
                        More updates to come!
                          I love that you have those mudflaps on this thing.
                            They probably pull my MPG down a point or two but you gotta be ready for the mud!
                              Getting some odds & ends tightening up.
                              -The steering wheel I got as a replacement had the airbag bracket bent a bit.  Put my old bracket in to had the airbag sit in the wheel at the proper height and not stick out.
                              -"New" door sills.
                              -Grip strip wasn't working on the trunk.  The valet lockout wasn't making the connection.  Bent it a bit and now the grip strip opens the trunk.
                              -New tabs to correct the loose triiimmm.
                                Getting the lower rear window seals replaced and found some spots.  Sand, prime, paint!
                                  All buttoned up!
                                    And that’s why they call you doctor, nice job!
                                      Diff and trans fluid change!
                                        New trunk!
                                          I love it!!!
                                          is that CF or steel?
