  4. Lifted E30 V2
Lifted E30 V2
    18 days and 14 hours remaining until e30 picnic begins...
    I will eat a shoe if this thing makes it to the picnic
      Quoting for proof. Although I think I'm siding with you on this one.
        Image result for sniffle gif
          Got to see this beast in person over the weekend! Unfortunatly it was static 😕
            The lack of confidence is saddening really.
            My lack of time to work on it isn't great, but I have an action plan, and it all involves the Friday evening before the picnic, as that is my first available time.
              Dont let the nay sayers get your hopes down. I have faith in you!
                I have thrown in the white flag. Time to switch back.
                Got more air worked out of the system but still doesn't want to idle or run normal, and then will frequently just rev itself up to 4500 or so and just sit there with no throttle input while smoking white (blue?) a whole bunch.
                Either the motor is toast or the pump isn't working right, with my suspicion more toward the pump.
                    selling the diesel setup then?
                      Sorry to see this. It was a great project idea and the running/road pictures were priceless.
                      Just a final 'evil voice in your ear' thought before others suggest it or to counteract any good advice and to potentially save @Bassboy3313 from himself. Perhaps consider one last rumbling, smoke belching, engine destroying ride through the e30 picnic grounds? If it's going to go perhaps go in style? We might lose the site for future picnics but could be worth it...   😈
                        Where is that dislike button?!?!??!
                        Seriously do NOT let this thing defeat you, you were and are sooo close!
                        Maybe find a trust worthy diesel guy and have him look at it?
                        Maybe find a pump that you can convert to run instead?
                        There has to be somethign you can do other than give up.
                        I would be happier if you did do a cummins swap though vs another M20. (sorry not sorry)
                          Easy gentlemen!
                          I appreciate the words of not giving up, and you are all correct. I am not letting this win (just yet), but I want to drive the damn thing a bit, so I'm throwing the motor that works fine back in it.
                          I will be building a rolling cart to put the diesel on so I can roll it outside and play and try to get it working. I don't need a chassis for that, which is quite convenient. The more I think about it the more I don't trust the pump. That's the only thing that makes it work, and the motor isn't working right.
                          There is a running driving 524td for sale that I may go look at, a spare motor wouldn't hurt, and there is a chance it has a similar enough pump that wouldn't require a whole bunch of wiring.
                          I have reached back out to Dave and Ivo to see if someone can find another pump.
                          For the time being I think driving it with an M20 is more fun than not driving it at all!
                          It does suck to be 3k deep into something that I'm taking out though lol.
                          • dealindaveD
                            dealindaveD
                            dealindave
                            I always thought it would be neat (albeit impractical (depending on your definition of impractical)) to swap a 4bt or 6bt into an E30
                            I will do my best to find a suitable replacement pump so you don't have to reinforce the front end of the car to support a cummins though lol.
                              Getting it running on a stand is a great idea. Get'r done and driving to the picnic!
                                As long as your not giving up, I am no longer upset.
                                  My first non booked evening is Friday, so it's an ambitious plan.
                                  It also looks like rain saturday
                                    Cummins engine stands up straight and would be way too tall.  30.7" tall.  Also 800ish pounds would make the handling somewhat non optimized.
                                      Looks like only a 30% chance at the moment though!
                                        Last year it rained and I mistakenly left my umbrella at the picnic. Im hoping its still there
                                        If anyone could get this thing going it would be you
                                          Dont be so negative. Ive seen it done in a Miata and it fit perfectly.
                                          Image result for cummins miata
