    Love how you are using lots of OE volvo stuff.
    I am jealous of your oil cooler but I think thats just about the smallest oil filter I ever did see!
    Cute lil guy
    • The Full BananaT
      The Full BananaT
      The Full Banana
      I've been working on this a lot, except when it's over 90 degrees in the garage because forget that. Yesterday afternoon I got the car back down on the ground for the first time since February. I drove it 8 feet back and forward, and then decided that I needed to wash it.
      It's clean again, phew.
      For extra content to offset my lazy post, here are a couple other details:
      Stainless hardlines that control the wastegate, and a bracket to secure them (the plastic bit will be replaced with something aluminum or stainless)
      Crankcase ventilation system is all plumbed as well (although I will be replacing these hoses with some Aeroquip hose when I get around to it). Two valve cover vents and the factory oil separator box outlet are plumbed into the ProVent, which returns to the intake pipe via a silicone hose underneath the front of the engine. The ProVent drains back into the oil pan through a fitting next to the dipstick.
      I bought a 28mm drop swaybar. This was necessary to clear my oil pan, and is the largest swaybar available for this car.
      And here's the harness connector finished off with some raychem 4:1 shrink and a 90 degree shrink boot.
      I've left out about 95% of things, so this seems like a good place to end this post. Next up is getting the car running well on megasquirt.
        That looks so good with the engine turned the right way...
          Awesome Tom!! From everything you told me on Saturday and now seeing this, I am extremely excited for my ride along. 😄
          • The Full BananaT
            The Full BananaT
            The Full Banana
            Thanks guys! I can't wait until it's ready to give ride-alongs!
              Bumping from way back, I saw this and it reminded me of your project.
              https://bringatrailer.com/listing/1984-volvo-242-turbo-coupe-2/
              • The Full BananaT
                The Full BananaT
                The Full Banana
                Yeah, the guy did a really nice job on that one. Pretty impressive that it's road legal in California without any diesel registration trickery or anything like that.
                Anyway, I still have this car. I popped the head gasket last fall, so in the process of replacing that, a bunch of things snowballed which currently leaves me sitting here with a refreshed head with a little porting, rebuilt turbo, fresh powder and ceramic coatings, a revised oil drain from the turbo to the factory block drain port, and a million other little adjustments (including another set of BBS RCs that are wider).
                I just started it back up on Sunday. It was excellent, but then had quite a bit of white smoke after a few minutes, then came misfires. Time to diagnose. There's a real temptation to part this out and buy a clownshoe. 🤡
                  Bummer, think it cracked a cylinder?  I can't remember, did you shim the block?
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    It’s possible, but seems a bit odd. It’s a 2.3 bottom end that I put hbeam rods in and shimmed the liners. Between all of that, it really shouldn’t be anywhere near the threshold of cracking (unless it wasn’t in great shape before I got it). I’ll pull spark plugs and check for signs of coolant in the combustion chambers (especially #5 where the gasket failed).
                      Oh I would think that would be sturdy.  I thought you had the 2.5 block.  Do you have any codes for the misfires?  Do you have VIDA/DICE? I just got one, still struggling with software.  If it would help you could borrow it once I figure out my AWD issue.  I replaced the collar gear that was stripped on my vR and it worked for a little while but now it won't engage but no CEL or alarms on the dash.  Hopefully this will help me figure out what's up.
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        I'm running Megasquirt MS3x with this engine, so no codes. Old fashioned diagnosis it is!
                          That's not a bad thing, this VIDA/DICE thing is a huge pain.  Chinese adapters and hacked dealer software on VM images is making my head hurt.
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            In a delightful twist of fate, this seems to be running pretty well. Boost control is working now so I can actually drive it normally without constantly feathering the pedal.
                            70% chance I'll show up to the e30 picnic with this and park somewhere out of the way as to not offend.
                              Great!  Im looking forward to it
                                its boxy. it has round headlights. if you average the #of cylinders for available e30 motors, you get 5. i think no one will notice.
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Just for the record, I did end up showing up to the e30 picnic in this... for about 10 minutes at 2:15. No photo evidence aside from washing it in my driveway that morning.
                                    Certified
                                      I hearby stand as a witness to this testament
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        A year later, and I'm just about to button up installing a fresh engine built with Wiseco pistons and h-beam rods in a painstakingly refinished engine bay. This car has been a real test of my patience and perseverance.
                                          I envy your workmanship! New motor for more power?
