  4. 1999 M3 daily driver running log
264 Posts 28 Posters 5.0k Views 4 Watching
    Come to think of it, I dont remember what ° I have. Probably 88 [emoji19]
      Ready for summer! Slapped on the roof rack and a square set of 17x8.5 contours with 245/40/17 Falken Fk510's. Loving the wider rubber already, it looks a lot meaner! Not usually a black wheel fan, but on the white/modena it really makes the interior pop!
      I also discovered I don't have any roundel center caps for my wheels, so if anyone has a set in decent shape (68mm, 36136783536) let me know!
        Curious how the roof rack is mounted.
          Its Thule Traverse 480 feet, with the fit kit 1015 (fits the feet to an e36 coupe), and I can't remember the width of the bars but I had them on my e30. Looks like they don't make that specific fit kit anymore but some retailers still have it in stock. It's basically rubber pads that are shaped to the roof profile, and then clamps that come down and grab onto the crack just above the window trim. It basically squeezes itself to the shape of the roof, but its on there really well!
            This looks great white black wheels. I dig!
              140k
              The keyless entry has developed a mind of it's own and immediately re-locks the doors after hitting the unlock button. I suspect the trunk lock/actuator is messing with things as it has been very sticky and tough to operate lately. Anyone have behavior like this before? Other things to look for?
              Edit: English is hard, fixed...
                140k
                The keyless entry has developed a mind of it's own and immediately locks the doors after hitting the lock button. I suspect the trunk lock/actuator is messing with things as it has been very sticky and tough to operate lately. Anyone have behavior like this before? Other things to look for?
                Seems good to me!  I assume you mean the doors lock and then unlock right away?  My coupe does this as well.  I don't have a key fob, it does the lock and immediately unlock if I push the rod down.  If I push it down a second time they all stay down.  I just don't lock it, I think it has something to do with the limit switches for the door being closed.  Do your windows drop when you open the door?  Mine do not.
                  Seems good to me!
                  Came here to post this.
                  Is it by chance an air actuated system like Audi/VW uses? im guessing not but the only time I had issues like that was on a pneumatic system
                    Whoops haha, fixed that! It's actually the opposite: If the car is unlocked and I lock it, it all works fine. If the car is locked, and I hit the button to unlock it, the car re-locks itself immediately. This only happens when I use the keyless remote (earlier 3-button system if that matters). The window drop works on both doors. Good call on the limit switches, I have the hood switch connected to the alarm so that or the trunk could possibly be causing a problem.
                    It's an electric system with actuators on both doors and the trunk, and limit switches on each of those as well as the hood.
                      I had this issue on my 95 325is and it was a security issue with the window pressure sensors.  Replacement of the driver side window motor fixed it.
                        Minor update: It has now changed it's mind and the situation is reversed. Only does it with keyless, key works fine in all doors and trunk lock. Looks like I've got a date with a multi-meter pretty soon.
                          on e30s,  problems with the central locking 'disagreeing' with locking is caused by actuators that have gone bad, or door lock/latch mechanisms which are a little sticky and make the sensors in the actuators misread due to the extra resistance. i'd try lubing all the mechanisms first and see if you see an improvement.
                          not sure if this applies to e36s.
                            If you end up needing a trunk lock actuator, I have one you can come steal.
                              140.3k
                              Oil changed with Mobil1 5w50
                              Haven't gotten a chance to look into the lock situation, might get to it this weekend. I did, however, finally get into cleaning the interior before the picnic last weekend. I had time to get into everything but the leather on the front seats. It had gotten pretty dirty, but it's looking awesome now. I'm planning to finish up the front seats this weekend and will finally get some pics of the interior in this thread.
                              With the super hot weather coming up this weekend I reinstalled the AC belt and tensioner. I had taken it off when I was investigating weird noises maybe two years ago and never got around to reinstalling it. The AC worked well when I bought the car, but unfortunately it doesn't do much anymore. RIP.
                              I also added another rack to the roof rack so I can carry my mountain bike (it didn't fit the existing racks). Looks good up there
                                A/C is usually a pretty simple fix if you don't need to rebuild the compressor. Buy a can of AC stop leak fix and a A?C Pro recharge and it might be all you need.
                                ( if you are interested PM me, I can get a deal on this stuff)
                                Image result for ac leak stop leakImage result for ac recharge
                                  142.5k
                                  After picking up the wagon I now have too many cars, so over the weekend I did a bunch of things I've been meaning to do to start prepping this car for sale 😦... all that's left is to give it a good detail and remove a few parts I want to transfer to the wagon or sell separately.
                                  As a last hurrah before it gets listed, I took it to the FVSCC autocross at the newly repaved Road America motorplex and had a blast! The car didn't miss a beat and handled fantastically despite the higher treadwear tires and meh brake pads. I didn't have any of the common lifter tick issues either as I ran it a half-quart over full and let the revs sit at 3500 for the 2-3 minute drive back to grid after each run. The new motorplex surface is really smooth but it is also super slippery, lots of counter steering was needed! There were a lot of people doing a bit of landscaping in the earlier runs. I competed in STR and took a respectable 10th place... out of 10 haha, turns out that class is super competitive and had 4 of the top 20 overall times. I ended up in 91st out of 159 for raw times so I'm more than happy with that!
                                    I really want to get out to one of the auto x events at this track next year, I think E30 should be pretty well suited for it. I believe @MPW3RLee was there as well.
                                      THAT INTERIOR!!!! I JUST CANT GET OVER IT!
                                        I had my e30 there last year and it was a riot, to be fair its a blast in just about any car, adding elevation to an auto-x (like at RA and USAIR) is so much fun!
                                        • ChrisOC
                                          ChrisOC
                                          ChrisO
                                          Same, it would be cool to know people there already when it is my first time!
